Hello everyone. I now have a FreeRTOS project, and there is a problem compiling, as the title shows. I don’t know why this is, can you solve this problem for me?
Here is the project source code source code
src/ otherwise it won’t be compiled…Keil and IAR folders from the FreeRTOS/ports directory must be deleted, they contain source code meant for the assembler of these toolchains. Only GCC must prevailbuild_flags must be adapted accordingly-mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=softfp so that the assembly builds correctly (see here)Fixed project: here.
Also you did not choose a FreeRTOS heap, is that wanted?
Thank you for your answer. I have changed the project file according to your prompt, but there are still errors. I can’t understand the “platformio.ini” of “platformIO”. It is a bit difficult for me to configure it.
Here is the changed project source code
Did you see my download link? It should work for reference (https://drive.google.com/file/d/1cEiz0KXbT4IO96QakhHlN6vcuwhOcPMT/view?usp=sharing)
Have you changed the files in this link? Why is it the same as what I uploaded?
You are right, I somehow zipped the wrong file… Redoing…
Thank you for your answer. You solved a big problem for me.
