Hardware:
Board: ESP32 Dev Module
IDE name: Platform.io
Flash Frequency: 40Mhz
PSRAM enabled: no
Upload Speed: 921600
Computer OS: Mac OSX
Description:
Hi, I’m trying to use the “HTTPS_OTA_Update.ino” to perform OTA update of ESP32. But when I compile the code, an Error message appears “error: ‘struct esp_http_client_config_t’ has no member named ‘skip_cert_common_name_check’”. I go to the struct ‘esp_http_client_config_t’ and found no member of ‘skip_cert_common_name_check’. How to solve this problem?
Thanks!
Sketch:
//Change the code below by your sketch
// This sketch provide the functionality of OTA Firmware Upgrade
#include "WiFi.h"
#include "HttpsOTAUpdate.h"
// This sketch shows how to implement HTTPS firmware update Over The Air.
// Please provide your WiFi credentials, https URL to the firmware image and the server certificate.
static const char *ssid = "your-ssid"; // your network SSID (name of wifi network)
static const char *password = "your-password"; // your network password
static const char *url = "https://example.com/firmware.bin"; //state url of your firmware image
static const char *server_certificate = "-----BEGIN CERTIFICATE-----\n" \
"MIIEkjCCA3qgAwIBAgIQCgFBQgAAAVOFc2oLheynCDANBgkqhkiG9w0BAQsFADA/\n" \
"MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT\n" \
"DkRTVCBSb290IENBIFgzMB4XDTE2MDMxNzE2NDA0NloXDTIxMDMxNzE2NDA0Nlow\n" \
"SjELMAkGA1UEBhMCVVMxFjAUBgNVBAoTDUxldCdzIEVuY3J5cHQxIzAhBgNVBAMT\n" \
"GkxldCdzIEVuY3J5cHQgQXV0aG9yaXR5IFgzMIIBIjANBgkqhkiG9w0BAQEFAAOC\n" \
"AQ8AMIIBCgKCAQEAnNMM8FrlLke3cl03g7NoYzDq1zUmGSXhvb418XCSL7e4S0EF\n" \
"q6meNQhY7LEqxGiHC6PjdeTm86dicbp5gWAf15Gan/PQeGdxyGkOlZHP/uaZ6WA8\n" \
"SMx+yk13EiSdRxta67nsHjcAHJyse6cF6s5K671B5TaYucv9bTyWaN8jKkKQDIZ0\n" \
"Z8h/pZq4UmEUEz9l6YKHy9v6Dlb2honzhT+Xhq+w3Brvaw2VFn3EK6BlspkENnWA\n" \
"a6xK8xuQSXgvopZPKiAlKQTGdMDQMc2PMTiVFrqoM7hD8bEfwzB/onkxEz0tNvjj\n" \
"/PIzark5McWvxI0NHWQWM6r6hCm21AvA2H3DkwIDAQABo4IBfTCCAXkwEgYDVR0T\n" \
"AQH/BAgwBgEB/wIBADAOBgNVHQ8BAf8EBAMCAYYwfwYIKwYBBQUHAQEEczBxMDIG\n" \
"CCsGAQUFBzABhiZodHRwOi8vaXNyZy50cnVzdGlkLm9jc3AuaWRlbnRydXN0LmNv\n" \
"bTA7BggrBgEFBQcwAoYvaHR0cDovL2FwcHMuaWRlbnRydXN0LmNvbS9yb290cy9k\n" \
"c3Ryb290Y2F4My5wN2MwHwYDVR0jBBgwFoAUxKexpHsscfrb4UuQdf/EFWCFiRAw\n" \
"VAYDVR0gBE0wSzAIBgZngQwBAgEwPwYLKwYBBAGC3xMBAQEwMDAuBggrBgEFBQcC\n" \
"ARYiaHR0cDovL2Nwcy5yb290LXgxLmxldHNlbmNyeXB0Lm9yZzA8BgNVHR8ENTAz\n" \
"MDGgL6AthitodHRwOi8vY3JsLmlkZW50cnVzdC5jb20vRFNUUk9PVENBWDNDUkwu\n" \
"Y3JsMB0GA1UdDgQWBBSoSmpjBH3duubRObemRWXv86jsoTANBgkqhkiG9w0BAQsF\n" \
"AAOCAQEA3TPXEfNjWDjdGBX7CVW+dla5cEilaUcne8IkCJLxWh9KEik3JHRRHGJo\n" \
"uM2VcGfl96S8TihRzZvoroed6ti6WqEBmtzw3Wodatg+VyOeph4EYpr/1wXKtx8/\n" \
"wApIvJSwtmVi4MFU5aMqrSDE6ea73Mj2tcMyo5jMd6jmeWUHK8so/joWUoHOUgwu\n" \
"X4Po1QYz+3dszkDqMp4fklxBwXRsW10KXzPMTZ+sOPAveyxindmjkW8lGy+QsRlG\n" \
"PfZ+G6Z6h7mjem0Y+iWlkYcV4PIWL1iwBi8saCbGS5jN2p8M+X+Q7UNKEkROb3N6\n" \
"KOqkqm57TH2H3eDJAkSnh6/DNFu0Qg==\n" \
"-----END CERTIFICATE-----";
static HttpsOTAStatus_t otastatus;
void HttpEvent(HttpEvent_t *event)
switch(event->event_id) {
case HTTP_EVENT_ERROR:
Serial.println("Http Event Error");
break;
case HTTP_EVENT_ON_CONNECTED:
Serial.println("Http Event On Connected");
break;
case HTTP_EVENT_HEADER_SENT:
Serial.println("Http Event Header Sent");
break;
case HTTP_EVENT_ON_HEADER:
Serial.printf("Http Event On Header, key=%s, value=%s\n", event->header_key, event->header_value);
break;
case HTTP_EVENT_ON_DATA:
break;
case HTTP_EVENT_ON_FINISH:
Serial.println("Http Event On Finish");
break;
case HTTP_EVENT_DISCONNECTED:
Serial.println("Http Event Disconnected");
break;
void setup(){
Serial.print("Attempting to connect to SSID: ");
WiFi.begin(ssid, password);
// attempt to connect to Wifi network:
Serial.print(".");
delay(1000);
Serial.print("Connected to ");
Serial.println(ssid);
HttpsOTA.onHttpEvent(HttpEvent);
Serial.println("Starting OTA");
HttpsOTA.begin(url, server_certificate);
Serial.println("Please Wait it takes some time ...");
void loop(){
otastatus = HttpsOTA.status();
if(otastatus == HTTPS_OTA_SUCCESS) {
Serial.println("Firmware written successfully. To reboot device, call API ESP.restart() or PUSH restart button on device");
} else if(otastatus == HTTPS_OTA_FAIL) {
Serial.println("Firmware Upgrade Fail");
delay(1000);
Debug Messages:
Compiling .pio/build/esp32doit-devkit-v1/src/HttpsOTAUpdate.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/lib099/WiFi/WiFiUdp.cpp.o
src/HttpsOTAUpdate.cpp: In member function 'void HttpsOTAUpdateClass::begin(const char*, const char*, bool)':
src/HttpsOTAUpdate.cpp:91:12: error: 'struct esp_http_client_config_t' has no member named 'skip_cert_common_name_check'
config.skip_cert_common_name_check = skip_cert_common_name_check;
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/WMath.cpp.o
*** [.pio/build/esp32doit-devkit-v1/src/HttpsOTAUpdate.cpp.o] Error 1
================================================================== [FAILED] Took 2.77 seconds ==================================================================
The terminal process "platformio 'run'" terminated with exit code: 1.
