hey !
Platformio can’t find the source file the father had a folder name with “[” or “]”.
I tried to link the file in platformio.ini using “src_dir” and it gives me the same error "Error: Nothing to build. Please put your source code file: ’ username\file [project] '
Ty
Could you provide platformio.ini and project files structure?
hi, thank you for you reply, there is the file structure and platformio.ini
C:\LIAMSE\Project[1]\ROBOT\ : eclipse project folder"created using platformio"::
/platformio.ini*************/
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
; Redirecting...
[platformio]
env_default = megaatmega2560
[env:uno]
board = uno
upload_protocol = dragon_isp
upload_flags = -Pusb
build_unflags = “-flto”
[env:nanoatmega328]
board = nanoatmega328
upload_protocol = atmelice_isp
[env:megaatmega2560]
board = megaatmega2560
Thanks a lot for the report! The bug is fixed in
https://github.com/platformio/platformio-core/commit/ddd07138dd2c90a45d8f464e25869f38493981a3
Please re-test with Development Version
it’s work, Thank you !
In order to use platformio as stable version on our system. Could you please tell us in which stable version it will be implemented?
Thanks in advance.
- You can use stable version of PIO Core but avoid using of
[]in project path (these are Glob’s special chars) - The nearest milestone is PIO Core 3.3. See Milestones - platformio/platformio-core · GitHub
Hi.
I’m continuing the job of liams. We can’t change the project path because of the rules of our system to save the files. So, we will be working with the development version until the next release.
We do have an other problem. “é” doesn’t seems to work too when we declare “lib_extra_dirs” in platformio.ini. Is it possible to add almost all characters with accent available on paths? I know, I ask for much, but I was wondering if it is possible.
If not, is there any way to add them ourself directly into platformio.ini?
Thanks in advance.
We have an issue for that
Ok. Thanks. I will follow it.
For the moment, I managed to do it through indirect access (using …\…\).
