Hi, I have been trying to compile this code:
And I always get this error:
rtos.h no such file
But, it compiles successfully and the code works. So, why do I get it?
rtos.h no such file
What is in your platformio.ini file. You could be compiling for more than one platform and it’s failing on the one you aren’t using.
Hi, I’m only compiling the code in one platform, my platformio.ini file is:
[env:nucleo_l152re]
platform = ststm32
framework = mbed
board = nucleo_l152re
I have this problem, and it’s a new problem. I.e. I have a project that compiled previously and now doesn’t.
I think that’s because the rtos folder used to be on the include path, and isn’t any more, but including <rtos/rtos.h> doesn’t work because then you get mbed_rtx_conf.h: No such file or directory which is in rtos/rtx5.
That seems to be that in mbed 5, you don’t #include <rtos.h> any more, you just set a build flag in your project:
build_flags = -DPIO_FRAMEWORK_MBED_PRESENT
Then you can use RTOS features.
I didn’t get the build flags quite right above:
[env:nucleo_f411re]
platform = ststm32
framework = mbed
board = nucleo_f411re
upload_port = /media/david/NODE_F411RE
build_flags = -std=gnu++14 -D PIO_FRAMEWORK_MBED_RTOS_PRESENT
Builds, but then fails to link:
/home/david/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/softfp/crt0.o: In function _start': (.text+0x4a): undefined reference to
__wrap_main’
.pioenvs/nucleo_f411re/FrameworkMbedCore/drivers/Serial.o: In function mbed::Serial::lock()': Serial.cpp:(.text._ZN4mbed6Serial4lockEv+0x6): undefined reference to
rtos::Mutex::lock(unsigned long)’
.pioenvs/nucleo_f411re/FrameworkMbedCore/drivers/Serial.o: In function mbed::Serial::unlock()': Serial.cpp:(.text._ZN4mbed6Serial6unlockEv+0x2): undefined reference to
rtos::Mutex::unlock()’
.pioenvs/nucleo_f411re/FrameworkMbedCore/drivers/Serial.o: In function mbed::Serial::Serial(PinName, PinName, int)': Serial.cpp:(.text._ZN4mbed6SerialC2E7PinNameS1_i+0x2c): undefined reference to
rtos::Mutex::Mutex()’
.pioenvs/nucleo_f411re/FrameworkMbedCore/drivers/Serial.o: In function mbed::Serial::~Serial()': Serial.cpp:(.text._ZN4mbed6SerialD2Ev[_ZN4mbed6SerialD5Ev]+0x1c): undefined reference to
rtos::Mutex::~Mutex()’
.pioenvs/nucleo_f411re/FrameworkMbedCore/platform/FileBase.o: In function SingletonPtr<rtos::Mutex>::get()': FileBase.cpp:(.text._ZN12SingletonPtrIN4rtos5MutexEE3getEv[_ZN12SingletonPtrIN4rtos5MutexEE3getEv]+0x10): undefined reference to
osMutexAcquire’
FileBase.cpp:(.text._ZN12SingletonPtrIN4rtos5MutexEE3getEv[_ZN12SingletonPtrIN4rtos5MutexEE3getEv]+0x1e): undefined reference to rtos::Mutex::Mutex()' FileBase.cpp:(.text._ZN12SingletonPtrIN4rtos5MutexEE3getEv[_ZN12SingletonPtrIN4rtos5MutexEE3getEv]+0x26): undefined reference to
osMutexRelease’
FileBase.cpp:(.text._ZN12SingletonPtrIN4rtos5MutexEE3getEv[_ZN12SingletonPtrIN4rtos5MutexEE3getEv]+0x30): undefined reference to singleton_mutex_id' .pioenvs/nucleo_f411re/FrameworkMbedCore/platform/FileBase.o: In function
mbed::FileBase::FileBase(char const*, mbed::PathType)’:
FileBase.cpp:(.text._ZN4mbed8FileBaseC2EPKcNS_8PathTypeE+0x1c): undefined reference to rtos::Mutex::lock(unsigned long)' FileBase.cpp:(.text._ZN4mbed8FileBaseC2EPKcNS_8PathTypeE+0x30): undefined reference to
.pioenvs/nucleo_f411re/FrameworkMbedCore/platform/FileBase.o: In function mbed::FileBase::~FileBase()': FileBase.cpp:(.text._ZN4mbed8FileBaseD2Ev+0x12): undefined reference to
rtos::Mutex::lock(unsigned long)‘
FileBase.cpp:(.text._ZN4mbed8FileBaseD2Ev+0x2c): undefined reference to rtos::Mutex::unlock()' .pioenvs/nucleo_f411re/FrameworkMbedCore/platform/FileBase.o: In function
mbed::FileBase::lookup(char const*, unsigned int)’:
FileBase.cpp:(.text._ZN4mbed8FileBase6lookupEPKcj+0x10): undefined reference to rtos::Mutex::lock(unsigned long)' FileBase.cpp:(.text._ZN4mbed8FileBase6lookupEPKcj+0x38): undefined reference to
.pioenvs/nucleo_f411re/FrameworkMbedCore/platform/mbed_retarget.o: In function mbed::remove_filehandle(mbed::FileHandle*)': mbed_retarget.cpp:(.text._ZN4mbed17remove_filehandleEPNS_10FileHandleE+0xe): undefined reference to
mbed_retarget.cpp:(.text._ZN4mbed17remove_filehandleEPNS_10FileHandleE+0x34): undefined reference to rtos::Mutex::unlock()' .pioenvs/nucleo_f411re/FrameworkMbedCore/platform/mbed_retarget.o: In function
_open’:
mbed_retarget.cpp:(.text._open+0x4e): undefined reference to rtos::Mutex::lock(unsigned long)' mbed_retarget.cpp:(.text._open+0x72): undefined reference to
rtos::Mutex::unlock()‘
mbed_retarget.cpp:(.text._open+0xf2): undefined reference to rtos::Mutex::unlock()' .pioenvs/nucleo_f411re/FrameworkMbedCore/platform/mbed_wait_api_rtos.o: In function
wait_us’:
mbed_wait_api_rtos.cpp:(.text.wait_us+0x2a): undefined reference to rtos::Thread::wait(unsigned long)' .pioenvs/nucleo_f411re/src/main.o: In function
slip::SlipOutput::~SlipOutput()’:
main.cpp:(.text._ZN4slip10SlipOutputD2Ev[_ZN4slip10SlipOutputD5Ev]+0xa): undefined reference to rtos::Mutex::~Mutex()' .pioenvs/nucleo_f411re/src/main.o: In function
Servos<4u>::moveStep()’:
main.cpp:(.text._ZN6ServosILj4EE8moveStepEv[_ZN6ServosILj4EE8moveStepEv]+0x48): undefined reference to rtos::Thread::signal_set(long)' .pioenvs/nucleo_f411re/src/main.o: In function
Servos<4u>::statusSender()’:
main.cpp:(.text._ZN6ServosILj4EE12statusSenderEv[_ZN6ServosILj4EE12statusSenderEv]+0x14): undefined reference to rtos::Thread::signal_wait(long, unsigned long)' .pioenvs/nucleo_f411re/src/main.o: In function
Servos<4u>::~Servos()’:
main.cpp:(.text._ZN6ServosILj4EED2Ev[_ZN6ServosILj4EED5Ev]+0x6): undefined reference to rtos::Thread::~Thread()' .pioenvs/nucleo_f411re/src/main.o: In function
_GLOBAL__sub_I_serial’:
main.cpp:(.text.startup._GLOBAL__sub_I_serial+0x58): undefined reference to rtos::Mutex::Mutex()' main.cpp:(.text.startup._GLOBAL__sub_I_serial+0xde): undefined reference to
rtos::Semaphore::Semaphore(long)‘
main.cpp:(.text.startup._GLOBAL__sub_I_serial+0xe6): undefined reference to rtos::Mutex::Mutex()' main.cpp:(.text.startup._GLOBAL__sub_I_serial+0xf8): undefined reference to
rtos::Thread::constructor(osPriority_t, unsigned long, unsigned char*, char const*)‘
main.cpp:(.text.startup._GLOBAL__sub_I_serial+0x132): undefined reference to rtos::Thread::start(mbed::Callback<void ()>)' main.cpp:(.text.startup._GLOBAL__sub_I_serial+0x1c8): undefined reference to
vtable for rtos::Thread’
.pioenvs/nucleo_f411re/lib/libcanonical-sexps.a(SlipOutput.o): In function slip::SlipOutput::begin()': SlipOutput.cpp:(.text._ZN4slip10SlipOutput5beginEv+0xa): undefined reference to
.pioenvs/nucleo_f411re/lib/libcanonical-sexps.a(SlipOutput.o): In function slip::SlipOutput::end()': SlipOutput.cpp:(.text._ZN4slip10SlipOutput3endEv+0x12): undefined reference to
I’m having the exact same issue as @davidji. It builds, but gives errors on linking.
Are there any updates on this?
Could you share a test source code to reproduce this issue?
You need to make sure that the build_flags is correct, according to the guide, (mbed configuration)
That means using the following build_flags as appropriate:
-D PIO_FRAMEWORK_MBED_EVENTS_PRESENT
-D PIO_FRAMEWORK_MBED_FILESYSTEM_PRESENT
AND…
you still need to #include "rtos.h"
, otherwise, the dependency finder will not include the RTOS lib. Normally, mbed does not make you explicitly declare rtos.h, bit PlatformIO extracts it as a separate library behind the scenes, so you need to declare it.
If you do it right, you should get output in the console that shows mbed-rtos in the Library Dependency Graph
