Hello everybody,
i am having an error with xtensa. Can anyone tell me what it could be?
PlatformIO already officially supports 2.0.3. Does the same error happen when using platform = espressif32?
Is your ESP32 platform up-to-date? Please use CLI and pio platform update espressif32.
Utente@PC-Fabio ~/D/P/P/a/abiot-gateway (master)> pio platform update espressif32
WARNING: This command is deprecated and will be removed in the next releases.
Please use pio pkg update instead.
Platform Manager: espressif32@4.4.0 is already up-to-date
Tool Manager: framework-arduinoespressif32@3.20003.220619 is already up-to-date
Tool Manager: tool-esptoolpy@1.30300.0 is already up-to-date
Tool Manager: tool-mklittlefs@1.203.210628 is already up-to-date
Tool Manager: tool-mkspiffs@2.230.0 is already up-to-date
Tool Manager: toolchain-esp32s2ulp@1.22851.191205 is already up-to-date
Tool Manager: toolchain-riscv32-esp@8.4.0+2021r2-patch3 is already up-to-date
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch3 is already up-to-date
Tool Manager: toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3 is already up-to-date
This error comes from the package itself and just including Arduino.h, that’s not good. Please remove the folder C:\Users\<user>\.platformio\packages\framework-arduinoespressif32 and try building again.
The first one would be sufficient.
I deleted the folder, and I also deleted the “.pio” folder and then compiled. But it gives me another mistake:
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\main.cpp.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\abiot-gateway-arduinoesp32\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\abiot-gateway-arduinoesp32\libFrameworkArduino.a
Linking .pio\build\abiot-gateway-arduinoesp32\firmware.elf
c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/…/lib/gcc/xtensa-esp32s2-elf/8.4.0/…/…/…/…/xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o:(.literal._ZN18CommunicationAbiot11initModemTXEv+0x14): undefined reference to LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)' c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o: in function CommunicationAbiot::initModemTX()’:
C:\Users\Utente\Documents\PlatformIO\Projects\abiot\abiot-gateway/src/lora/CommunicationAbiot.cpp:321: undefined reference to LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)' c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o: in function CommunicationAbiot::initModemRX()’:
C:\Users\Utente\Documents\PlatformIO\Projects\abiot\abiot-gateway/src/lora/CommunicationAbiot.cpp:343: undefined reference to `LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)’
*** [.pio\build\abiot-gateway-arduinoesp32\firmware.elf] Error 1
============================================================================================================== [FAILED] Took 363.63 seconds ==============================================================================================================
Il processo del terminale “C:\Users\Utente.platformio\penv\Scripts\platformio.exe ‘run’” è stato terminato. Codice di uscita: 1.
Terminale verrà riutilizzato dalle attività, premere un tasto qualsiasi per chiuderlo.
Is the library that supplise this object / class still in the dependency graph?
I seem to see it
|-- PubSubClient @ 2.8.0
|-- TinyGSM @ 0.11.5
|-- EspSoftwareSerial @ 6.16.1
|-- RTClib @ 1.14.2
| |-- Wire @ 2.0.0
|-- Regexp @ 0.1.0
|-- ArduinoJson @ 6.19.4
|-- Ethernet @ 2.0.0
| |-- SPI @ 2.0.0
|-- SSLClient @ 1.6.11
|-- AsyncElegantOTA @ 2.2.7
| |-- AsyncTCP-esphome @ 1.2.2
| |-- ESPAsyncWebServer-esphome @ 2.1.0
| | |-- FS @ 2.0.0
| | |-- WiFi @ 2.0.0
| |-- FS @ 2.0.0
| |-- Update @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- FS @ 2.0.0
| |-- WiFi @ 2.0.0
|-- EByte LoRa E220 library @ 1.0.3
|-- WiFi @ 2.0.0
|-- SPI @ 2.0.0
|-- WiFiClientSecure @ 2.0.0
| |-- WiFi @ 2.0.0
The library only enables the software serial constructors if you activate a macro.
Use
build_flags = -DACTIVATE_SOFTWARE_SERIAL -DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_DEBUG
in the platformio.ini.
I used
[env:esp32-s2-saola-1]
board = esp32-s2-saola-1
plerup/EspSoftwareSerial@^6.13.2
xreef/EByte LoRa E220 library@^1.0.3
to v erify this.
On the other hand I could argue that since the ESP32 can create a hardware serial on any pins anyway, you should use those constructors
with e.g. the Serial1 object that you still have on the SoC. Hardware-based serial should be better than software-based serial, unless you really need that hardware serial for something else.
Unfortunately I use the two serial ports already present to communicate with SIMCOM GSM and with Ethernet Shield.
So how can I solve my problem using serial software?
I was using this construction
where 4 means IO4 pin etc.
Just uncomment this and adapt pins. (Needs -DACTIVATE_SOFTWARE_SERIAL)
Uhm ![]()
c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o:(.literal._ZN18CommunicationAbiot11initModemTXEv+0x14): undefined reference to `LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)'
c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o: in function `CommunicationAbiot::initModemTX()':
C:\Users\Utente\Documents\PlatformIO\Projects\abiot\abiot-gateway/src/lora/CommunicationAbiot.cpp:321: undefined reference to `LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)'
c:/users/utente/.platformio/packages/toolchain-xtensa-esp32s2@8.4.0+2021r2-patch3/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: .pio/build/abiot-gateway-arduinoesp32/src/lora/CommunicationAbiot.cpp.o: in function `CommunicationAbiot::initModemRX()':
C:\Users\Utente\Documents\PlatformIO\Projects\abiot\abiot-gateway/src/lora/CommunicationAbiot.cpp:343: undefined reference to `LoRa_E220::LoRa_E220(SoftwareSerial*, unsigned char, unsigned char, unsigned char, UART_BPS_RATE)'
My Platformio.io:
[env:abiot-gateway-arduinoesp32]
#platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip
platform: espressif32
knolleary/PubSubClient@^2.8
vshymanskyy/TinyGSM@^0.11.4
adafruit/RTClib@^1.14.1
nickgammon/Regexp@^0.1.0
bblanchon/ArduinoJson@^6.18.5
arduino-libraries/Ethernet@^2.0.0
openslab-osu/SSLClient@^1.6.11
ayushsharma82/AsyncElegantOTA@^2.2.6
ottowinter/ESPAsyncWebServer-esphome@^2.1.0
# EByte-LoRa
upload_port = COM11
monitor_port = COM11
build_flags = -DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_DEBUG
Can you show your current full platformio.ini?
What code is at /src/lora/CommunicationAbiot.cpp:321?
This appears double? The need to be either on the same line or separated by newlines with at least two spaces at the front.
Can you use
# EByte-LoRa
upload_port = COM11
and recheck?
Good man!
Retrieving maximum program size .pio\build\abiot-gateway-arduinoesp32\firmware.elf
Checking size .pio\build\abiot-gateway-arduinoesp32\firmware.elf
RAM: [== ] 15.0% (used 49260 bytes from 327680 bytes)
Flash: [======= ] 66.6% (used 873498 bytes from 1310720 bytes)
Building .pio\build\abiot-gateway-arduinoesp32\firmware.bin
esptool.py v3.3
Creating esp32s2 image...
Merged 2 ELF sections
Successfully created esp32s2 image.
Thanks a lot!
