I have just installed PlatformIO trying to use this software instead of INO.
Though, when I run the command: platformio device list I get the following output:
_Usage: platformio [OPTIONS] COMMAND [ARGS]..._
_Error: No such command "device"_
My platformio version is: 3.3.0a7
Has someone had similar problems?
Thank you.
              How did you install PIO? what do you see with pio --version?
              It was installed by following this tutorial:
http://docs.platformio.org/en/latest/installation.html#python-package-manager
- use:
pip install -U platformio
- then
python -c "$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/master/scripts/get-platformio.py)"
This is the result of the command pio --version:
pi@raspberrypi /home/platformio/temp-humid $ pio --version
PlatformIO, version 3.3.0a7
              I can’t reproduce this issue. Could you try?
pip uninstall platformio
              I have uninstalled and installed with the commands provided, though when I ran again: **pio device list** I got the same No such command “device”  error.
Note: I had to use sudo for those commands as without it I got “Permission denied errors”.
Note: The version was changed: from 3.3.0a7 (initially) to 3.2.1 (current version).
              Please DON’T USE sudo. Try sudo rm -r ~/.platformio and run pio device list without sudo
              Used:
and after
pio device list (without sudo)
but still same error.
Should I have also uninstalled and reinstalled pio?
[Update] : I have also reinstalled pio after that but still no success
              What is your Python? python --version?
              Python:
pi@raspberrypi ~ $ python --version
Python 2.7.3
              Has anyone solved this problem. I just updated to Platformio 2.0 on a Mac and am getting this same error when trying to open a serial port.
