c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:26:10: …error: #include expects "FILENAME" or <FILENAME>
#include "soc/rtc_io_reg.h
In file included from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:19,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/hal/include/hal/touch_sensor_types.h:11,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/esp_hw_support/include/esp_sleep.h:12,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/esp32-hal.h:33,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/esp32-hal-timer.h:23,
from c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:23:
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp: In function 'void onTimer()':
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:156:31: error: 'RTC_IO_PAD_DAC1_REG' was not declared in this scope
SET_PERI_REG_BITS(RTC_IO_PAD_DAC1_REG, RTC_IO_PDAC1_DAC, LastDacValue, RTC_IO_PDAC1_DAC_S);
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/esp_common/include/esp_assert.h:29:38: note: in definition of macro 'TRY_STATIC_ASSERT'
if (__builtin_constant_p(CONDITION) && !(CONDITION)) { \
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:96:57: note: in expansion of macro 'IS_DPORT_REG'
#define ASSERT_IF_DPORT_REG(_r, OP) TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:205:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((reg), SET_PERI_REG_BITS); \
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:156:13: note: in expansion of macro 'SET_PERI_REG_BITS'
In file included from c:\users\itadm\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\sys\reent.h:503,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/newlib/platform_include/sys/reent.h:17,
from c:\users\itadm\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\stdio.h:60,
from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/esp32-hal.h:25,
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:96:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:175:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((addr), WRITE_PERI_REG); \
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:206:14: note: in expansion of macro 'WRITE_PERI_REG'
(WRITE_PERI_REG((reg),(READ_PERI_REG(reg)&(~((bit_map)<<(shift))))|(((value) & bit_map)<<(shift)) )); \
In file included from C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/hal/include/hal/touch_sensor_types.h:11,
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:87:34: note: in definition of macro 'ETS_UNCACHED_ADDR'
#define ETS_UNCACHED_ADDR(addr) (addr)
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:156:52: error: 'RTC_IO_PDAC1_DAC' was not declared in this scope
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:176:76: note: in definition of macro 'WRITE_PERI_REG'
(*((volatile uint32_t *)ETS_UNCACHED_ADDR(addr))) = (uint32_t)(val); \
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:156:84: error: 'RTC_IO_PDAC1_DAC_S' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:156:84: note: suggested alternative: 'RTC_RODATA_ATTR'
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:157:31: error: 'RTC_IO_PAD_DAC1_REG' was not declared in this scope
SET_PERI_REG_MASK(RTC_IO_PAD_DAC1_REG, RTC_IO_PDAC1_XPD_DAC | RTC_IO_PDAC1_DAC_XPD_FORCE);
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:187:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((reg), SET_PERI_REG_MASK); \
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:157:13: note: in expansion of macro 'SET_PERI_REG_MASK'
C:\Users\itadm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:188:13: note: in expansion of macro 'WRITE_PERI_REG'
WRITE_PERI_REG((reg), (READ_PERI_REG(reg)|(mask))); \
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:157:52: error: 'RTC_IO_PDAC1_XPD_DAC' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:157:75: error: 'RTC_IO_PDAC1_DAC_XPD_FORCE' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:157:75: note: suggested alternative: 'SENS_SAR1_DAC_XPD_FSM_S'
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:162:31: error: 'RTC_IO_PAD_DAC2_REG' was not declared in this scope
SET_PERI_REG_BITS(RTC_IO_PAD_DAC2_REG, RTC_IO_PDAC2_DAC, LastDacValue, RTC_IO_PDAC2_DAC_S);
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:162:13: note: in expansion of macro 'SET_PERI_REG_BITS'
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:162:52: error: 'RTC_IO_PDAC2_DAC' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:162:84: error: 'RTC_IO_PDAC2_DAC_S' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:162:84: note: suggested alternative: 'RTC_RODATA_ATTR'
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:163:31: error: 'RTC_IO_PAD_DAC2_REG' was not declared in this scope
SET_PERI_REG_MASK(RTC_IO_PAD_DAC2_REG, RTC_IO_PDAC2_XPD_DAC | RTC_IO_PDAC2_DAC_XPD_FORCE);
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:163:13: note: in expansion of macro 'SET_PERI_REG_MASK'
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:163:52: error: 'RTC_IO_PDAC2_XPD_DAC' was not declared in this scope
c:\Users\itadm\Documents\Arduino\libraries\XT_DAC_Audio\XT_DAC_Audio.cpp:163:75: error: 'RTC_IO_PDAC2_DAC_XPD_FORCE' was not declared in this scope
exit status 1
Compilation error: exit status 1
