Windows 7 x64 Pro, user name is cyrillic.
All software packages are up to date (10 Apr 2017)
Virtualenv Download: Traceback (most recent call last):
File "C:\Users\73B5~1\AppData\Local\Temp\tmp-3132Pa6EwBBLx4V3\virtualenv-15.1.0\virtualenv.py", line 2328, in <module>
main()
File "C:\Users\73B5~1\AppData\Local\Temp\tmp-3132Pa6EwBBLx4V3\virtualenv-15.1.0\virtualenv.py", line 713, in main
symlink=options.symlink)
File "C:\Users\73B5~1\AppData\Local\Temp\tmp-3132Pa6EwBBLx4V3\virtualenv-15.1.0\virtualenv.py", line 925, in create_environment
site_packages=site_packages, clear=clear, symlink=symlink))
File "C:\Users\73B5~1\AppData\Local\Temp\tmp-3132Pa6EwBBLx4V3\virtualenv-15.1.0\virtualenv.py", line 1148, in install_python
writefile(join(site_dir, 'orig-prefix.txt'), prefix)
File "C:\Users\73B5~1\AppData\Local\Temp\tmp-3132Pa6EwBBLx4V3\virtualenv-15.1.0\virtualenv.py", line 368, in writefile
if c != content.encode("utf-8"):
UnicodeDecodeError: 'ascii' codec can't decode byte 0xcf in position 9: ordinal not in range(128)
C:\Users\Пользователь>set | find "Поль"
APPDATA=C:\Users\Пользователь\AppData\Roaming
HOMEPATH=\Users\Пользователь
LOCALAPPDATA=C:\Users\Пользователь\AppData\Local
USERNAME=Пользователь
USERPROFILE=C:\Users\Пользователь
Does any workaround exist?
