Error compiling ESP32 Arduino can't find pins_arduino.h:
I have been using platformio succesfully for over a year on ESP32 with the Arduino framework.
Today I upgraded to Espressif32 v6.6.0.
I now get an error can’t find pins_arduino.h
In file included from C:/Users/davidg/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal.h:83,
from C:/Users/davidg/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:36,
from src/main.cpp:1:
C:/Users/davidg/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-gpio.h:29:10: fatal error: pins_arduino.h: No such file or directory
I get this error on a basic arduino framework in a new project.
I have tried removing the espressif folders in the .platformio as suggested on some post here. But I still get the error.
This is the basic project platformio.ini
I am running platformio on Windows 10.
What happens if you use
platform = espressif32@6.5.0
No change.
I tried installing an espressif version from 12 months ago, tried a clean and removing the arduino package folders, then allowing them to reinstall as per some of the posts here.
This is failing on a new project with the template arduino setup(0 and loop(). see attached.
Sounds like a broken framework!
Did you also delete the folders framework-arduinoespressif32 located in .platformio/packages/ ?
If not:
  • close VS Code
  • delete the folders
  • start VS Code
  • wait until PlatformIO has completed all tasks (reinstallation of the framework)
I did delete that folder. The dialogue sat there saying it had completed 100% but did not close.
I just repeated it and left it alone for a few minutes and it closed this time and it seems to have fixed it.
Thank you for your help.
i am solve with delet all folder in C:\Users\admin.platformio\packages
step:
1.close vscode
2. delet all folder in C:\Users\admin.platformio\packages
3. open youre project in vscode
4.wait proses intelisense index proses then build youre project.
