LinuxMint20 OS
I am trying to compile Marlin 2.0 firmware for a 3D printer. I do this with the console command $ platformio run
An error appears while executing the command. From the output I can not understand what is the reason. Please help me figure it out.
Compiling .pio/build/LPC1769/src/src/libs/hex_print_routines.cpp.o
Compiling .pio/build/LPC1769/src/src/libs/least_squares_fit.cpp.o
Compiling .pio/build/LPC1769/src/src/libs/nozzle.cpp.o
Compiling .pio/build/LPC1769/src/src/libs/numtostr.cpp.o
Compiling .pio/build/LPC1769/src/src/libs/stopwatch.cpp.o
Compiling .pio/build/LPC1769/src/src/libs/vector_3.cpp.o
Compiling .pio/build/LPC1769/src/src/module/configuration_store.cpp.o
Compiling .pio/build/LPC1769/src/src/module/delta.cpp.o
In file included from Marlin/src/lcd/menu/../../inc/../core/language.h:382,
from Marlin/src/lcd/menu/../../inc/MarlinConfig.h:43,
from Marlin/src/lcd/menu/../ultralcd.h:24,
from Marlin/src/lcd/menu/menu.h:24,
from Marlin/src/lcd/menu/menu_motion.cpp:31:
Marlin/src/lcd/menu/menu_motion.cpp: In function 'void _menu_move_distance(AxisEnum, screenFunc_t, int8_t)':
Marlin/src/lcd/menu/menu_motion.cpp:262:33: warning: 'мм' directive writing 4 bytes into a region of size 3 [-Wformat-overflow=]
262 | sprintf_P(tmp, GET_TEXT(MSG_MOVE_Z_DIST), dtostrf(SHORT_MANUAL_Z_MOVE, 1, digs, numstr));
Marlin/src/lcd/menu/../../inc/../core/multi_language.h:74:49: note: in definition of macro 'GET_TEXT'
74 | #define GET_TEXT(MSG) GET_LANG(LCD_LANGUAGE)::MSG
Marlin/src/lcd/menu/menu_motion.cpp:262:18: note: 'sprintf' output 22 or more bytes into a destination of size 20
Compiling .pio/build/LPC1769/src/src/module/endstops.cpp.o
In file included from Marlin/src/lcd/menu/menu_temperature.cpp:31:
Marlin/src/lcd/menu/menu.h: In function 'void menu_temperature()':
Marlin/src/lcd/menu/menu.h:343:37: warning: '_thisItemNr' may be used uninitialized in this function [-Wmaybe-uninitialized]
343 | #define END_SCREEN() } screen_items = _thisItemNr
Marlin/src/lcd/menu/menu.h:327:40: note: '_thisItemNr' was declared here
327 | int8_t _menuLineNr = encoderTopLine, _thisItemNr; \
Marlin/src/lcd/menu/menu.h:340:22: note: in expansion of macro 'SCREEN_OR_MENU_LOOP'
340 | #define START_MENU() SCREEN_OR_MENU_LOOP(true)
Marlin/src/lcd/menu/menu_temperature.cpp:165:3: note: in expansion of macro 'START_MENU'
165 | START_MENU();
Compiling .pio/build/LPC1769/src/src/module/motion.cpp.o
Compiling .pio/build/LPC1769/src/src/module/planner.cpp.o
Compiling .pio/build/LPC1769/src/src/module/planner_bezier.cpp.o
Compiling .pio/build/LPC1769/src/src/module/printcounter.cpp.o
Compiling .pio/build/LPC1769/src/src/module/probe.cpp.o
Compiling .pio/build/LPC1769/src/src/module/scara.cpp.o
Compiling .pio/build/LPC1769/src/src/module/servo.cpp.o
Compiling .pio/build/LPC1769/src/src/module/stepper.cpp.o
Compiling .pio/build/LPC1769/src/src/module/stepper/L64xx.cpp.o
Compiling .pio/build/LPC1769/src/src/module/stepper/TMC26X.cpp.o
Compiling .pio/build/LPC1769/src/src/module/stepper/indirection.cpp.o
Compiling .pio/build/LPC1769/src/src/module/stepper/trinamic.cpp.o
Compiling .pio/build/LPC1769/src/src/module/temperature.cpp.o
Marlin/src/module/configuration_store.cpp: In static member function 'static void MarlinSettings::reset()':
Marlin/src/module/configuration_store.cpp:2621:32: error: 'DEFAULT_Kp' was not declared in this scope; did you mean 'DEFAULT_Kd'?
2621 | PID_PARAM(Kp, e) = float(DEFAULT_Kp);
| DEFAULT_Kd
Compiling .pio/build/LPC1769/src/src/module/tool_change.cpp.o
*** [.pio/build/LPC1769/src/src/module/configuration_store.cpp.o] Error 1
Marlin/src/module/planner.cpp: In static member function 'static bool Planner::_populate_block(block_t*, bool, const abce_long_t&, const xyze_pos_t&, feedRate_t, uint8_t, const float&)':
Marlin/src/module/planner.cpp:2407:19: error: 'maxj' was not declared in this scope
2407 | maxj = (max_jerk[axis] // mj : The max jerk setting for this axis
Marlin/src/module/planner.cpp:2407:36: error: 'axis' was not declared in this scope
Marlin/src/module/planner.cpp:2396:23: warning: unused variable 'extra_xyjerk' [-Wunused-variable]
2396 | constexpr float extra_xyjerk = 0;
*** [.pio/build/LPC1769/src/src/module/planner.cpp.o] Error 1
============================================ [FAILED] Took 38.39 seconds ============================================
Environment Status Duration
LPC1769 FAILED 00:00:38.385
======================================= 1 failed, 0 succeeded in 00:00:38.385 =======================================
