Error opening PlatformIO - Open
Hello there,
mby you can help me with this issue: I can not Open PIO
My Console shows this error :
console.ts:139 [Extension Host] runCommand C:\Users\pthee\.platformio\penv\Scripts\python.exe Array(14) Object
index.html?id=9f0a0e5f-5fc4-4537-91e2-a68b1c7ea3d2&parentId=1&origin=8e4f10a1-412e-4d3c-9d7c-9a6720865b36&swVersion=4&extensionId=platformio.platformio-ide&platform=electron&vscode-resource-base-authority=vscode-resource.vscode-cdn.net&parentOrigin=vscode-file%3A%2F%2Fvscode-app:1060 Unrecognized feature: 'local-network-access'.
(anonymous) @ index.html?id=9f0a0e5f-5fc4-4537-91e2-a68b1c7ea3d2&parentId=1&origin=8e4f10a1-412e-4d3c-9d7c-9a6720865b36&swVersion=4&extensionId=platformio.platformio-ide&platform=electron&vscode-resource-base-authority=vscode-resource.vscode-cdn.net&parentOrigin=vscode-file%3A%2F%2Fvscode-app:1060
console.ts:139 [Extension Host] Error: Could not start PIO Home server: Timeout error
	at Timeout._onTimeout (c:\Users\pthee\.vscode\extensions\platformio.platformio-ide-3.3.4-win32-x64\node_modules\platformio-node-helpers\dist\index.js:1:10741)
	at listOnTimeout (node:internal/timers:588:17)
	at process.processTimers (node:internal/timers:523:7)
yks @ console.ts:139
$logExtensionHostMessage @ mainThreadConsole.ts:39
S @ rpcProtocol.ts:458
Q @ rpcProtocol.ts:443
M @ rpcProtocol.ts:373
L @ rpcProtocol.ts:299
(anonymous) @ rpcProtocol.ts:161
C @ event.ts:1202
fire @ event.ts:1233
fire @ ipc.net.ts:652
l.onmessage @ localProcessExtensionHost.ts:383
console.ts:139 [Extension Host] runCommand C:\Users\pthee\.platformio\penv\Scripts\python.exe (14) ['-m', 'platformio', '-c', 'vscode', 'home', '--port', 45230, '--host', '127.0.0.1', '--session-id', '77bdb2a680f4f0792ed8d0d315228cb3e6eefdd2', '--shutdown-timeout', 3600, '--no-open'] {_id: 'C:\\Users\\pthee\\.platformio\\penv\\Scripts\\python.exe-0.05342792114510697'}
C @ event.ts:1202
notificationsAlerts.ts:42 Error: Could not start PIO Home server: Timeout error 	at Timeout._onTimeout (c:\Users\pthee\.vscode\extensions\platformio.platformio-ide-3.3.4-win32-x64\node_modules\platformio-node-helpers\dist\index.js:1:10741) 	at listOnTimeout (node:internal/timers:588:17) 	at process.processTimers (node:internal/timers:523:7)...
c @ notificationsAlerts.ts:42
(anonymous) @ notificationsAlerts.ts:28
C @ event.ts:1202
D @ event.ts:1213
fire @ event.ts:1237
addNotification @ notifications.ts:228
notify @ notificationService.ts:234
(anonymous) @ mainThreadMessageService.ts:93
g @ mainThreadMessageService.ts:56
$showMessage @ mainThreadMessageService.ts:50
C @ event.ts:1202
Perhaps one of you knows how I can fix this problem.
Thank you very much and have peaceful holidays.
Can you still launch the CLI? If yes, post the output of pio system info here, then pio home.
If the CLI is not launchable, search your home folder (Windows: C:\Users\<user>\.platformio for penv\Scripts\pio.exe, then launch a regular terminal, and use the full path to pio.exe instead of pio for the previous commands.
Hello and happy new year!
I can click on Platform IO Core CLI … but everything else it try to start PIO Home , Loading… and I get the error i posed last year.
When i open the pio.exe : It open and close short time after.
Solution:
If you are working in an enterprise environment with a corporate SSL inspection proxy
(Zscaler, McAfee, etc.) and PIO Home hangs or shows a blank screen / HTTPClientError inside
VS Code, follow these steps:
  1. Disable strict SSL verification in PIO Core:
    Run this command in your terminal / PowerShell:
platformio settings set enable_proxy_strict_ssl false
  1. Set explicit Host & Port in VS Code settings.json:
    Add the following settings to your VS Code User settings.json:
"platformio-ide.pioHomeServerHttpHost": "localhost",
"platformio-ide.pioHomeServerHttpPort": 8008
  1. Add environment variables to bypass local loopback proxying:
    Add NO_PROXY=127.0.0.1,localhost,::1 and PLATFORMIO_NO_SSL_VERIFY=1 to your environment
    variables.
  2. Ensure manually extracted packages contain .piopm:
    If you manually downloaded/extracted packages (like contrib-piohome) to bypass proxy blocks
    in .platformio/packages/, ensure a .piopm file is present inside the package directory,
    otherwise PIO Core will endlessly attempt to re-download it via proxy.
After restarting VS Code, PIO Home loads cleanly inside the embedded VS Code tab!
