My problem is this error.
I tried to fix it, but unfortunately i couldn’t because I don’t know exactly what the problem is
This is the error code:
.pio\build\esp32dev\src\web_control.cpp.o:(.literal._Z14httpClockSetupv+0x34): undefined reference to `webServer'
.pio\build\esp32dev\src\web_server.cpp.o:(.literal._Z7httpLogv+0x8): undefined reference to `webServer'
.pio\build\esp32dev\src\web_server.cpp.o:(.literal._Z16handleWebRequestv+0x8): undefined reference to `webServer'
*** [.pio\build\esp32dev\firmware.elf] Error 1
It seems like only web_control.cpp and web_server.cpp are affected so I’ll put the code too.
web_control.cpp:
#include "web_control.h"
#include "filesys.h"
#include "citylist.h"
#include "main.h"
#include "config.h"
#include <listObj.h>
void httpClockSetup();
void httpClockSetupSave();
void httpClockSetup() {
#ifdef WIFIDEBUG
Serial.println("Handle Clock Setup");
char tempstr[1024 * 3]; //Is that enough? How big is the stack actually???
char tmp2[1024]; //Is that enough? How big is the stack actually???
uint16_t citycnt = 0;
snprintf(tempstr, sizeof(tempstr),
"<!DOCTYPE html>\
<title>LED Clock Setup</title>\
<meta name=\"viewport\" content=\"initial-scale=1.0\">\
<link rel=\"stylesheet\" href=\"pure-min.css\">\
<form action=\"/saveledsetup\" class=\"pure-form pure-form-aligned\">\
<fieldset>\
<div class=\"pure-control-group\">\
<label for=\"city\">City</label>\
<select name=\"city\">");
#ifdef WIFIDEBUG
Serial.println("Inserting City List");
while (cities[citycnt].latitude != 0) {
snprintf(tmp2, 1024, "<option value=\"%d\">%s</option>", citycnt, cities[citycnt].cityname);
strncat(tempstr, tmp2, 2048);
citycnt++;
yield();
"</select>\
<label for=\"bday\">Brightness Day [%%]</label>\
<input name=\"bday\" id=\"bday\" type=\"number\" min=\"005\" max=\"100\" required placeholder=\"80\">\
</div>\
<label for=\"bnight\">Brightness Night [%%]</label>\
<input name=\"bnight\" id=\"bnight\" type=\"number\" min=\"005\" max=\"100\" required placeholder=\"15\">\
</div>\
<label for=\"ntpupd\">NTP Update Interval [min]</label>\
<input name=\"ntpupd\" id=\"ntpupd\" type=\"number\" min=\"0001\" max=\"1440\" required placeholder=\"15\">\
</div>\
<input type=\"submit\" value=\"Save\">\
</div>\
</fieldset>\
</form>");
#ifdef WIFIDEBUG
Serial.println("Serving Clock Setup Page");
Serial.println(tempstr);
Serial.println("");
webServer.send(200, "text/html", tempstr);
void httpClockSetupSave() {
config_t *pConfig = get_config_ptr();
logline << webServer.client().remoteIP() << " connect ";
appendLog();
for (int ii = 0; ii < webServer.args(); ii++) {
logline << ' ' << webServer.argName(ii) << ':' << webServer.arg(ii);
appendLog();
//Store Values sent from Webpage
pConfig->city_index = atoi(webServer.arg("city").c_str());
pConfig->day_brightness = atoi(webServer.arg("bday").c_str());
pConfig->night_brightness = atoi(webServer.arg("bnight").c_str());
pConfig->NTP_Sync_interval = atoi(webServer.arg("ntpupd").c_str());
#ifdef WIFIDEBUG
Serial.println("Saving Clock Config");
save_config();
void register_Setup_pages() {
webServer.on("/", httpClockSetup);
webServer.on("/saveledsetup", httpClockSetupSave);
web_server:
#include "web_server.h"
#include "main.h"
bool loadFromSpiffs(String path);
void httpDefault();
void handleWebRequest();
void httpPureCss();
void httpLogDelete();
bool loadFromSpiffs(String path) {
String dataType = "text/plain";
if (path.endsWith("/")) path += "index.htm";
if (path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
else if (path.endsWith(".html")) dataType = "text/html";
else if (path.endsWith(".htm")) dataType = "text/html";
else if (path.endsWith(".css")) dataType = "text/css";
else if (path.endsWith(".js")) dataType = "application/javascript";
else if (path.endsWith(".png")) dataType = "image/png";
else if (path.endsWith(".gif")) dataType = "image/gif";
else if (path.endsWith(".jpg")) dataType = "image/jpeg";
else if (path.endsWith(".ico")) dataType = "image/x-icon";
else if (path.endsWith(".xml")) dataType = "text/xml";
else if (path.endsWith(".pdf")) dataType = "application/pdf";
else if (path.endsWith(".zip")) dataType = "application/zip";
File dataFile = SPIFFS.open(path.c_str(), "r");
if (!dataFile) {
path += ".gz";
File file = SPIFFS.open(path.c_str(), "r");
if (!file) {
return false;
if (webServer.hasArg("download")) dataType = "application/oclet-stream";
#ifdef WIFIDEBUG
Serial.print("XMit File: ");
Serial.print(path);
Serial.print(" Type: ");
Serial.print(dataType);
if (webServer.streamFile(dataFile, dataType) != dataFile.size()) {
#ifdef WIFIDEBUG
Serial.println("XMit File Size Missmatch");
dataFile.close();
return true;
void httpLog() {
logline << webServer.client().remoteIP() << " log";
appendLog();
logfile.seek(0, SeekSet);
webServer.streamFile(logfile, "text/plain");
logfile.seek(0, SeekEnd);
void httpLogDelete() {
logfile.close();
SPIFFS.remove("/log.txt");
logfile = SPIFFS.open("/log.txt", "a+");
logline << webServer.client().remoteIP() << "NEW LOG";
appendLog();
void httpDefault() {
logline << webServer.client().remoteIP() << " redirect";
appendLog();
webServer.sendHeader("Location", "http://WifiLogin.lan", true);
webServer.send(302, "text/plain", "");
webServer.client().stop();
void httpHome() {
/*if (server.hostHeader() != String("WifiLogin.lan")) {
return httpDefault();
logline << webServer.client().remoteIP() << " home";
appendLog();
File file = SPIFFS.open("/index.htm.gz", "r");
//Handle file not existing....
if (file) {
webServer.streamFile(file, "text/html");
} else {
File file = SPIFFS.open("/index.htm.", "r");
if (file) {
} else {
logline << webServer.client().remoteIP() << " missing index.htm";
appendLog();
handleWebRequest();
file.close();
void httpPureCSS() {
File file = SPIFFS.open("/pure-min.css.gz", "r");
webServer.streamFile(file, "text/css");
file.close();
void handleWebRequest() {
if (loadFromSpiffs(webServer.uri())) return;
String message = "File Not Detected\n\n";
message += "URI: ";
message += webServer.uri();
message += "\nMethod: ";
message += (webServer.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += webServer.args();
message += "\n";
for (uint8_t i = 0; i < webServer.args(); i++) {
message += " NAME:" + webServer.argName(i) + "\n VALUE:" + webServer.arg(i) + "\n";
webServer.send(404, "text/plain", message);
#ifdef WIFIDEBUG
Serial.println(message);
void webserver_init() {
#ifdef WIFIDEBUG
Serial.println("Registering WebServer Callbacks");
webServer.on("/hotspot-detect.html", httpHome);
webServer.on("/log.txt", httpLog);
webServer.on("/log.delete", httpLogDelete);
webServer.onNotFound(handleWebRequest);
#ifndef WIFIDEBUG
Serial.println("Starting Server");
webServer.begin();
Thank you very much in advance!
