Error: The PlatformIO task detection didn't contribute a task
Whenever I start the build process I get a “Task error” notification, with the following output:
Error: The PlatformIO task detection didn’t contribute a task for the following configuration:
“type”: “PlatformIO”,
“args”: [
“run”
“problemMatcher”: [
“$platformio”
The task will be ignored.
However the build process seems to work normally.
What can I check?
Thanks
Giovanni
Estou com mesmo problema, conseguiu resolver?
Please remove tasks.json from .vscode folder.
Yes, I removed tasks.json, rebuilt the project and the error did not show up anymore. If rhallado confirms the same we can close the issue.
Thank you very much!
Giovanni
the same error can appear if another workspace folder has that file… solved by removing.
So, check extra folder too.
