Error ESP32 PROG
Hello
I have error code with my ESP32 Prog can you help me ? Thanks
 Open On-Chip Debugger  v0.10.0-esp32-20201202 (2020-12-02-17:38)
 Licensed under GNU GPL v2
 For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
2
Info : FreeRTOS creation
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
Info : accepting 'gdb' connection from pipe
Warn : No symbols for FreeRTOS!
Error: Target not examined yet
Error executing event gdb-attach on target esp32.cpu0:
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
.pioinit:11: Error in sourced command file:
Remote communication error.  Target disconnected.: No error.
That here. Have you checked that?
A general countermeasure would be to write debug_speed = 500 in the platformio.ini to lower the debugging speed to 500kHz.
Otherwise there could also be a wrong connection to the board. Since you didn’t show the wireup, I can’t say that.
I double-check the connections all looks good .
Reading symbols from c:\Users\mcece\Desktop\arduino\temperatrure\.pio\build\esp32doit-devkit-v1\firmware.elf...
done.
PlatformIO Unified Debugger -> http://bit.ly/pio-debug
PlatformIO: debug_tool = esp-prog
PlatformIO: Initializing remote target...
2
Error: JTAG scan chain interrogation failed: all ones
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
And the same happens with a lower debug_speed as previously noted? (docs).
this is my ini file
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
upload_protocol = esp-prog
monitor_speed = 9600
    adafruit/Adafruit SHT31 Library @ 2.0.0
    adafruit/Adafruit MCP9600 Library @ 1.1.1
debug_init_break = tbreak setup
debug_speed = 20000
upload_port = COM6
That’s not necessary since the esp-prog upload happens via the USB device, not a COM port.
Ok but, did you try the lower speed? What is the wireup? Also, which exact dev board are you using?
PlatformIO: Initializing remote target…
2
adapter speed: 1000 kHz
Info : clock speed 1000 kHz
Error: Trying to use configured scan chain anyway…
Info : accepting ‘gdb’ connection from pipe
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use ‘gdb_memory_map disable’.
Error: attempted ‘gdb’ connection rejected
i use this DEV board : https://www.digikey.ca/en/products/detail/schtoeta-engineering-limited/ESP32-DEVKITC-32UE/12091813?utm_adgroup=RF%20Evaluation%20and%20Development%20Kits%2C%20Boards&utm_source=google&utm_medium=cpc&utm_campaign=Shopping_Product_RF%2FIF%20and%20RFID_NEW&utm_term=&productid=12091813&gclid=CjwKCAiAmrOBBhA0EiwArn3mfP8BNNMBVAKznM5PL8qur5PknFmqObGyxLhTS1z0jKsnn_Zxyg1KlBoCGPMQAvD_BwE
So how exactly did you connect the esp-prog to your target board?
i connected same as the schematic on this page ESP32 WROOM-32 and JTAG timeout
and connector of my esp-prog : https://docs.platformio.org/en/latest/_images/esp-prog_jtag_connector.png
Okay, should be the same as in Low-cost ESP32 In-circuit Debugging | by Manuel Bl. | Medium then.
If all cables are ok, the power supply is okay and the pinout is okay then I don’t see a problem. You might get help at Issues · espressif/openocd-esp32 · GitHub if you describe your problem.
It very much looks a wiring problem:
  • Make sure you power the ESP32 board independently (typically via the USB port), and not via ESP-Prog
  • Double and triple check that you have connected the correct pins
  • Use short wires and do not go via a breadboard
  • Don’t forget to connect GND of ESP32 board to GND of ESP-Prog
  • Ensure the GND pin on the ESP32 board is working (some board have an incorrectly labelled GND pin)
So i try my second board and it work …it was bad board …now i want to make my proper design and i want to know what i need to connect minimum to program the esp32 . Thanks
