Hey guys, new to Platform IO.
Trying to compile Marlin 2.0 and upload to an MKS Robin Lite v1.1. Using a Mac, current version, compiling within Visual Studio Code. Using PIO I can see the board, so USB connectivity is working, or at least its physically connected properly. Below is partial results from the Terminal.
For bug reports, read
debug_level: 1
hla_swd
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
Also, here’s what I think is the important stuff from platformio.ini:
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = mks_robin_lite
[common]
default_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
extra_scripts = pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
build_flags = -fmax-errors=5 -g -D__MARLIN_FIRMWARE__ -fmerge-all-constants
U8glib-HAL=https://github.com/MarlinFirmware/U8glib-HAL/archive/bugfix.zip
LiquidCrystal@1.3.4
TMCStepper@>=0.5.2,<1.0.0
Adafruit NeoPixel@1.2.5
Adafruit_MAX31865=https://github.com/adafruit/Adafruit_MAX31865/archive/master.zip
LiquidTWI2=https://github.com/lincomatic/LiquidTWI2/archive/master.zip
Arduino-L6470=https://github.com/ameyer/Arduino-L6470/archive/dev.zip
SailfishLCD=https://github.com/mikeshub/SailfishLCD/archive/master.zip
SailfishRGB_LED=https://github.com/mikeshub/SailfishRGB_LED/archive/master.zip
SlowSoftI2CMaster=https://github.com/mikeshub/SlowSoftI2CMaster/archive/master.zip
# Globally defined properties
# inherited by all environments
[env]
build_flags = ${common.build_flags}
lib_deps = ${common.lib_deps}
Any assistance you can provide would be greatly appreciated. Thank you.
