Hello
I’m trying to use
In the README.md file, i’m trying to make a project with the code inside the section “Setting up the server”.
After received errors about SPPIFFS and others i solved them adding includes. No errors with this.
But i get “/main.ino:81:21: error: ‘Update’ was not declared in this scope” and after hours and hours reading and reading, i’m totally stucked and i need some help.
The code i have in main.cpp is the following:
#include "FS.h"
#include "WiFi.h"
#include "AsyncTCP.h"
#include "ESPAsyncWebServer.h"
#include <SPIFFS.h>
AsyncWebServer server(80);
AsyncWebSocket ws("/ws"); // access at ws://[esp ip]/ws
AsyncEventSource events("/events"); // event source (Server-Sent events)
const char* ssid = "your-ssid";
const char* password = "your-pass";
const char* http_username = "admin";
const char* http_password = "admin";
//flag to use from web update to reboot the ESP
bool shouldReboot = false;
void onRequest(AsyncWebServerRequest *request){
//Handle Unknown Request
request->send(404);
void onBody(AsyncWebServerRequest *request, uint8_t *data, size_t len, size_t index, size_t total){
//Handle body
void onUpload(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final){
//Handle upload
void onEvent(AsyncWebSocket * server, AsyncWebSocketClient * client, AwsEventType type, void * arg, uint8_t *data, size_t len){
//Handle WebSocket event
void setup(){
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.printf("WiFi Failed!\n");
return;
// attach AsyncWebSocket
ws.onEvent(onEvent);
server.addHandler(&ws);
// attach AsyncEventSource
server.addHandler(&events);
// respond to GET requests on URL /heap
server.on("/heap", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", String(ESP.getFreeHeap()));
// upload a file to /upload
server.on("/upload", HTTP_POST, [](AsyncWebServerRequest *request){
request->send(200);
}, onUpload);
// send a file when /index is requested
server.on("/index", HTTP_ANY, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.htm");
// HTTP basic authentication
server.on("/login", HTTP_GET, [](AsyncWebServerRequest *request){
if(!request->authenticate(http_username, http_password))
return request->requestAuthentication();
request->send(200, "text/plain", "Login Success!");
// Simple Firmware Update Form
server.on("/update", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/html", "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>");
server.on("/update", HTTP_POST, [](AsyncWebServerRequest *request){
shouldReboot = !Update.hasError();
AsyncWebServerResponse *response = request->beginResponse(200, "text/plain", shouldReboot?"OK":"FAIL");
response->addHeader("Connection", "close");
request->send(response);
},[](AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final){
if(!index){
Serial.printf("Update Start: %s\n", filename.c_str());
Update.runAsync(true);
if(!Update.begin((ESP.getFreeSketchSpace() - 0x1000) & 0xFFFFF000)){
Update.printError(Serial);
if(!Update.hasError()){
if(Update.write(data, len) != len){
if(final){
if(Update.end(true)){
Serial.printf("Update Success: %uB\n", index+len);
} else {
// attach filesystem root at URL /fs
server.serveStatic("/fs", SPIFFS, "/");
// Catch-All Handlers
// Any request that can not find a Handler that canHandle it
// ends in the callbacks below.
server.onNotFound(onRequest);
server.onFileUpload(onUpload);
server.onRequestBody(onBody);
server.begin();
void loop(){
if(shouldReboot){
Serial.println("Rebooting...");
delay(100);
ESP.restart();
static char temp[128];
sprintf(temp, "Seconds since boot: %u", millis()/1000);
events.send(temp, "time"); //send event "time"
and in platformio.ini i have:
ESP Async WebServer
AsyncTCP
Can anyone give me some light, please?
Thanks in advance.
Pedro
