Oh you are right about the github link, my bad.
Yes that’s really interesting. The discussion at http://stm32duino.com/viewtopic.php?f=41&t=2434&start=80#p33786 outlines the way that problem was apparently solved. In the first solution they added -u
flags to the linker (docs) to force inclusion, but that didn’t work for me. I tried doing this in my platformio.ini
build_flags = -Wl,--unresolved-symbols=report-all -Wl,--start-group -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid -Wl,--end-group
but the build process failed early on when libFrameworkArduino.a
was created without the libFrameworkArduinoVariant.a
being present first?
arm-none-eabi-ar rc .pioenvs\bluepill_f103c8\libFrameworkArduino.a .pioenvs\bluepill_f103c8\FrameworkArduino\HardwareSerial.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\HardwareTimer.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\IPAddress.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\Print.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\Stream.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\WString.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\avr\dtostrf.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\cxxabi-compat.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\ext_interrupts.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\hooks.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\itoa.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\adc.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\adc_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\bkp_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\dac.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\dma.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\dma_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\exc.S.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\exti.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\exti_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\flash.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\fsmc_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\gpio.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\gpio_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\i2c_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\iwdg.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\nvic.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\pwr.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\rcc.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\rcc_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\spi.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\spi_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\stm32f1\performance\isrs.S.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\stm32f1\performance\vector_table.S.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\systick.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\timer.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\timer_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usart.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usart_f1.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usart_private.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\stm32f1\usb.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\stm32f1\usb_cdcacm.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\stm32f1\usb_reg_map.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\usb_lib\usb_core.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\usb_lib\usb_init.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\usb_lib\usb_mem.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\usb\usb_lib\usb_regs.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\libmaple\util.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\main.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\new.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\pwm.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\sdio.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\stm32f1\util_hooks.c.o .pioenvs\bluepill_f103c8\FrameworkArduino\stm32f1\wiring_pulse_f1.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\stm32f1\wirish_debug.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\stm32f1\wirish_digital_f1.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\tone.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\usb_serial.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\wirish_analog.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\wirish_digital.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\wirish_math.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\wirish_shift.cpp.o .pioenvs\bluepill_f103c8\FrameworkArduino\wirish_time.cpp.o
arm-none-eabi-ranlib .pioenvs\bluepill_f103c8\libFrameworkArduino.a
*** [.pioenvs\bluepill_f103c8\firmware.elf] Implicit dependency `C:\Users\Maxi\.platformio\platforms\ststm32\builder\_sbrk' not found, needed by target `.pioenvs\bluepill_f103c8\firmware.elf'.
[ERROR] Took 6.88 seconds
I then tried the other way (their second solution) to include the compiled syscall object file to the linker using the absolute path of that file which was compiled in a previous run:
build_flags = -Wl,--start-group "C:\Users\Maxi\Documents\bluepill_mbed\.pioenvs\bluepill_f103c8\FrameworkArduinoVariant\wirish\syscalls.c.o" -Wl,--end-group
With that, it builds.
arm-none-eabi-g++ -o .pioenvs\bluepill_f103c8\firmware.elf -Os -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m3 -Wl,--start-group -Wl,--end-group -Wl,-T"jtag_c8.ld" .pioenvs\bluepill_f103c8\src\main.cpp.o -LC:\Users\Maxi\.platformio\platforms\ststm32\ldscripts -LC:\Users\Maxi\.platformio\packages\framework-arduinoststm32\STM32F1\variants\generic_stm32f103c\ld -L.pioenvs\bluepill_f103c8 -Wl,--start-group .pioenvs\bluepill_f103c8\libFrameworkArduinoVariant.a .pioenvs\bluepill_f103c8\libFrameworkArduino.a -lgcc -lm .pioenvs\bluepill_f103c8\FrameworkArduinoVariant\wirish\syscalls.c.o -Wl,--end-group
arm-none-eabi-size -B -d .pioenvs\bluepill_f103c8\firmware.elf
arm-none-eabi-objcopy -O binary .pioenvs\bluepill_f103c8\firmware.elf .pioenvs\bluepill_f103c8\firmware.bin
text data bss dec hex filename
14596 3200 1288 19084 4a8c .pioenvs\bluepill_f103c8\firmware.elf
[SUCCESS] Took 6.72 seconds
At least there’s an ugly solution. Let’s see what @ivankravets thinks about that, as it seems that PIOs build system needs to add some special linker flags for it.
Really makes we wonder how noone every noticed that error before. Without _sbrk
there’s also no malloc
or any new
operator working. Funny.
