fuzzymind:
framework = mbed@5.4.0
You can’t annotate frameworks like that, the version annotation works for platform, see docs .
If you want to use mbed-os 5.4.0, I could only find a reference to
Updated mbed framework to 5.4.5/142
in ststm32 platform version 2.1.0 (link ).
However, I tried this with
[env:nucleo_f030r8]
platform = ststm32@2.1.0
framework = mbed
board = nucleo_f030r8
and while it did download the older platform, it immediately ran into the problem
- framework-mbed 3.142.0 (1.42)
- toolchain-gccarmnoneeabi 1.40804.0 (4.8.4)
AttributeError: 'SConsEnvironment' object has no attribute 'IsFileWithExt':
File "C:\Users\Max\AppData\Local\Programs\Python\Python38\Lib\site-packages\platformio\builder\main.py", line 178:
File "C:\Users\Max\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\Max\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\Max\.platformio\platforms\ststm32@2.1.0\builder\main.py", line 165:
File "C:\Users\Max\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\Max\AppData\Local\Programs\Python\Python38\Lib\site-packages\platformio\builder\tools\platformio.py", line 61:
env.ProcessProgramDeps()
File "C:\Users\Max\AppData\Local\Programs\Python\Python38\Lib\site-packages\platformio\builder\tools\platformio.py", line 128:
File "C:\Users\Max\AppData\Local\Programs\Python\Python38\Lib\site-packages\platformio\builder\tools\platformio.py", line 343:
SConscript(env.GetFrameworkScript(f), exports="env")
File "C:\Users\Max\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 654:
return method(*args, **kw)
File "C:\Users\Max\.platformio\platforms\ststm32@2.1.0\builder\frameworks\mbed\mbed.py", line 296:
target_dirs = get_mbed_dirs_data(join(FRAMEWORK_DIR, d), ignore_dirs)
File "C:\Users\Max\.platformio\platforms\ststm32@2.1.0\builder\frameworks\mbed\mbed.py", line 195:
if (any(env.IsFileWithExt(f, SRC_BUILD_EXT) for f in files)):
============================================= [FAILED] Took 172.85 seconds =============================================
Showing that tool-scons is making problems since some functions have been removed in newer versions (env.IsFileWithExt()).
I fixed it as follows
Write platofrmio.ini as
[env:nucleo_f030r8]
framework = mbed
extra_scripts = pre:fix_build.py
Create the file fix_build.py in the main directory of the project with content
Import("env")
from os.path import basename
def IsFileWithExt(file_, ext): # pylint: disable=W0613
if basename(file_).startswith("."):
return False
for e in ext:
if file_.endswith(".%s" % e):
return True
return False
# expose function
env.IsFileWithExt = IsFileWithExt
Build the project once. This will fail, but will download all the needed stuff. You shuold get an error like
TypeError: Unicode-objects must be encoded before hashing:
File "C:\Users\Max\.platformio\platforms\ststm32@2.1.0\builder\frameworks\mbed\mbed.py", line 304:
basename(src_dir), md5(src_dir).hexdigest()[:5]))
Open the file C:\Users\<user>\.platformio\platforms\ststm32@2.1.0\builder\frameworks\mbed\mbed.py in a text editor and go to line 304.
Exchange
with
basename(src_dir), md5(src_dir.encode('utf-8')).hexdigest()[:5]))
Rebuild the project.
This creates a successfully buildable project with that ancient mbed-os version for me.
>pio run
Processing nucleo_f030r8 (platform: ststm32@2.1.0; board: nucleo_f030r8; framework: mbed)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f030r8.html
PLATFORM: ST STM32 (2.1.0) > ST Nucleo F030R8
HARDWARE: STM32F030R8T6 48MHz, 8KB RAM, 64KB Flash
DEBUG: Current (stlink-v2-1) On-board (stlink-v2-1)
Found 8 compatible libraries
Compiling .pio\build\nucleo_f030r8\FrameworkMbed-hal-21f81\mbed_gpio.o
Compiling .pio\build\nucleo_f030r8\src\main.o
Generating LD script .pio\build\nucleo_f030r8\STM32F030X8.ld.link_script.ld
Linking .pio\build\nucleo_f030r8\firmware.elf
Checking size .pio\build\nucleo_f030r8\firmware.elf
Building .pio\build\nucleo_f030r8\firmware.bin
RAM: [= ] 11.1% (used 908 bytes from 8192 bytes)
Flash: [== ] 17.6% (used 11508 bytes from 65536 bytes)
=============== [SUCCESS] Took 4.88 seconds ===============
