It contain some of the following information in the developer tools:
Extension Host] (node:30040) [DEP0147] DeprecationWarning: In future versions of Node.js, fs.rmdir(path, { recursive: true }) will be removed. Use fs.rm(path, { recursive: true }) instead
(Use `Code --trace-deprecation ...` to show where the warning was created)
y @ console.ts:137
console.ts:137 [Extension Host] runCommand C:\Users\31324.LAPTOP-DT05SR3D\.platformio\python3\python.exe Array(3) Object
console.ts:137 [Extension Host] runCommand C:\Users\31324.LAPTOP-DT05SR3D\.platformio\python3\python.exe Array(1) Object
notificationsAlerts.ts:42 Error: error: subprocess-exited-with-error python setup.py bdist_wheel did not run successfully. exit code: 1 [610 lines of output] running bdist_wheel running build running build_py creating build creating build\lib creating build\lib\platformio copying platformio\app.py -> build\lib\platformio copying platformio\cache.py -> build\lib\platformio copying platformio\cli.py -> build\lib\platformio copying platformio\compat.py -> build\lib\platformio copying platformio\dependencies.py -> build\lib\platformio copying platformio\exception.py -> build\lib\platformio copying platformio\fs.py -> build\lib\platformio copying platformio\http...
[[object Object]]PlatformIO Core is not installed
[[object Object]]Response code 413 (Request Entity Too Large)
I recently open vscode and platformio show this problem. According to previous post I have try:
- Remove the PIO extension in VSCode. Delete
C:\Users\<user>\.platformio
completely - enabling win11 to long pathnames
- delete python and install the newest version on the official website
- change the internet envir
but none of them works
Thank a lot if anyone could help me have some solutions on this problem
