I’m trying to debug a program Factorial.c on the Nexys A7 50T FPGA board using PlatformIO. I have procured its bitstream file from the GitHub repository.
Shown below is the platformio.ini code:
[env:swervolf_nexys]
platform = chipsalliance
board = swervolf_nexys
framework = wd-riscv-sdk
board_build.bitstream_file = D:\STUDIES\NexysFiles\Nexys-A7-50T-OOB-2018.2-1\vivado_proj\Nexys-A7-50T-OOB.runs\impl_1\nexys50t.bit
Shown below is the program code:
#if defined(D_NEXYS_A7)
#include <bsp_printf.h>
#include <bsp_mem_map.h>
#include <bsp_version.h>
#else
PRE_COMPILED_MSG("no platform was defined")
#include <psp_api.h>
#define N 7
int main(void)
int fact = 1;
int temp = N;
while(temp > 0){
fact *= temp;
temp -= 1;
uartInit(); // Initialize UART
printfNexys("Factorial of %d: %d ", N, fact);
Using PlatformIO, the bitstream is uploaded successfully on the board.
After clicking on “Run Debug”, the compilation is also done successfully.
But the debug console fails with the following errors:
My current driver used is: libwdi
I have installed in using Zadig by following the steps mentioned in the guide and have also tried reinstalling the driver but the same issue persists.
I’m using Windows 10.
