This is the whole script I use to re-direct toolchain paths and filter specific GCC non-compatible flags and add new ARMCC-specific flags.
# Run "pio run -t envdump" to display whoe "env" object with all its contents
# to verify whether data written here is also written in there
import os
from SCons.Script import Import
Import("env")
Import("projenv")
platform = env.PioPlatform()
# Filter out excluded build options from flag variable
def FilterFlags(flagVar, filteredOptions):
filteredFlags = [flag for flag in flagVar if flag not in filteredOptions]
return filteredFlags
# Define list of flag variables for option exclude
filteredBuildFlags = ["CPPFLAGS", "CFLAGS", "CCFLAGS", "CXXFLAGS", "ASFLAGS", "LINKFLAGS", "_LIBFLAGS"]
# Define default flags to exclude from all flag variables
filteredOptions = [
"-Wall",
"-ffunction-sections",
"-fdata-sections",
"-mcpu=cortex-m3",
"-Os",
"nostdlib",
"-l",
"-mthumb",
"-Wl,--gc-sections,--relax",
"-specs=nano.specs",
"-ggdb3",
"-ggdb2",
"-ggdb",
"-D",
"-2"
# Add more flags to exclude as needed
# Modify flags globally (as if through "build_flags")
for e in [env, projenv, DefaultEnvironment()]:
# ARMCC toolchain executables
e.Replace(
AR = "armar",
AS = "armasm",
CC = "armcc",
CXX = "armcc",
LD = "armlink",
LINK= "armlink",
GDB = "arm-none-eabi-gdb", # to retain compatibility
OBJCOPY = "fromelf --bin --output $TARGET $SOURCE && echo",
# For displaying ROM/RAM usage
SIZEPROGREGEXP=r"^(?:ER_IROM1)\s+(\d+).*",
SIZEDATAREGEXP=r"^(?:RW_IRAM1)\s+(\d+).*",
# Preprocessor flags
#e.Replace(CPPFLAGS = [])
e.Append(CPPFLAGS = [
"-DUSE_HAL_DRIVER",
"-DSTM32F103xE",
"-DUSER_VECT_TAB_ADDRESS"
"-DHAL_WWDG_MODULE_ENABLED",
"-DHAL_IWDG_MODULE_ENABLED"
# Compiler flags
#e.Replace(CCFLAGS = [])
e.Append(CCFLAGS = [
"--c99",
"-c",
"--cpu=Cortex-M3",
"-g",
"-O0",
"--thumb",
# Assembler flags
#e.Replace(ASFLAGS = [])
e.Append(ASFLAGS = [
"--cpu=Cortex-M3",
"-g",
"--apcs=interwork",
# Linker flags
#e.Replace(LINKFLAGS = [])
e.Append(LINKFLAGS = [
"--cpu=Cortex-M3"
#"--list=$BUILD_DIR/$PROGNAME.map" # causes errors for some reason
# Replace "-T" with "--scatter" for linker (scatter) scirpt
old_flags = e["LINKFLAGS"].copy()
try:
i = old_flags.index("-T")
old_flags[i] = "--scatter"
e.Replace(LINKFLAGS=old_flags)
except:
pass
# Remove "-Wl,..." which are GCC specific
e.Replace(_LIBFLAGS = [])
# Prevent searching for default linker file
e.Replace(LIBPATH = [])
# Filter out excluded flags from all flag variables
for flag in filteredBuildFlags:
existingFlags = e.get(flag, [])
filteredFlags = FilterFlags(existingFlags, filteredOptions)
e.Replace(**{flag: filteredFlags})
# Add new toolchain to path
pkg = platform.get_package("toolchain-armcc")
e.PrependENVPath(
"PATH",
os.path.join(pkg.path, "bin")
if os.path.isdir(os.path.join(pkg.path, "bin"))
else pkg.path,
