I am facing problems while trying to compile code for the board esp-wroom-02 (using language C). I am using vs code+platformIO. I used one of the examples of platfrmIO(exactly the empty project example). Below the log:
> Executing task: pio run <
## Processing esp_wroom_02 (platform: espressif8266; board: esp_wroom_02; framework: esp8266-rtos-sdk)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp_wroom_02.html
PLATFORM: Espressif 8266 (2.6.3) > ESP-WROOM-02
HARDWARE: ESP8266 80MHz, 80KB RAM, 2MB Flash
* framework-esp8266-rtos-sdk 1.5.0-beta.5
* tool-esptool 1.413.0 (4.13)
* tool-esptoolpy 1.30000.201119 (3.0.0)
* toolchain-xtensa 1.40802.0 (4.8.2)
Found 2 compatible libraries
Compiling .pio/build/esp_wroom_02/src/main.o
Compiling .pio/build/esp_wroom_02/libe0e/example1/example1.o
Compiling .pio/build/esp_wroom_02/libc56/example2/example2.o
Compiling /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/driver/driver/gpio.o
Compiling /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/driver/driver/hw_timer.o
Compiling /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/driver/driver/i2c_master.o
Compiling /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/driver/driver/spi_interface.o
Compiling /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/driver/driver/uart.o
Archiving /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libdriver.a
Archiving .pio/build/esp_wroom_02/libc56/libexample2.a
Indexing /home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libdriver.a
Archiving .pio/build/esp_wroom_02/libe0e/libexample1.a
Indexing .pio/build/esp_wroom_02/libc56/libexample2.a
Indexing .pio/build/esp_wroom_02/libe0e/libexample1.a
Linking .pio/build/esp_wroom_02/firmware.elf
/home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libmain.a(app_main.o): In function `user_uart_wait_tx_fifo_empty': (.irom0.text+0x388): undefined reference to `user_init'
/home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libmain.a(app_main.o): In function `user_uart_wait_tx_fifo_empty': (.irom0.text+0x39f): undefined reference to `user_init'
/home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libmain.a(app_main.o): In function `user_init_task': (.irom0.text+0x4fc): undefined reference to `user_rf_cal_sector_set'
/home/benedito/.platformio/packages/framework-esp8266-rtos-sdk/lib/libmain.a(app_main.o): In function `flash_data_check': (.irom0.text+0x644): undefined reference to `user_rf_cal_sector_set'
*** [.pio/build/esp_wroom_02/firmware.elf] Error 1
============================================================ [FAILED] Took 4.03 seconds ============================================================
The terminal process "pio 'run'" terminated with exit code: 1.
Well it musn’t be completely empty, the RTOS SDK does need some user implementations. It needs the user_init and user_rf_cal_sector_set functions.
You should start from platform-espressif8266/examples/esp8266-rtos-sdk-blink/src/main.c at develop · platformio/platform-espressif8266 · GitHub.
Note that the RTOS-SDK version that PlatformIO uses is extremely outdated. That is logged in Update ESP8266_RTOS_SDK v1.4.0 to ESP8266_RTOS_SDK v3.x.x · Issue #219 · platformio/platform-espressif8266 · GitHub.
thanks for the tip @maxgerhardt , I’m going to see it
that is, do I need just to realize these functions in may main.c file?
Yes, these two functions at least must be implemented / copied.
Note that user_init is the main entry point of the firmware, all your logic needs to go here. As seen in the example above, the function just creates a FreeRTOS task and then in that task’s code, the actual work is done. Thus I recommend to start out with that example first by fully copying it.
am I obliged to work with RTOS? Iam sure I needn’d it for my current project …
Well there is also a Non-OS (no RTOS) SDK version. platform-espressif8266/examples/esp8266-nonos-sdk-blink at develop · platformio/platform-espressif8266 · GitHub
When working with the RTOS-SDK you should be at least creating your main task in which you do all your work. If you block forever in user_init() the SDK is stuck before it can call the start function of the FreeRTOS task scheduler, so none of the FreeRTOS functions will work…
Also, the Arduino-ESP8266 core doesn’t contain an RTOS and you can program it in C++ and C (preferred C++ though if you want to use any of the core’s functionality).
The code for RTOS works now !
Now in my project settings I changed to esp8266-nonos-sdk framework to take out the RTOS, but arised error: user_config.h: No such file or directory . There are three modules that calls this file : key.o , sdio_slv.o and spi.o . Can I somewhere create this file?
good! the code works!
I didn’t pay attention to your link before, sorry. There is everything there. Thanks so much
now I am trying to change the example, to put there my board, platform and framework . But once again error: Error: Detected a whitespace character in project paths . But I don’t have spaces neither in the file name nor in user name.
Environment Status Duration
nodemcuv2 SUCCESS 00:00:00.940
esp12e FAILED 00:00:00.344
The one that I changed fails.
What’s your full platformio.ini and code?
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
framework = esp8266-nonos-sdk
build_flags = -I include
monitor_speed = 74880
[env:esp12e]
framework = espidf
in main I didn’t touch anything yet:
#include "osapi.h"
#include "user_interface.h"
static os_timer_t ptimer;
* FunctionName : user_rf_cal_sector_set
* Description : SDK just reversed 4 sectors, used for rf init data and paramters.
* We add this function to force users to set rf cal sector, since
* we don't know which sector is free in user's application.
* sector map for last several sectors : ABBBCDDD
* A : rf cal
* B : at parameters
* C : rf init data
* D : sdk parameters
* Parameters : none
* Returns : rf cal sector
uint32 ICACHE_FLASH_ATTR
user_rf_cal_sector_set(void)
enum flash_size_map size_map = system_get_flash_size_map();
uint32 rf_cal_sec = 0;
switch (size_map) {
case FLASH_SIZE_4M_MAP_256_256:
rf_cal_sec = 128 - 5;
break;
case FLASH_SIZE_8M_MAP_512_512:
rf_cal_sec = 256 - 5;
break;
case FLASH_SIZE_16M_MAP_512_512:
case FLASH_SIZE_16M_MAP_1024_1024:
rf_cal_sec = 512 - 5;
break;
case FLASH_SIZE_32M_MAP_512_512:
case FLASH_SIZE_32M_MAP_1024_1024:
rf_cal_sec = 1024 - 5;
break;
case FLASH_SIZE_64M_MAP_1024_1024:
rf_cal_sec = 2048 - 5;
break;
case FLASH_SIZE_128M_MAP_1024_1024:
rf_cal_sec = 4096 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
void blinky(void *arg)
static uint8_t state = 0;
if (state) {
GPIO_OUTPUT_SET(2, 1);
} else {
GPIO_OUTPUT_SET(2, 0);
state ^= 1;
void ICACHE_FLASH_ATTR user_init(void)
gpio_init();
uart_init(115200, 115200);
os_printf("SDK version:%s\n", system_get_sdk_version());
// Disable WiFi
wifi_set_opmode(NULL_MODE);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2);
os_timer_disarm(&ptimer);
os_timer_setfn(&ptimer, (os_timer_func_t *)blinky, NULL);
os_timer_arm(&ptimer, 2000, 1);
The environment that is failing is the ESP32 environment (that you’ve called esp12e confusingly, which is ESP8266 chip instead of a ESP32 chip).
Code for esp8266-nonos-sdk and ESP-IDF are not compatible with each other. You have to create different projects are use a src_filter to ignore the file meant for the other framework.
ESP-IDF projects need a few more files to be compiliable – mainly two CMakeLists.txt files in the root and src/ folder of the project.
I’d suggest you create a new blank project for the ESP32 Dev kit (esp32dev) with the ESP-IDF selected and then copy all the files from the example code at https://github.com/platformio/platform-espressif32/tree/develop/examples/espidf-blink in the project. Then you can try and build the firmware and upload it to your ESP32 development board.
After that you can use src_filter in your original project if you are really sure that you want to have ESP8266 and ESP32 code in the same project, for different frameworks.
Can you help me with this problem
Linking .pio\build\CYD-2432S028\firmware.elf
c:/users/mas dek/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: cannot find -lnet80211
*** [.pio\build\CYD-2432S028\firmware.elf] Error 1
You have a space in your username
You have a space in your username! PlatformIO doesn’t like this!
i am use platformio on vscode sir
Yes, but the problem is the same: white space character in your windows username.
Remove platformio, set the windows environment variable ro specify a directory without a white space character (see above), install platformio again.
The default directory is C:\<usename>\.platformio
You can change the default directory by setting the windows environment variable before installing platformio!
