I am getting an error when trying to create a new mbed project with the SAML21-XPRO-B.
Is there something wrong with the installation?
Could not Initialise Project
PIO Core Call Error: The next files/directories have been created in C:\Users\Brendan\AppData\Roaming\SPB_Data\Documents\PlatformIO\Projects\SAML21Plained_testing
src - Put your source files here
lib - Put here project specific (private) libraries Error: [06/01/18 12:31:06] Processing saml21_xpro_b (platform: atmelsam; board: saml21_xpro_b; framework: mbed)
PLATFORM: Atmel SAM > Atmel SAML21-XPRO-B
SYSTEM: SAML21J18B 48MHz 32KB RAM (256KB Flash)
DEBUG: CURRENT(cmsis-dap) ON-BOARD(cmsis-dap) EXTERNAL(atmel-ice, blackmagic, jlink)
WindowsError: [Error 2] The system cannot find the file specified: 'C:\\Users\\Brendan\\AppData\\Roaming\\SPB_Data\\.platformio\\packages\\framework-mbed\\features\\nanostack\\FEATURE_NANOSTACK_FULL':
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 165:
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 541:
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\platforms\atmelsam\builder\main.py", line 162:
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\packages\tool-scons\script\..\engine\SCons\Environment.py", line 224:
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 69:
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 278:
SConscript(env.GetFrameworkScript(f))
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 604:
return method(*args, **kw)
File "C:\Users\Brendan\AppData\Roaming\SPB_Data\.platformio\platforms\atmelsam\builder\frameworks\mbed\mbed.py", line 174:
get_dynamic_manifest(lib, lib_config, extra_includes))
File "c:\users\brendan\appdata\roaming\spb_data\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 120:
self.process_extra_options()
File "c:\users\brendan\appdata\roaming\spb_data\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 258:
with util.cd(self.path):
File "c:\users\brendan\appdata\roaming\spb_data\.platformio\penv\lib\site-packages\platformio\util.py", line 107:
os.chdir(self.new_path)
[ERROR] Took 0.62 seconds
Report a problem
