Error in the display of PlatformIO Home
i have some trouble with the display of the PlatformIO page… it all lists without proper positioning and i cannot select the boards…
it started after the latest PlatformIO IDE update.
Which information should i add ?
best,
Sylvain
Do you use the latest Atom and PlatformIO IDE for Atom? If yes, please open PIO IDE Terminal and type pio update. Restart Atom. Does it work now?
ooh, i’m getting this message :
Obsolete PIO Core v3.5.1 is used (previous was 3.5.2rc3)
Please remove multiple PIO Cores from a system:
http://docs.platformio.org/page/faq.html#multiple-pio-cores-in-a-system
i tried uninstalling and reinstalling PlatformIO from Atom but that didnt seem enough…
Please remove all PIO Cores from a system.
it keeps on reinstalling 3.5.1 each time i launch it ;
cannot access Platformio > Settings > Platformio IDE ( it just doesnt open the settings windows )
Please update PIO IDE extension to 2.1.2 version. Does it work now?
i could stop the constant reinstallation by uninstalling and reinstalling Platform IO and Python 2.7.4
and these options
OFF : automatically update Platform IDE
OFF : use platform development IDE
Use Built-in platform Core
ON : use development platform Core
current : is PlatformIO 3.5.2rc4
i did the upgrade to PIO IDE 2.1.2 right now. i can work with the editor, build and access settings of Platform,
but Platform Home still looks bad :
Please open PlatformIO IDE Terminal and type
pio home
PIO Home should be opened in your standalone browser. Do you see any errors in console?
I think those are two different issues. If you are not able to access the settings due to the re-install loop you can edit PIO_CORE_MIN_VERSION in config.js to your current version. From there you can follow Redirecting... without reinstalling anything.
the re-install issue is indeed solved, but i keep having the Home page in a strange way.
tried installing Safari thinking it was an issue with Java in Chrome, but nothing changes.
it wont open through pio home
back to this topic since i need to use the Home page…
this is what i can see as warnings in Console after doing pio home :
(index):39 Resource interpreted as Stylesheet but transferred with MIME type application/x-css: “http://127.0.0.1:8008/themes/platformio-dark.css”.
(anonymous) @ (index):39
28c486a994ab65f53b53c.min.js:39 autoPlay is triggered more than once
r.autoPlay @ 8c486a994ab65f53b53c.min.js:39
(anonymous) @ 8c486a994ab65f53b53c.min.js:39
mt @ 8c486a994ab65f53b53c.min.js:25
commitLifeCycles @ 8c486a994ab65f53b53c.min.js:25
E @ 8c486a994ab65f53b53c.min.js:25
_ @ 8c486a994ab65f53b53c.min.js:25
b @ 8c486a994ab65f53b53c.min.js:25
v @ 8c486a994ab65f53b53c.min.js:25
m @ 8c486a994ab65f53b53c.min.js:25
c @ 8c486a994ab65f53b53c.min.js:25
enqueueSetState @ 8c486a994ab65f53b53c.min.js:25
a.setState @ 8c486a994ab65f53b53c.min.js:25
r.updateState @ 8c486a994ab65f53b53c.min.js:39
r.onWindowResized @ 8c486a994ab65f53b53c.min.js:39
a @ 8c486a994ab65f53b53c.min.js:39
load (async)
r.checkImagesLoad @ 8c486a994ab65f53b53c.min.js:39
r.componentDidUpdate @ 8c486a994ab65f53b53c.min.js:39
i.onStateChange @ 8c486a994ab65f53b53c.min.js:6
notify @ 8c486a994ab65f53b53c.min.js:6
e.notifyNestedSubs @ 8c486a994ab65f53b53c.min.js:6
(anonymous) @ 8c486a994ab65f53b53c.min.js:6
(anonymous) @ 8c486a994ab65f53b53c.min.js:17
(anonymous) @ 8c486a994ab65f53b53c.min.js:33
dispatch @ 8c486a994ab65f53b53c.min.js:6
r @ 8c486a994ab65f53b53c.min.js:17
s @ 8c486a994ab65f53b53c.min.js:17
a @ 8c486a994ab65f53b53c.min.js:17
t @ 8c486a994ab65f53b53c.min.js:6
o.onmessage @ 8c486a994ab65f53b53c.min.js:6
r.dispatchEvent @ 8c486a994ab65f53b53c.min.js:17
r._transportMessage @ 8c486a994ab65f53b53c.min.js:33
r.emit @ 8c486a994ab65f53b53c.min.js:6
ws.onmessage @ 8c486a994ab65f53b53c.min.js:33
and this is the look of it :
Does it work now? Please run pio upgrade.
