I’m trying to create a project using the ESP32CAM AI Thinker in the PlatformIO environment integrated with VS Code and espidf framework.
The problem is that I can include the esp-camera.h (and I can access the header) in my project, and it takes me to all the functions while developing the project. However, when trying to compile, I get errors like the functions are not defined
My platform.ini is configured as follows:
[platformio]
default_envs = release
[env]
platform = espressif32 @ 6.10.0
board = esp32cam
framework = espidf
esp32-camera
Universal-Arduino-Telegram-Bot
cJSON
ArduinoJson@6.18.5
;lib_extra_dirs =
; ${PROJECT_DIR}/lib/esp32-camera
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-DARDUINOJSON_USE_LONG_LONG=1
-DARDUINOJSON_ENABLE_COMMENTS=1
-DARDUINOJSON_ENABLE_NAN=1
-DARDUINOJSON_ENABLE_INFINITY=1
;-DUSE_TELEGRAM
-DUSE_WIFI
-DCONFIG_SCCB_CLK_FREQ=100000
-DCONFIG_CAMERA_JPEG_MODE_FRAME_SIZE_AUTO
-DCONFIG_IDF_TARGET_ESP32
[env:release]
extends = env
build_type = release
lib_deps = ${env.lib_deps}
build_flags = ${env.build_flags}
[env:debug]
extends = env
build_type = debug
debug_tool = esp-prog
upload_protocol = esp-prog
${env.build_flags}
-DCORE_DEBUG_LEVEL=5
(libdeps with = “github link”)
And I get the aforementioned error. I have also tried cloning the library directly into lib/ and executing the same steps.
If anyone has any idea where the error might be coming from when including the esp32-camera library, it would be greatly appreciated. Thanks!Preformatted text
