Hey. I use platformio as an extension for vscode. I really like platformio, but I don’t understand what happens when compiling libraries. Very rarely does a new connected library compile without errors. You have to fix the library code yourself. Often these are small things that can even be commented out or corrected, but this time I don’t know what to do. I am writing a small project with NodeMCU and Wifi Web Server. I install the latest versions of the ESP8266Wifi libraries from github. Pour the program into the board and get a compilation error. Error in the ESP8266mDNS library in the LEAmDNS.h file: 910: 9 and other Wifi libs (ESP8266WiFi, ESP8266WebServer)
Please help solve this error. I really like platformio and I don’t want to use the arduino ide anymore. Thanks for any help!
Error message:
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)
Collected 54 compatible libraries
|-- <ESP8266mDNS> 1.2
| |-- <ESP8266WiFi> 1.0
|-- <ESP8266WebServer> 1.0
Compiling .pioenvs\nodemcuv2\src\main.cpp.o
Compiling .pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFi.cpp.o
Compiling .pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Compiling .pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
In file included from lib\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
from src\main.cpp:2:
lib\ESP8266WiFi\src/WiFiClient.h:56:15: error: 'virtual int WiFiClient::connect(IPAddress, uint16_t)' marked override, but does not override
virtual int connect(IPAddress ip, uint16_t port) override;
lib\ESP8266WiFi\src/WiFiClient.h:76:16: error: 'virtual void WiFiClient::stop()' marked override, but does not override
virtual void stop() override { (void)stop(0); }
In file included from lib\ESP8266WiFi\src/ESP8266WiFi.h:40:0,
lib\ESP8266WiFi\src/WiFiServer.h:52:14: error: invalid abstract return type for member function 'WiFiClient WiFiServer::available(uint8_t*)'
WiFiClient available(uint8_t* status = NULL);
lib\ESP8266WiFi\src/WiFiClient.h:45:7: note: because the following virtual functions are pure within 'WiFiClient':
class WiFiClient : public Client, public SList<WiFiClient> {
In file included from lib\ESP8266WiFi\src/WiFiClient.h:27:0,
from lib\ESP8266WiFi\src/ESP8266WiFi.h:39,
C:\users\braga\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Client.h:29:21: note: virtual int Client::connect(const IPAddress&, uint16_t)
virtual int connect(CONST IPAddress& ip, uint16_t port) =0;
In file included from lib\ESP8266WiFi\src\ESP8266WiFi.h:39:0,
from lib\ESP8266WiFi\src\ESP8266WiFi.cpp:25:
lib\ESP8266WiFi\src\WiFiClient.h:56:15: error: 'virtual int WiFiClient::connect(IPAddress, uint16_t)' marked override, but does not override
lib\ESP8266WiFi\src\WiFiClient.h:76:16: error: 'virtual void WiFiClient::stop()' marked override, but does not override
In file included from lib\ESP8266WiFi\src\ESP8266WiFi.h:40:0,
lib\ESP8266WiFi\src\WiFiServer.h:52:14: error: invalid abstract return type for member function 'WiFiClient WiFiServer::available(uint8_t*)'
lib\ESP8266WiFi\src\WiFiClient.h:45:7: note: because the following virtual functions are pure within 'WiFiClient':
In file included from lib\ESP8266WiFi\src\WiFiClient.h:27:0,
from lib\ESP8266WiFi\src\ESP8266WiFi.h:39,
from lib\ESP8266WiFi\src\ESP8266WiFiAP.cpp:25:
from lib\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:27:
In file included from lib\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from lib\ESP8266WiFi\src/WiFiServerSecure.h:20,
from lib\ESP8266WiFi\src/ESP8266WiFi.h:41,
lib\ESP8266WiFi\src/WiFiClientSecureBearSSL.h: In member function 'int BearSSL::WiFiClientSecure::getMFLNStatus()':
lib\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:110:67: error: 'br_ssl_engine_get_mfln_negotiated' was not declared in this scope
return connected() && br_ssl_engine_get_mfln_negotiated(_eng);
In file included from lib\ESP8266WiFi\src/WiFiServerSecure.h:23:0,
lib\ESP8266WiFi\src/WiFiServerSecureBearSSL.h: At global scope:
lib\ESP8266WiFi\src/WiFiServerSecureBearSSL.h:59:22: error: invalid abstract return type for member function 'BearSSL::WiFiClientSecure BearSSL::WiFiServerSecure::available(uint8_t*)'
WiFiClientSecure available(uint8_t* status = NULL);
lib\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:34:7: note: because the following virtual functions are pure within 'BearSSL::WiFiClientSecure':
class WiFiClientSecure : public WiFiClient {
In file included from src\main.cpp:4:0:
lib\ESP8266WebServer\src/ESP8266WebServer.h:98:22: error: invalid abstract return type for member function 'virtual WiFiClient ESP8266WebServer::client()'
virtual WiFiClient client() { return _currentClient; }
lib\ESP8266WiFi\src/WiFiClient.h:45:7: note: since type 'WiFiClient' has pure virtual functions
from lib\ESP8266WiFi\src\WiFiServerSecure.h:20,
from lib\ESP8266WiFi\src\ESP8266WiFi.h:41,
In file included from lib\ESP8266WiFi\src\WiFiServerSecure.h:23:0,
lib\ESP8266WiFi\src\WiFiServerSecureBearSSL.h: At global scope:
lib\ESP8266WiFi\src\WiFiServerSecureBearSSL.h:59:22: error: invalid abstract return type for member function 'BearSSL::WiFiClientSecure BearSSL::WiFiServerSecure::available(uint8_t*)'
lib\ESP8266WebServer\src/ESP8266WebServer.h:169:15: error: cannot declare field 'ESP8266WebServer::_currentClient' to be of abstract type 'WiFiClient'
WiFiClient _currentClient;
lib\ESP8266WebServer\src/ESP8266WebServer.h: In member function 'virtual WiFiClient ESP8266WebServer::client()':
lib\ESP8266WebServer\src/ESP8266WebServer.h:98:40: error: cannot allocate an object of abstract type 'WiFiClient'
In file included from lib\ESP8266mDNS\src/ESP8266mDNS_Legacy.h:47:0,
from lib\ESP8266mDNS\src/ESP8266mDNS.h:45,
from src\main.cpp:5:
lib\ESP8266WiFi\src/WiFiUdp.h: At global scope:
lib\ESP8266WiFi\src/WiFiUdp.h:98:13: error: 'IPAddress WiFiUDP::remoteIP()' marked override, but does not override
IPAddress remoteIP() override;
lib\ESP8266WiFi\src/WiFiUdp.h:100:12: error: 'uint16_t WiFiUDP::remotePort()' marked override, but does not override
uint16_t remotePort() override;
In file included from lib\ESP8266mDNS\src/ESP8266mDNS.h:46:0,
lib\ESP8266mDNS\src/LEAmDNS.h:910:9: error: 'oneShotMs' in namespace 'esp8266::polledTimeout' does not name a type
esp8266::polledTimeout::oneShotMs m_Timeout; // Used for probes and announcements
lib\ESP8266mDNS\src/LEAmDNS.h:978:17: error: 'oneShotMs' in namespace 'esp8266::polledTimeout' does not name a type
esp8266::polledTimeout::oneShotMs m_TTLTimeout;
lib\ESP8266mDNS\src/LEAmDNS.h:1081:9: error: 'oneShotMs' in namespace 'esp8266::polledTimeout' does not name a type
esp8266::polledTimeout::oneShotMs m_ResendTimeout;
*** [.pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFiAP.cpp.o] Error 1
*** [.pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFi.cpp.o] Error 1
In file included from lib\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:45:0:
lib\ESP8266WiFi\src\WiFiUdp.h:98:13: error: 'IPAddress WiFiUDP::remoteIP()' marked override, but does not override
lib\ESP8266WiFi\src\WiFiUdp.h:100:12: error: 'uint16_t WiFiUDP::remotePort()' marked override, but does not override
lib\ESP8266WebServer\src/ESP8266WebServer.h:98:56: warning: control reaches end of non-void function [-Wreturn-type]
*** [.pioenvs\nodemcuv2\src\main.cpp.o] Error 1
*** [.pioenvs\nodemcuv2\libb11\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o] Error 1
============================================== [ERROR] Took 3.03 seconds ==============================================
** Source file to reproduce:**
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#ifndef STASSID
#define STASSID "your-ssid"
#define STAPSK "your-password"
const char* ssid = STASSID;
const char* password = STAPSK;
ESP8266WebServer server(80);
void handleRoot();
void handleNotFound();
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
delay(500);
MDNS.begin("esp8266");
server.on("/", handleRoot);
server.onNotFound(handleNotFound);
server.begin();
server.handleClient();
MDNS.update();
void handleRoot() {
server.send(200, "text/plain", "hello from esp8266!");
void handleNotFound() {
server.send(404, "text/plain", "File Not Found");
My platformio.ini file:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
lib_ldf_mode = chain
Operating system: Windows 10 Pro build 17134
PlatformIO Version: 3.6.7
