I’m trying to build a LoRa temperature probe. I first made it in the arduino IDE and it all works bud I want to use a different LoRa library that is not supported with the arduino IDE. So I’m trying to get everything working in platformIO bud I get a compiling error I can’t fix.
error:
Linking .pio\build\ttgo_lora32_v1\firmware.elf
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_base.cpp.o): In function `base64_dec_len(char*, int)':
D:\Users\Sander\Downloads\ESP32-LMIC-DeepSleep-example-master\ESP32-LMIC-DeepSleep-example-master/.pio\libdeps\ttgo_lora32_v1\ThingsML\src\senml\../util/base64.h:9: multiple definition of `base64_dec_len(char*, int)'
.pio\build\ttgo_lora32_v1\src\main.cpp.o:D:\Users\Sander\Downloads\ESP32-LMIC-DeepSleep-example-master\ESP32-LMIC-DeepSleep-example-master/.pio\libdeps\ttgo_lora32_v1\ThingsML\src/senml/../util/base64.h:9: first defined here
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_basepack.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\src\main.cpp.o:main.cpp:(.text._Z14base64_dec_lenPci+0x0): first defined here
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_cbor_parser.cpp.o): In function `base64_dec_len(char*, int)':
D:\Users\Sander\Downloads\ESP32-LMIC-DeepSleep-example-master\ESP32-LMIC-DeepSleep-example-master/.pio\libdeps\ttgo_lora32_v1\ThingsML\src\senml\record/../../util/base64.h:9: multiple definition of `base64_dec_len(char*, int)'
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_helpers.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_json_parser.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_jsonstreamingparser.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_logging.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_pack.cpp.o): In function `base64_dec_len(char*, int)':
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(cbor.cpp.o): In function `base64_dec_len(char*, int)':
D:\Users\Sander\Downloads\ESP32-LMIC-DeepSleep-example-master\ESP32-LMIC-DeepSleep-example-master/.pio\libdeps\ttgo_lora32_v1\ThingsML\src\cbor\../senml/../util/base64.h:9: multiple definition of `base64_dec_len(char*, int)'
.pio\build\ttgo_lora32_v1\lib73f\libThingsML.a(senml_base_parser.cpp.o): In function `base64_dec_len(char*, int)':
*** [.pio\build\ttgo_lora32_v1\firmware.elf] Error 1
This is my code:
#include <arduino.h>
#include <thingsml.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <ttn_credentials.h>
#include <Wire.h>
#include <Adafruit_MAX31865.h>
/*Custum variables */
//#define useOled
//#define loraUit
float temp = 0;
#define battMax 1480
#define battMin 1140
float battPercent = 0;
float battCo = 0;
SenMLPack device("tempProbe");
//SenMLDoubleRecord temperature(THINGSML_TEMPERATURE);
//SenMLDoubleRecord battery(THINGSML_BATTERY_LEVEL);
//Temp setup
Adafruit_MAX31865 thermo = Adafruit_MAX31865(13);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF 430.0
// The 'nominal' 0-degrees-C resistance of the sensorr
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL 100.0
bool GOTO_DEEPSLEEP = false;
// rename ttn_credentials.h.example to ttn_credentials.h and add you keys
static const u1_t PROGMEM APPEUI[8] = TTN_APPEUI;
static const u1_t PROGMEM DEVEUI[8] = TTN_DEVEUI;
static const u1_t PROGMEM APPKEY[16] = TTN_APPKEY;
void os_getArtEui(u1_t *buf) { memcpy_P(buf, APPEUI, 8); }
void os_getDevEui(u1_t *buf) { memcpy_P(buf, DEVEUI, 8); }
void os_getDevKey(u1_t *buf) { memcpy_P(buf, APPKEY, 16); }
static uint8_t mydata[] = "Test";
static osjob_t sendjob;
// Schedule TX every this many seconds
// Respect Fair Access Policy and Maximum Duty Cycle!
// https://www.thethingsnetwork.org/docs/lorawan/duty-cycle.html
// https://www.loratools.nl/#/airtime
const unsigned TX_INTERVAL = 60;
// Saves the LMIC structure during DeepSleep
RTC_DATA_ATTR lmic_t RTC_LMIC;
#ifdef HELTEC_WIFI_LORA_32_V2_pins
#define PIN_LMIC_NSS 18
#define PIN_LMIC_RST 14
#define PIN_LMIC_DIO0 26
#define PIN_LMIC_DIO1 35
#define PIN_LMIC_DIO2 34
#define Vext 21
#ifdef TTGO_LORA32_V1_pins
#define PIN_LMIC_DIO1 33
#define PIN_LMIC_DIO2 32
#define Vext 21
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = PIN_LMIC_NSS,
.rxtx = LMIC_UNUSED_PIN,
.rst = PIN_LMIC_RST,
.dio = {PIN_LMIC_DIO0, PIN_LMIC_DIO1, PIN_LMIC_DIO2},
void battMeasure() {
battCo = (battMax - battMin) / 100;
digitalWrite(Vext, LOW); //Turn on external power
uint16_t ADC_voltage = analogRead(37);
float percent = (ADC_voltage - battMin) / battCo;
battPercent = percent;
Serial.print("batt percent: ");
Serial.println(percent);
if (battPercent > 100){
battPercent = 100;
digitalWrite(Vext, HIGH); //Turn off external power
#ifdef useOled
displayBatt();
void tempMeasure() {
Serial.println("Meet temp");
thermo.begin(MAX31865_3WIRE); // set to 2WIRE or 4WIRE as necessary
uint16_t rtd = thermo.readRTD();
temp = (thermo.temperature(RNOMINAL, RREF));
Serial.print("RTD value: "); Serial.println(rtd);
float ratio = rtd;
ratio /= 32768;
Serial.print("Ratio = "); Serial.println(ratio, 8);
Serial.print("Resistance = "); Serial.println(RREF * ratio, 8);
Serial.print("Temperature = "); Serial.println(temp);
// Check and print any faults
uint8_t fault = thermo.readFault();
if (fault) {
Serial.print("Fault 0x"); Serial.println(fault, HEX);
if (fault & MAX31865_FAULT_HIGHTHRESH) {
Serial.println("RTD High Threshold");
if (fault & MAX31865_FAULT_LOWTHRESH) {
Serial.println("RTD Low Threshold");
if (fault & MAX31865_FAULT_REFINLOW) {
Serial.println("REFIN- > 0.85 x Bias");
if (fault & MAX31865_FAULT_REFINHIGH) {
Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_RTDINLOW) {
Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_OVUV) {
Serial.println("Under/Over voltage");
thermo.clearFault();
Serial.println();
#ifdef useOled
displayTemp();
return;
// opmode def
// https://github.com/mcci-catena/arduino-lmic/blob/89c28c5888338f8fc851851bb64968f2a493462f/src/lmic/lmic.h#L233
void LoraWANPrintLMICOpmode(void)
Serial.print(F("LMIC.opmode: "));
if (LMIC.opmode & OP_NONE)
Serial.print(F("OP_NONE "));
if (LMIC.opmode & OP_SCAN)
Serial.print(F("OP_SCAN "));
if (LMIC.opmode & OP_TRACK)
Serial.print(F("OP_TRACK "));
if (LMIC.opmode & OP_JOINING)
Serial.print(F("OP_JOINING "));
if (LMIC.opmode & OP_TXDATA)
Serial.print(F("OP_TXDATA "));
if (LMIC.opmode & OP_POLL)
Serial.print(F("OP_POLL "));
if (LMIC.opmode & OP_REJOIN)
Serial.print(F("OP_REJOIN "));
if (LMIC.opmode & OP_SHUTDOWN)
Serial.print(F("OP_SHUTDOWN "));
if (LMIC.opmode & OP_TXRXPEND)
Serial.print(F("OP_TXRXPEND "));
if (LMIC.opmode & OP_RNDTX)
Serial.print(F("OP_RNDTX "));
if (LMIC.opmode & OP_PINGINI)
Serial.print(F("OP_PINGINI "));
if (LMIC.opmode & OP_PINGABLE)
Serial.print(F("OP_PINGABLE "));
if (LMIC.opmode & OP_NEXTCHNL)
Serial.print(F("OP_NEXTCHNL "));
if (LMIC.opmode & OP_LINKDEAD)
Serial.print(F("OP_LINKDEAD "));
if (LMIC.opmode & OP_TESTMODE)
Serial.print(F("OP_TESTMODE "));
if (LMIC.opmode & OP_UNJOIN)
Serial.print(F("OP_UNJOIN "));
void LoraWANDebug(lmic_t lmic_check)
Serial.println("");
Serial.println("");
LoraWANPrintLMICOpmode();
Serial.println("");
Serial.print(F("LMIC.seqnoUp = "));
Serial.println(lmic_check.seqnoUp);
Serial.print(F("LMIC.globalDutyRate = "));
Serial.print(lmic_check.globalDutyRate);
Serial.print(F(" osTicks, "));
Serial.print(osticks2ms(lmic_check.globalDutyRate) / 1000);
Serial.println(F(" sec"));
Serial.print(F("LMIC.globalDutyAvail = "));
Serial.print(lmic_check.globalDutyAvail);
Serial.print(osticks2ms(lmic_check.globalDutyAvail) / 1000);
Serial.print(F("LMICbandplan_nextTx = "));
Serial.print(LMICbandplan_nextTx(os_getTime()));
Serial.print(osticks2ms(LMICbandplan_nextTx(os_getTime())) / 1000);
Serial.print(F("os_getTime = "));
Serial.print(os_getTime());
Serial.print(osticks2ms(os_getTime()) / 1000);
Serial.print(F("LMIC.txend = "));
Serial.println(lmic_check.txend);
Serial.print(F("LMIC.txChnl = "));
Serial.println(lmic_check.txChnl);
Serial.println(F("Band \tavail \t\tavail_sec\tlastchnl \ttxcap"));
for (u1_t bi = 0; bi < MAX_BANDS; bi++)
Serial.print(bi);
Serial.print("\t");
Serial.print(lmic_check.bands[bi].avail);
Serial.print("\t\t");
Serial.print(osticks2ms(lmic_check.bands[bi].avail) / 1000);
Serial.print(lmic_check.bands[bi].lastchnl);
Serial.println(lmic_check.bands[bi].txcap);
Serial.println("");
Serial.println("");
void PrintRuntime()
long seconds = millis() / 1000;
Serial.print("Runtime: ");
Serial.print(seconds);
Serial.println(" seconds");
void PrintLMICVersion()
Serial.print(F("LMIC: "));
Serial.print(ARDUINO_LMIC_VERSION_GET_MAJOR(ARDUINO_LMIC_VERSION));
Serial.print(F("."));
Serial.print(ARDUINO_LMIC_VERSION_GET_MINOR(ARDUINO_LMIC_VERSION));
Serial.print(ARDUINO_LMIC_VERSION_GET_PATCH(ARDUINO_LMIC_VERSION));
Serial.println(ARDUINO_LMIC_VERSION_GET_LOCAL(ARDUINO_LMIC_VERSION));
void onEvent(ev_t ev)
Serial.print(": ");
switch (ev)
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
break;
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
break;
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
break;
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
break;
case EV_JOINING:
Serial.println(F("EV_JOINING"));
break;
case EV_JOINED:
Serial.println(F("EV_JOINED"));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (size_t i = 0; i < sizeof(artKey); ++i)
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (size_t i = 0; i < sizeof(nwkKey); ++i)
Serial.print(nwkKey[i], HEX);
Serial.println("");
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don't use it in this example.
LMIC_setLinkCheckMode(0);
break;
|| This event is defined but not used in the code. No
|| point in wasting codespace on it.
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
break;
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
break;
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen)
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
GOTO_DEEPSLEEP = true;
break;
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
break;
case EV_RESET:
Serial.println(F("EV_RESET"));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
break;
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
break;
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
Serial.println(F("EV_TXSTART"));
break;
case EV_TXCANCELED:
Serial.println(F("EV_TXCANCELED"));
break;
case EV_RXSTART:
/* do not print anything -- it wrecks timing */
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
break;
default:
Serial.print(F("Unknown event: "));
Serial.println((unsigned)ev);
break;
void do_send(osjob_t *j)
// Check if there is not a current TX/RX job running
Serial.println(F("OP_TXRXPEND, not sending"));
else
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(1, mydata, sizeof(mydata) - 1, 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
void SaveLMICToRTC(int deepsleep_sec)
Serial.println(F("Save LMIC to RTC"));
RTC_LMIC = LMIC;
// ESP32 can't track millis during DeepSleep and no option to advanced millis after DeepSleep.
// Therefore reset DutyCyles
unsigned long now = millis();
// EU Like Bands
#if defined(CFG_LMIC_EU_like)
Serial.println(F("Reset CFG_LMIC_EU_like band avail"));
for (int i = 0; i < MAX_BANDS; i++)
ostime_t correctedAvail = RTC_LMIC.bands[i].avail - ((now / 1000.0 + deepsleep_sec) * OSTICKS_PER_SEC);
if (correctedAvail < 0)
correctedAvail = 0;
RTC_LMIC.bands[i].avail = correctedAvail;
RTC_LMIC.globalDutyAvail = RTC_LMIC.globalDutyAvail - ((now / 1000.0 + deepsleep_sec) * OSTICKS_PER_SEC);
if (RTC_LMIC.globalDutyAvail < 0)
RTC_LMIC.globalDutyAvail = 0;
#else
Serial.println(F("No DutyCycle recalculation function!"));
void LoadLMICFromRTC()
Serial.println(F("Load LMIC from RTC"));
LMIC = RTC_LMIC;
void GoDeepSleep()
Serial.println(F("Go DeepSleep"));
PrintRuntime();
Serial.flush();
esp_sleep_enable_timer_wakeup(TX_INTERVAL * 1000000);
esp_deep_sleep_start();
void setup()
pinMode(Vext, OUTPUT);
adcAttachPin(37);
analogSetClockDiv(255); // 1338mS
tempMeasure();
battMeasure();
//Setup ThingsMl
//device.add(temperature);
//device.add(battery);
//temperature.set(temp);
//battery.set(battPercent);
Serial.println(F("Starting DeepSleep test"));
PrintLMICVersion();
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
if (RTC_LMIC.seqnoUp != 0)
LoadLMICFromRTC();
LoraWANDebug(LMIC);
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
void loop()
static unsigned long lastPrintTime = 0;
os_runloop_once();
const bool timeCriticalJobs = os_queryTimeCriticalJobs(ms2osticksRound((TX_INTERVAL * 1000)));
if (!timeCriticalJobs && GOTO_DEEPSLEEP == true && !(LMIC.opmode & OP_TXRXPEND))
Serial.print(F("Can go sleep "));
SaveLMICToRTC(TX_INTERVAL);
GoDeepSleep();
else if (lastPrintTime + 2000 < millis())
Serial.print(F("Cannot sleep "));
Serial.print(F("TimeCriticalJobs: "));
Serial.print(timeCriticalJobs);
Serial.print(" ");
PrintRuntime();
lastPrintTime = millis();
And the platformio.ini
[platformio]
default_envs =
[env:heltec_wifi_lora_32_v2]
board = heltec_wifi_lora_32_V2
build_unflags = -Werror=reorder
${common.lib_deps}
-D HELTEC_WIFI_LORA_32_V2_pins
${common.build_flags}
[env:ttgo_lora32_v1]
board = ttgo-lora32-v1
${common.lib_deps}
-D TTGO_LORA32_V1_pins
[common]
mcci-catena/MCCI LoRaWAN LMIC library @ ^4.0.0
adafruit/Adafruit MAX31865 library@^1.3.0
;kpn-iot/ThingsML@^1.0.2
-D ARDUINO_LMIC_PROJECT_CONFIG_H_SUPPRESS
-D CFG_eu868=1
-D LMIC_DEBUG_LEVEL=1
-D CFG_sx1276_radio=1
-D DISABLE_PING=1
-D DISABLE_BEACONS=1
-D USE_ORIGINAL_AES
-w
Who can help my?
Greetings,
Sander
