Hi
Currently I am adding a new table for Marlin but I am getting an error that the new table for Marlin is not found and it is not compiling for me.
Have you guys encountered this error before and is there any way that can help me compile it?
I have attached some pictures
The error does not come from any .h or .cpp file modifications but from the platformio.ini. You state board = MIX_COLOR_VN_V1_0 in it. So, there must be the board definition JSON file for it somewhere, expected to be called MIX_COLOR_VN_V1_0.json. The error indicates there is none.
so this is where naturally all custom board JSON files are being stored.
Part 2 is the STM32Duino variant for the board. Now Marlin is really advanced here and uses an extra script for generate_generic_variant.py to do this on-the-fly.
Read the script carefully. You will find that what it does is
Instead of using custom board definitions and variants, try to work with the already existing board definitions and Arduino varaints. From the STM32F407IX macro your target chip is partly clear. For that series, PlatformIO only has the genericSTM32F407IGT6 board definition However, you will see in that link that PlatformIO doesn’t declare the board to be compatible with the Arduino framework – this is in this case incorrect and an oversight on the PlatformIO side. Starting at STM32Duino v2.0.0, there is a STM32F4xx/F407I(E-G)(H-T)_F417I(E-G)(H-T) variant folder that would apply to this chip and Arduino-enable it, it just isn’t declared as variant in the board’s JSON file, genericSTM32F407IGT6.json. So custom modification is necessary anyways which leads to…
using custom board definitions and Arduino variant. You should start by copying the above referenced JSON file as MIX_COLOR_VN_V1_0.json in the buildroot/share/PlatformIO/boards folder and make adjustments to it, specifically,
expand the "frameworks" array to contain "arduino"
in the "build" section, add a new attribute with "variant": "MIX_COLOR_VN_V1_0" (the name for the variant folder can be arbitrary but for simplicity should match the board file name)
correct the "mcu", "maximum_ram_size" and "maximum_size" to the correct values if your MCU is not exactly a STM32F407IG.
then, go to Marlin’s buildroot/share/PlatformIO/variants folder and create the variant folder there, named MIX_COLOR_VN_V1_0 as declared before. You can grab the STM32F4xx/F407I(E-G)(H-T)_F417I(E-G)(H-T) files from STM32Duino 2.0.0 as a starting point and put them in that folder. Note that these are the files for 2.0.0 but Marlin, through declaring that an older ststm32 platform is used uses STM32Duino 1.9.0. In STM32Duino 1.9.0 there wasn’t a variant for the STM32F407IG yet (available variants) and the filenames and file contents may be slightly different from 2.0.0 and 1.9.0, so you’ll have to play aroud with them a little. A modification that definitely seems to be necessary is renaming variant_generic.h/pp to variant.h/cpp. You should also make sure to define a clock initialization function SystemClock_Config() that matches your board’s hardware (e.g., use HSE=8MHz with PLL to get to 168MHz, make sure the USB clocks are correct so that USB will work). That can be done as documented in the STM32Duino Wiki with STM32CubeMX. I’m sure you will also have to edit default pin settings in the variant.h for e.g. I2C, Serial etc…
Doing that should give you the board definition file so that there is no “unknown ID” error anymore, the Arduino variant is then needed to actually support the board in STM32Duino.
