My previously working VS Code + PlatformIO development framework stopped working. Previously building Tasmota build now results in Error: Unknown board ID 'esp8266_1M'
- I’ve uninstalled VS Code, deleted <user>\.platformio and .vscode folders, deleted the local repo
- I’ve downloaded the repo, reinstalled VS Code, installed PIO IDE, it installs all the necessary frameworks, but than gives this error
- certainly the boards folder contains the necessary .json files
- Tasmota developers said “it should work”, yes, and it has worked a few weeks ago, but something changed
- googling this error for days yielded nothing useful
What can cause this type of error???
Versions: everything is the latest
> Executing task: C:\Users\lmagyar\.platformio\penv\Scripts\platformio.exe run <
Processing tasmota (platform: espressif8266 @ 2.6.3; framework: arduino; board: esp8266_1M)
Tool Manager: Installing platformio/toolchain-xtensa @ ~2.40802.0
Tool Manager: toolchain-xtensa @ 2.40802.200502 has been installed!
=========================================== [FAILED] Took 126.69 seconds ===========================================
Verbose:
PS Z:\Local\GitHub\lmagyar\Tasmota> pio run -v
Processing tasmota (platform: espressif8266 @ 2.6.3; platform_packages: tasmota/framework-arduinoespressif8266 @ ~2.7.4, platformio/tool-esptoolpy @ ~1.30100; framework: arduino; board: esp8266_1M; board_build.filesystem: littlefs; build_unflags: -Wall, -Wdeprecated-declarations; build_flags: -DCORE_DEBUG_LEVEL=0, -Wl,-Map,firmware.map, -Wno-deprecated-declarations, -mtarget-align, -free, -fipa-pta, -Wreturn-type, -DUSE_CONFIG_OVERRIDE, -DNDEBUG, -DFP_IN_IROM, -DBEARSSL_SSL_BASIC, -DPIO_FRAMEWORK_ARDUINO_ESPRESSIF_SDK22x_190703, -DPIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH_LOW_FLASH, -DVTABLES_IN_FLASH, -DPSTR_ALIGN=1, -DMIMETYPE_MINIMAL, -DWAVEFORM_LOCKED_PWM; monitor_speed: 115200; upload_port: COM20; upload_resetmethod: nodemcu; extra_scripts: pio-tools/strip-floats.py, pio-tools/name-firmware.py, pio-tools/gzip-firmware.py, pio-tools/override_copy.py, pio-tools/download_fs.py; lib_ldf_mode: chain; lib_compat_mode: strict; lib_extra_dirs: lib/lib_basic, lib/lib_i2c, lib/lib_display, lib/lib_ssl, lib/lib_audio, lib/lib_rf, lib/lib_div; lib_ignore: Servo(esp8266), ESP8266AVRISP, ESP8266LLMNR, ESP8266NetBIOS, ESP8266SSDP, SP8266WiFiMesh, Ethernet(esp8266), GDBStub, TFT_Touch_Shield_V2, ESP8266HTTPUpdateServer, ESP8266WiFiMesh, EspSoftwareSerial, SPISlave, Hash, ArduinoOTA)
