hey pls help me when i wanna run my Python Code i get that error: Error: Please setup environments in platformio.ini
file
i dont know what i should doing? can someone say it pls
file
What is your platformio.ini
do you mean what is in platformio.ini
; Redirecting...
Where are you deploying the code? Are you using the PlatformIO IDE ? If you are having trouble configuring your platformio.ini
it could be an idea to use the IDE to select the platform you are developing for:
http://docs.platformio.org/en/latest/ide/atom.html#setting-up-the-project
But I’m not sure what you’re trying to do, so
