I’m trying to Debug a hello world application on HiFive Unleashed using PlatformIO Core (CLI) tool. I’ve setup the utility using this Wiki:
https://docs.platformio.org/en/latest/core/installation.html#installation
And used these commands to debug the application:
I’m facing a strange error while starting the debug session:
Error: invalid ELF file, only 32bits files are supported
embedded:startup.tcl:486: Error: ** Programming Failed **
Here are the complete verbose logs:
arshadaleem@lmlpt52:~/platformio/platform-sifive/examples/freedom-e-sdk_hello$ platformio run -e sifive-hifive-unleashed --target upload -v
Processing sifive-hifive-unleashed (platform: sifive; framework: freedom-e-sdk; board: hifive-unleashed; monitor_speed: 115200)
CONFIGURATION: https://docs.platformio.org/page/boards/sifive/hifive-unleashed.html
PLATFORM: SiFive (2.4.0) > HiFive Unleashed
HARDWARE: FU540 1500MHz, 8GB RAM, 32MB Flash
DEBUG: Current (ftdi) On-board (ftdi, qemu, renode)
- framework-freedom-e-sdk 2.20050003.200818 (2005.0.3)
- tool-jlink 1.65200.0 (6.52.0)
- tool-openocd-riscv 2.1000.20190927 (10.0)
- toolchain-riscv 1.80300.190927 (8.3.0)
LDF: Library Dependency Finder ->
Found 0 compatible libraries
MethodWrapper(["checkprogsize"], [".pio/build/sifive-hifive-unleashed/firmware.elf"])
RAM: [ ] 0.0% (used 17380 bytes from 8589934592 bytes)
Flash: [ ] 0.1% (used 23612 bytes from 33554432 bytes)
text data bss dec hex filename
13716 9896 7484 31096 7978 .pio/build/sifive-hifive-unleashed/firmware.elf
<lambda>(["upload"], [".pio/build/sifive-hifive-unleashed/firmware.elf"])
AVAILABLE: ftdi
CURRENT: upload_protocol = ftdi
openocd -c "debug_level 2" -s /home/arshadaleem/.platformio/packages/tool-openocd-riscv -s /share/openocd/scripts -f /home/arshadaleem/.platformio/packages/framework-freedom-e-sdk/bsp/sifive-hifive-unleashed/openocd.cfg -c "program {.pio/build/sifive-hifive-unleashed/firmware.elf} verify; shutdown;"
Open On-Chip Debugger 0.10.0+dev (SiFive OpenOCD 0.10.0-2019.08.2)
Licensed under GNU GPL v2
For bug reports:
https://github.com/sifive/freedom-tools/issues
debug_level: 2
adapter speed: 10000 kHz
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : Hardware thread awareness created
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 10000 kHz
Info : JTAG tap: riscv.cpu tap/device found: 0x20000913 (mfg: 0x489 (SiFive Inc), part: 0x0000, ver: 0x2)
Info : datacount=2 progbufsize=16
Info : Disabling abstract command reads from CSRs.
Info : Core 0 could not be made part of halt group 1.
Info : Examined RISC-V core; found 5 harts
Info : hart 0: XLEN=64, misa=0x8000000000101105
Info : hart 1: currently disabled
Info : hart 2: currently disabled
Info : hart 3: currently disabled
Info : hart 4: currently disabled
Info : Core 1 could not be made part of halt group 1.
Info : hart 0: currently disabled
Info : hart 1: XLEN=64, misa=0x800000000014112d
Info : Core 2 could not be made part of halt group 1.
Info : hart 2: XLEN=64, misa=0x800000000014112d
Info : Core 3 could not be made part of halt group 1.
Info : hart 3: XLEN=64, misa=0x800000000014112d
Info : Core 4 could not be made part of halt group 1.
Info : hart 4: XLEN=64, misa=0x800000000014112d
Info : Found flash device 'issi is25wp256d' (ID 0x0019709d)
Warn : device needs paging or 4-byte addresses - not implemented
cleared protection for sectors 64 through 511 on flash bank 0
Ready for Remote Connections
** Programming Started **
auto erase enabled
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 545
at file "embedded:startup.tcl", line 486
*** [upload] Error 1
========================================================= [FAILED] Took 0.82 seconds =========================================================
(penv)
Output of readelf is as follows:
arshadaleem@lmlpt52:~/platformio/platform-sifive/examples/freedom-e-sdk_hello$ readelf -h .pio/build/sifive-hifive-unleashed/firmware.elf
ELF Header:
Magic: 7f 45 4c 46 02 01 01 00 00 00 00 00 00 00 00 00
Class: ELF64
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: UNIX - System V
ABI Version: 0
Type: EXEC (Executable file)
Machine: RISC-V
Version: 0x1
Entry point address: 0x20000000
Start of program headers: 64 (bytes into file)
Start of section headers: 47872 (bytes into file)
Flags: 0x1, RVC, soft-float ABI
Size of this header: 64 (bytes)
Size of program headers: 56 (bytes)
Number of program headers: 6
Size of section headers: 64 (bytes)
Number of section headers: 15
Section header string table index: 14
Any pointer in eliminating this error will be much appreciated.
Thanks.
