slime
May 14, 2020, 8:54pm
1
Hi
I’m getting the following errors when compiling the example “arduino-fade-all-pins” for the platform “ST STM8”
(PIO Home->Project Examples->[ST STM8]arduino-fade-all-pins):
*** [.pio\build\stm8sdisco\libFrameworkArduinoVariant.lib] Error 309
*** [.pio\build\stm8sblue\libFrameworkArduinoVariant.lib] Error 309
*** [.pio\build\s8uno\libFrameworkArduinoVariant.lib] Error 309
*** [.pio\build\mb208\libFrameworkArduinoVariant.lib] Error 309
*** [.pio\build\stm8sblack\libFrameworkArduinoVariant.lib] Error 309
How can I fixed it?
Extensions installed:
platformio.platformio-ide version 1.10.0
ms-vscode.cpptools version 0.25.0
platformio.ini:
[env:stm8sdisco]
platform = ststm8
board = stm8sdisco
[env:stm8sblue]
platform = ststm8
board = stm8sblue
[env:s8uno]
platform = ststm8
board = s8uno
[env:mb208]
platform = ststm8
board = mb208
[env:stm8sblack]
platform = ststm8
board = stm8sblack
Verbose:
> Executing task in folder 200514-152330-arduino-fade-all-pins: C:\Users\slime\.platformio\penv\Scripts\platformio.exe run <
Processing stm8sdisco (platform: ststm8; framework: arduino; board: stm8sdisco)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/stm8sdisco.html
PLATFORM: ST STM8 1.0.2 > ST STM8S-DISCOVERY
HARDWARE: STM8S105C6T6 16MHz, 2KB RAM, 32KB Flash
DEBUG: Current (stlink) On-board (stlink)
- framework-arduinoststm8 0.40.181216
- tool-stm8binutils 0.230.0 (2.30)
- toolchain-sdcc 1.30804.10766 (3.8.4)
Found 13 compatible libraries
Compiling .pio\build\stm8sdisco\src\fade-all-pins.c.rel
Archiving .pio\build\stm8sdisco\libFrameworkArduinoVariant.lib
Compiling .pio\build\stm8sdisco\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\Print-float.c.rel
C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
===================================== [FAILED] Took 2.82 seconds =====================================
Processing stm8sblue (platform: ststm8; framework: arduino; board: stm8sblue)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/stm8sblue.html
PLATFORM: ST STM8 1.0.2 > ST STM8S103F3 Breakout Board
HARDWARE: STM8S103F3P6 16MHz, 1KB RAM, 8KB Flash
Compiling .pio\build\stm8sblue\src\fade-all-pins.c.rel
Archiving .pio\build\stm8sblue\libFrameworkArduinoVariant.lib
Compiling .pio\build\stm8sblue\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\Print-float.c.rel
C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:38:2: warning: #warning "using uart1 for HardwareSerial"
===================================== [FAILED] Took 2.28 seconds =====================================
Processing s8uno (platform: ststm8; framework: arduino; board: s8uno)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/s8uno.html
PLATFORM: ST STM8 1.0.2 > sduino UNO (STM8S105K6)
HARDWARE: STM8S105K6T6 16MHz, 2KB RAM, 32KB Flash
Compiling .pio\build\s8uno\src\fade-all-pins.c.rel
Archiving .pio\build\s8uno\libFrameworkArduinoVariant.lib
Compiling .pio\build\s8uno\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\Print-float.c.rel
===================================== [FAILED] Took 2.46 seconds =====================================
Processing mb208 (platform: ststm8; framework: arduino; board: mb208)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/mb208.html
PLATFORM: ST STM8 1.0.2 > sduino MB (STM8S208MBT6B)
HARDWARE: STM8S208MBT6 16MHz, 6KB RAM, 128KB Flash
Compiling .pio\build\mb208\src\fade-all-pins.c.rel
Archiving .pio\build\mb208\libFrameworkArduinoVariant.lib
Compiling .pio\build\mb208\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\mb208\FrameworkArduino\Print-float.c.rel
===================================== [FAILED] Took 2.43 seconds =====================================
Processing stm8sblack (platform: ststm8; framework: arduino; board: stm8sblack)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/stm8sblack.html
PLATFORM: ST STM8 1.0.2 > ST STM8S105K4T6 Breakout Board
HARDWARE: STM8S105K4T6 16MHz, 2KB RAM, 16KB Flash
Compiling .pio\build\stm8sblack\src\fade-all-pins.c.rel
Archiving .pio\build\stm8sblack\libFrameworkArduinoVariant.lib
Compiling .pio\build\stm8sblack\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\Print-float.c.rel
===================================== [FAILED] Took 2.45 seconds =====================================
Environment Status Duration
stm8sdisco FAILED 00:00:02.819
stm8sblue FAILED 00:00:02.283
s8uno FAILED 00:00:02.458
mb208 FAILED 00:00:02.433
stm8sblack FAILED 00:00:02.455
=============================== 5 failed, 0 succeeded in 00:00:12.448 ===============================
Most interesstingly when I try to reproduce this, I get
*** [.pio\build\s8uno\libFrameworkArduinoVariant.lib] Error 123
alognside with a Windows error popup
Translating to
sdar.exe - Application error
The application could not be started (0xc000007b). Click on “OK” to close the application.
I’ll try and see what that is.
This issue seems to be known in *** [.pioenvs\stm8sblue\libFrameworkArduinoVariant.lib] Error 309 · Issue #12 · platformio/platform-ststm8 · GitHub .
Can you try adding
[env]
platform_packages = toolchain-sdcc @ 1.30603.9771
at the top of the platformio.ini of the example project?
slime
May 14, 2020, 10:17pm
4
Thanks for reply!
I added “platform_packages = toolchain-sdcc @ 1.30603.9771” at the top of “platformio.ini”, PlatformIO->PROJECT TASKS->Clean,
PlatformIO->PROJECT TASKS->Build.
Errors:
*** [.pio\build\stm8sdisco\libFrameworkArduino.lib] Error 5
*** [.pio\build\stm8sblue\libFrameworkArduino.lib] Error 5
*** [.pio\build\s8uno\libFrameworkArduino.lib] Error 5
*** [.pio\build\mb208\libFrameworkArduino.lib] Error 5
*** [.pio\build\stm8sblack\libFrameworkArduino.lib] Error 5
platformio.ini:
[env]
[env:stm8sdisco]
platform = ststm8
board = stm8sdisco
[env:stm8sblue]
platform = ststm8
board = stm8sblue
[env:s8uno]
platform = ststm8
board = s8uno
[env:mb208]
platform = ststm8
board = mb208
[env:stm8sblack]
platform = ststm8
board = stm8sblack
Verbose:
CONFIGURATION: ht tps://docs.platformio.org/page/boards/ststm8/stm8sdisco.html
- toolchain-sdcc 1.30603.9771 (3.6.3)
LDF: Library Dependency Finder -> h ttp://bit.ly/configure-pio-ldf
Compiling .pio\build\stm8sdisco\FrameworkArduino\Print.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\SPI.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\WMath.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\weak_atexit.c.rel
C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
Compiling .pio\build\stm8sdisco\FrameworkArduino\weak_initVariant.c.rel
C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
Compiling .pio\build\stm8sdisco\FrameworkArduino\weak_serialEvent.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\wiring.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\wiring_analog.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\wiring_digital.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\wiring_pulse.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\wiring_shift.c.rel
Archiving .pio\build\stm8sdisco\libFrameworkArduino.lib
==================================== [FAILED] Took 113.55 seconds ====================================
CONFIGURATION: ht tps://docs.platformio.org/page/boards/ststm8/stm8sblue.html
Compiling .pio\build\stm8sblue\FrameworkArduino\Print.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\SPI.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\WMath.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\weak_atexit.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\weak_initVariant.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\weak_serialEvent.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\wiring.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\wiring_analog.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\wiring_digital.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\wiring_pulse.c.rel
Compiling .pio\build\stm8sblue\FrameworkArduino\wiring_shift.c.rel
Archiving .pio\build\stm8sblue\libFrameworkArduino.lib
===================================== [FAILED] Took 6.72 seconds =====================================
CONFIGURATION: h ttps://docs.platformio.org/page/boards/ststm8/s8uno.html
Compiling .pio\build\s8uno\FrameworkArduino\Print.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\SPI.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\WMath.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\weak_atexit.c.rel
CC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
ompiling .pio\build\s8uno\FrameworkArduino\weak_initVariant.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\weak_serialEvent.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\wiring.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\wiring_analog.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\wiring_digital.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\wiring_pulse.c.rel
Compiling .pio\build\s8uno\FrameworkArduino\wiring_shift.c.rel
Archiving .pio\build\s8uno\libFrameworkArduino.lib
===================================== [FAILED] Took 7.71 seconds =====================================
CONFIGURATION: ht tps://docs.platformio.org/page/boards/ststm8/mb208.html
LDF: Library Dependency Finder -> ht tp://bit.ly/configure-pio-ldf
Compiling .pio\build\mb208\FrameworkArduino\Print.c.rel
Compiling .pio\build\mb208\FrameworkArduino\SPI.c.rel
Compiling .pio\build\mb208\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\mb208\FrameworkArduino\WMath.c.rel
Compiling .pio\build\mb208\FrameworkArduino\weak_atexit.c.rel
Compiling .pio\build\mb208\FrameworkArduino\weak_initVariant.c.rel
Compiling .pio\build\mb208\FrameworkArduino\weak_serialEvent.c.rel
Compiling .pio\build\mb208\FrameworkArduino\wiring.c.rel
Compiling .pio\build\mb208\FrameworkArduino\wiring_analog.c.rel
Compiling .pio\build\mb208\FrameworkArduino\wiring_digital.c.rel
Compiling .pio\build\mb208\FrameworkArduino\wiring_pulse.c.rel
Compiling .pio\build\mb208\FrameworkArduino\wiring_shift.c.rel
Archiving .pio\build\mb208\libFrameworkArduino.lib
===================================== [FAILED] Took 9.83 seconds =====================================
CONFIGURATION: htt ps://docs.platformio.org/page/boards/ststm8/stm8sblack.html
Compiling .pio\build\stm8sblack\FrameworkArduino\Print.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\SPI.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\WMath.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\weak_atexit.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\weak_initVariant.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\weak_serialEvent.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\wiring.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\wiring_analog.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\wiring_digital.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\wiring_pulse.c.rel
Compiling .pio\build\stm8sblack\FrameworkArduino\wiring_shift.c.rel
Archiving .pio\build\stm8sblack\libFrameworkArduino.lib
===================================== [FAILED] Took 7.47 seconds =====================================
stm8sdisco FAILED 00:01:53.554
stm8sblue FAILED 00:00:06.718
s8uno FAILED 00:00:07.707
mb208 FAILED 00:00:09.830
stm8sblack FAILED 00:00:07.471
=============================== 5 failed, 0 succeeded in 00:02:25.280 ===============================
Okay that’s the same error as mine. So rolling back the toolchain doesn’t help.
@valeros , are you able to reproduce this?
slime
May 14, 2020, 11:41pm
6
I builded the same project on another computer (both tests was done in Windows 10) and it result in the following errors:
Verbose:
Line 29: *** [.pio\build\stm8sdisco\libFrameworkArduinoVariant.lib] Error 3221225781
Line 58: *** [.pio\build\stm8sblue\libFrameworkArduinoVariant.lib] Error 3221225781
Line 87: *** [.pio\build\s8uno\libFrameworkArduinoVariant.lib] Error 3221225781
Line 116: *** [.pio\build\mb208\libFrameworkArduinoVariant.lib] Error 3221225781
Line 145: *** [.pio\build\stm8sblack\libFrameworkArduinoVariant.lib] Error 3221225781
> Executing task in folder 200514-202511-arduino-fade-all-pins: C:\Users\slime\.platformio\penv\Scripts\platformio.exe run <
Found 12 compatible libraries
=========================================================================================== [FAILED] Took 5.25 seconds ===========================================================================================
=========================================================================================== [FAILED] Took 5.15 seconds ===========================================================================================
CONFIGURATION: ht tps://docs.platformio.org/page/boards/ststm8/s8uno.html
=========================================================================================== [FAILED] Took 5.14 seconds ===========================================================================================
CONFIGURATION: ht tps://docs.platformio.org/page/boards/ststm8/stm8sblack.html
=========================================================================================== [FAILED] Took 5.02 seconds ===========================================================================================
stm8sdisco FAILED 00:00:05.255
stm8sblue FAILED 00:00:05.154
s8uno FAILED 00:00:05.136
mb208 FAILED 00:00:05.151
stm8sblack FAILED 00:00:05.023
===================================================================================== 5 failed, 0 succeeded in 00:00:25.719 =====================================================================================
Weirdly, I can’t repro this… nor does it break worse!
Indexing .pio\build\stm8sblack\libFrameworkArduinoVariant.lib
C:\users\peter\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
C:\users\peter\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
C:\users\peter\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
C:/users/peter/.platformio/packages/framework-arduinoststm8/variants/stm8sblack/pins_arduino.h:279: warning 158: overflow in implicit constant conversion
Indexing .pio\build\stm8sblack\libFrameworkArduino.lib
Linking .pio\build\stm8sblack\firmware.elf
Checking size .pio\build\stm8sblack\firmware.elf
sdcc -o .pio\build\stm8sblack\firmware.ihx -mstm8 --nostdlib --code-size 16384 --iram-size 2048 --out-fmt-ihx .pio\build\stm8sblack\src\fade-all-pins.c.rel -LC:\users\peter\.platformio\packages\toolchain-sdcc\lib\stm8 -LC:\users\peter\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\lib .pio\build\stm8sblack\libFrameworkArduinoVariant.lib .pio\build\stm8sblack\libFrameworkArduino.lib -lstm8 -lSTM8S105
RAM: [ ] 3.7% (used 75 bytes from 2048 bytes)
Flash: [== ] 18.6% (used 3042 bytes from 16384 bytes)
======================================================================== [SUCCESS] Took 11.18 seconds ========================================================================
stm8sdisco SUCCESS 00:00:11.601
stm8sblue SUCCESS 00:00:02.974
s8uno SUCCESS 00:00:11.196
mb208 SUCCESS 00:00:11.267
stm8sblack SUCCESS 00:00:11.177
======================================================================== 5 succeeded in 00:00:48.215 ========================================================================
Can you try an actual verbose build, and see if something comes up from the compiler?
slime
May 15, 2020, 10:43am
8
Verbose build:
> Executing task in folder 200514-152330-arduino-fade-all-pins: C:\Users\slime\.platformio\penv\Scripts\platformio.exe run --verbose <
Processing stm8sdisco (platform: ststm8; framework: arduino; board: stm8sdisco; platform_packages: toolchain-sdcc @ 1.30603.9771)
sdcc -o .pio\build\stm8sdisco\src\fade-all-pins.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -Iinclude -Isrc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco src\fade-all-pins.c
sdar rcs .pio\build\stm8sdisco\libFrameworkArduinoVariant.lib
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\HardwareSerial.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino
-IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\Print-float.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framewoC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
rk-arduiC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
noststm8\vC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13:
ariants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print-float.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\Print.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\SPI.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\SPI.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\WInterrupts.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\WMath.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\r
amework-arduinoststm8\cores\sduino\WMath.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\weak_atexit.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\weak_initVariant.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_initVariant.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\weak_serialEvent.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_serialEvent.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\wiring.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\wiring_analog.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_analog.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\wiring_digital.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino
-IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_digital.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\wiring_pulse.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT
-D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framew*o** [.pio\build\stm8sdisco\libFrameworkArduino.lib] Error
5
rk-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_pulse.c
sdcc -o .pio\build\stm8sdisco\FrameworkArduino\wiring_shift.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_DISCOVERY -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT
-D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sdisco C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_shift.c
sdar rcs .pio\build\stm8sdisco\libFrameworkArduino.lib .pio\build\stm8sdisco\FrameworkArduino\HardwareSerial.c.rel .pio\build\stm8sdisco\FrameworkArduino\Print-float.c.rel .pio\build\stm8sdisco\FrameworkArduino\Print.c.rel .pio\build\stm8sdisco\FrameworkArduino\SPI.c.rel .pio\build\stm8sdisco\FrameworkArduino\WInterrupts.c.rel .pio\build\stm8sdisco\FrameworkArduino\WMath.c.rel .pio\build\stm8sdisco\FrameworkArduino\weak_atexit.c.rel .pio\build\stm8sdisco\FrameworkArduino\weak_initVariant.c.rel .pio\build\stm8sdisco\FrameworkArduino\weak_serialEvent.c.rel .pio\build\stm8sdisco\FrameworkArduino\wiring.c.rel .pio\build\stm8sdisco\FrameworkArduino\wiring_analog.c.rel .pio\build\stm8sdisco\FrameworkArduino\wiring_digital.c.rel .pio\build\stm8sdisco\FrameworkArduino\wiring_pulse.c.rel .pio\build\stm8sdisco\FrameworkArduino\wiring_shift.c.rel
===================================== [FAILED] Took 9.50 seconds =====================================
Processing stm8sblue (platform: ststm8; framework: arduino; board: stm8sblue; platform_packages: toolchain-sdcc @ 1.30603.9771)
sdcc -o .pio\build\stm8sblue\src\fade-all-pins.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -Iinclude -Isrc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard src\fade-all-pins.c
sdar rcs .pio\build\stm8sblue\libFrameworkArduinoVariant.lib
sdcc -o .pio\build\stm8sblue\FrameworkArduino\HardwareSerial.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:38:2: warning: #warning "using uart1 for HardwareSerial"
T -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packageC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
s\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platforC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
mio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\Print-float.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print-float.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\Print.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\SPI.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303
-DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\SPI.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\WInterrupts.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\WMath.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WMath.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\weak_atexit.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\weak_initVariant.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_initVariant.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\weak_serialEvent.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_serialEvent.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\wiring.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\wiring_analog.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_analog.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\wiring_digital.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_digital.c
sdcc -o .pio\build\stm8sblue\FrameworkArduino\wiring_pulse.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinosts*** [.pio\build\stm8sblue\libFrameworkArduino.lib] Error 5
sdcc -o .pio\build\stm8sblue\FrameworkArduino\wiring_shift.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLUE -DSTM8S103 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\standard C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_shift.c
sdar rcs .pio\build\stm8sblue\libFrameworkArduino.lib .pio\build\stm8sblue\FrameworkArduino\HardwareSerial.c.rel .pio\build\stm8sblue\FrameworkArduino\Print-float.c.rel .pio\build\stm8sblue\FrameworkArduino\Print.c.rel .pio\build\stm8sblue\FrameworkArduino\SPI.c.rel .pio\build\stm8sblue\FrameworkArduino\WInterrupts.c.rel .pio\build\stm8sblue\FrameworkArduino\WMath.c.rel .pio\build\stm8sblue\FrameworkArduino\weak_atexit.c.rel .pio\build\stm8sblue\FrameworkArduino\weak_initVariant.c.rel .pio\build\stm8sblue\FrameworkArduino\weak_serialEvent.c.rel .pio\build\stm8sblue\FrameworkArduino\wiring.c.rel .pio\build\stm8sblue\FrameworkArduino\wiring_analog.c.rel .pio\build\stm8sblue\FrameworkArduino\wiring_digital.c.rel .pio\build\stm8sblue\FrameworkArduino\wiring_pulse.c.rel .pio\build\stm8sblue\FrameworkArduino\wiring_shift.c.rel
Processing s8uno (platform: ststm8; framework: arduino; board: s8uno; platform_packages: toolchain-sdcc @ 1.30603.9771)
sdcc -o .pio\build\s8uno\src\fade-all-pins.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -Iinclude -Isrc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\frameC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
work-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
\variants\s8uno src\fade-all-pins.cC
sdar rcs .pio\build\s8uno\libFrameworkArduinoVariant.lib
sdcc -o .pio\build\s8uno\FrameworkArduino\HardwareSerial.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c
sdcc -o .pio\build\s8uno\FrameworkArduino\Print-float.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print-float.c
sdcc -o .pio\build\s8uno\FrameworkArduino\Print.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print.c
sdcc -o .pio\build\s8uno\FrameworkArduino\SPI.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\SPI.c
sdcc -o .pio\build\s8uno\FrameworkArduino\WInterrupts.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c
sdcc -o .pio\build\s8uno\FrameworkArduino\WMath.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WMath.c
sdcc -o .pio\build\s8uno\FrameworkArduino\weak_atexit.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c
sdcc -o .pio\build\s8uno\FrameworkArduino\weak_initVariant.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_initVariant.c
sdcc -o .pio\build\s8uno\FrameworkArduino\weak_serialEvent.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_serialEvent.c
sdcc -o .pio\build\s8uno\FrameworkArduino\wiring.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framewo*** [.pio\build\s8uno\libFrameworkArduino.lib] Error 5
rk-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring.c
sdcc -o .pio\build\s8uno\FrameworkArduino\wiring_analog.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_analog.c
sdcc -o .pio\build\s8uno\FrameworkArduino\wiring_digital.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.pa
tformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_digital.c
slime
May 15, 2020, 10:45am
9
sdcc -o .pio\build\s8uno\FrameworkArduino\wiring_pulse.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_pulse.c
sdcc -o .pio\build\s8uno\FrameworkArduino\wiring_shift.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_UNO -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\s8uno C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_shift.c
sdar rcs .pio\build\s8uno\libFrameworkArduino.lib .pio\build\s8uno\FrameworkArduino\HardwareSerial.c.rel .pio\build\s8uno\FrameworkArduino\Print-float.c.rel .pio\build\s8uno\FrameworkArduino\Print.c.rel .pio\build\s8uno\FrameworkArduino\SPI.c.rel .pio\build\s8uno\FrameworkArduino\WInterrupts.c.rel .pio\build\s8uno\FrameworkArduino\WMath.c.rel .pio\build\s8uno\FrameworkArduino\weak_atexit.c.rel .pio\build\s8uno\FrameworkArduino\weak_initVariant.c.rel .pio\build\s8uno\FrameworkArduino\weak_serialEvent.c.rel .pio\build\s8uno\FrameworkArduino\wiring.c.rel .pio\build\s8uno\FrameworkArduino\wiring_analog.c.rel .pio\build\s8uno\FrameworkArduino\wiring_digital.c.rel .pio\build\s8uno\FrameworkArduino\wiring_pulse.c.rel .pio\build\s8uno\FrameworkArduino\wiring_shift.c.rel
===================================== [FAILED] Took 9.61 seconds =====================================
Processing mb208 (platform: ststm8; framework: arduino; board: mb208; platform_packages: toolchain-sdcc @ 1.30603.9771)------------------------------------------------------------------------------------------------------
sdcc -o .pio\build\mb208\src\fade-all-pins.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__
-Iinclude -Isrc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 src\fade-all-pins.c
sdar rcs .pio\build\mb208\libFrameworkArduinoVariant.lib
sdcc -o .pio\build\mb208\FrameworkArduino\HardwareSerial.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c
sdcc -o .pio\build\mb208\FrameworkArduino\Print-float.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=1080C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:38:2: warning: #warning "using uart1 for HardwareSerial"
2 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print-float.c
sdcc -o .pio\build\mb208\FrameworkArduino\Print.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINTC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
-D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\pacC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
kages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print.c
sdcc -o .pio\build\mb208\FrameworkArduino\SPI.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\SPI.c
sdcc -o .pio\build\mb208\FrameworkArduino\WInterrupts.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c
sdcc -o .pio\build\mb208\FrameworkArduino\WMath.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WMath.c
sdcc -o .pio\build\mb208\FrameworkArduino\weak_atexit.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c
sdcc -o .pio\build\mb208\FrameworkArduino\weak_initVariant.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_initVariant.c
sdcc -o .pio\build\mb208\FrameworkArduino\weak_serialEvent.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_serialEvent.c
sdcc -o .pio\build\mb208\FrameworkArduino\wiring.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring.c
sdcc -o .pio\build\mb208\FrameworkArduino\wiring_analog.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_analog.c
sdcc -o .pio\build\mb208\FrameworkArduino\wiring_digital.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Us*e** [.pio\build\mb208\libFrameworkArduino.lib] Error 5
sdcc -o .pio\build\mb208\FrameworkArduino\wiring_pulse.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_pulse.c
sdcc -o .pio\build\mb208\FrameworkArduino\wiring_shift.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_MB -DSTM8S208 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\mb208 C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_shift.c
sdar rcs .pio\build\mb208\libFrameworkArduino.lib .pio\build\mb208\FrameworkArduino\HardwareSerial.c.rel .pio\build\mb208\FrameworkArduino\Print-float.c.rel .pio\build\mb208\FrameworkArduino\Print.c.rel .pio\build\mb208\FrameworkArduino\SPI.c.rel .pio\build\mb208\FrameworkArduino\WInterrupts.c.rel .pio\build\mb208\FrameworkArduino\WMath.c.rel .pio\build\mb208\FrameworkArduino\weak_atexit.c.rel .pio\build\mb208\FrameworkArduino\weak_initVariant.c.rel .pio\build\mb208\FrameworkArduino\weak_serialEvent.c.rel .pio\build\mb208\FrameworkArduino\wiring.c.rel .pio\build\mb208\FrameworkArduino\wiring_analog.c.rel .pio\build\mb208\FrameworkArduino\wiring_digital.c.rel .pio\build\mb208\FrameworkArduino\wiring_pulse.c.rel .pio\build\mb208\FrameworkArduino\wiring_shift.c.rel
===================================== [FAILED] Took 8.55 seconds =====================================
Processing stm8sblack (platform: ststm8; framework: arduino; board: stm8sblack; platform_packages: toolchain-sdcc @ 1.30603.9771)
sdcc -o .pio\build\stm8sblack\src\fade-all-pins.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -Iinclude -Isrc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack src\fade-all-pins.c
sdar rcs .pio\build\stm8sblack\libFrameworkArduinoVariant.lib
sdcc -o .pio\build\stm8sblack\FrameworkArduino\HardwareSerial.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
-DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packagC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
es\framework-arduinoststm8\cores\sduino -IC:\Users\RC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
icardo\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\Print-float.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print-float.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\Print.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\Print.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\SPI.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\SPI.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\WInterrupts.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\s
ers\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\WMath.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\WMath.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\weak_atexit.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_atexit.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\weak_initVariant.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT
-D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_initVariant.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\weak_serialEvent.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT
-D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\weak_serialEvent.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\wiring.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\wiring_analog.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_analog.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\wiring_digital.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_digital.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\wiring_pulse.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_pulse.c
sdcc -o .pio\build\stm8sblack\FrameworkArduino\wiring_shift.c.rel -c -mstm8 -DF_CPU=16000000L -DPLATFORMIO=40303 -DSTM8S_BLACK -DSTM8S105 -DARDUINO_ARCH_STM8 -DARDUINO=10802 -Ddouble=float -DUSE_STDINT -D__PROG_TYPES_COMPAT__ -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\STM8S_StdPeriph_Driver\inc -IC:\Users\slime\.platformio\packages\framework-arduinoststm8\variants\stm8sblack C:\Users\slime\.platformio\packages\framework-arduinoststm8\cores\sduino\wiring_shift*.** [.pio\build\stm8sblack\libFrameworkArduino.lib]
Error 5
c
sdar rcs .pio\build\stm8sblack\libFrameworkArduino.lib .pio\build\stm8sblack\FrameworkArduino\HardwareSerial.c.rel .pio\build\stm8sblack\FrameworkArduino\Print-float.c.rel .pio\build\stm8sblack\FrameworkArduino\Print.c.rel .pio\build\stm8sblack\FrameworkArduino\SPI.c.rel .pio\build\stm8sblack\FrameworkArduino\WInterrupts.c.rel .pio\build\stm8sblack\FrameworkArduino\WMath.c.rel .pio\build\stm8sblack\FrameworkArduino\weak_atexit.c.rel .pio\build\stm8sblack\FrameworkArduino\weak_initVariant.c.rel .pio\build\stm8sblack\FrameworkArduino\weak_serialEvent.c.rel .pio\build\stm8sblack\FrameworkArduino\wiring.c.rel .pio\build\stm8sblack\FrameworkArduino\wiring_analog.c.rel .pio\build\stm8sblack\FrameworkArduino\wiring_digital.c.rel .pio\build\stm8sblack\FrameworkArduino\wiring_pulse.c.rel .pio\build\stm8sblack\FrameworkArduino\wiring_shift.c.rel
===================================== [FAILED] Took 8.82 seconds =====================================
Environment Status Duration
stm8sdisco FAILED 00:00:09.499
stm8sblue FAILED 00:00:07.713
s8uno FAILED 00:00:09.609
mb208 FAILED 00:00:08.551
stm8sblack FAILED 00:00:08.816
=============================== 5 failed, 0 succeeded in 00:00:44.188 ===============================
vampir8
November 10, 2020, 9:34am
10
Processing stm8sdisco (platform: ststm8; board: stm8sdisco; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/stm8sdisco.html
PLATFORM: ST STM8 (1.0.2) > ST STM8S-DISCOVERY
HARDWARE: STM8S105C6T6 16MHz, 2KB RAM, 32KB Flash
DEBUG: Current (stlink) On-board (stlink)
- framework-arduinoststm8 0.40.181216
- tool-stm8binutils 0.230.0 (2.30)
- toolchain-sdcc 1.30804.10766 (3.8.4)
Found 66 compatible libraries
Compiling .pio\build\stm8sdisco\src\main.c.rel
Archiving .pio\build\stm8sdisco\libFrameworkArduinoVariant.lib
Compiling .pio\build\stm8sdisco\FrameworkArduino\HardwareSerial.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\Print-float.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\Print.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\SPI.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\WInterrupts.c.rel
Compiling .pio\build\stm8sdisco\FrameworkArduino\WMath.c.rel
*** [.pio\build\stm8sdisco\libFrameworkArduinoVariant.lib] Error 309
C:\Users\admin\.platformio\packages\framework-arduinoststm8\cores\sduino\HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
C:\Users\admin\.platformio\packages\framework-arduinoststm8\cores\sduino\WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
============================================================================================= [FAILED] Took 1.76 seconds =============================================================================================
The terminal process "C:\Users\admin\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task in folder test_stm8: C:\Users\admin\.platformio\penv\Scripts\platformio.exe run <
Processing stm8sdisco (platform: ststm8; board: stm8sblack; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm8/stm8sblack.html
PLATFORM: ST STM8 (1.0.2) > ST STM8S105K4T6 Breakout Board
HARDWARE: STM8S105K4T6 16MHz, 2KB RAM, 16KB Flash
============================================================================================= [FAILED] Took 1.87 seconds =============================================================================================
Renaming main.cpp ->main.c doesn’t help.
vampir8
November 18, 2020, 2:28pm
12
Vsc, platformIO is installed on two computers.
I have the same error on both and I do not know where to look for the cause
I tried to use
[env:stm8sdisco]
platform = ststm8@1.0.0
[env:stm8sdisco]
platform = ststm8@1.0.1
As I said I have the same error on Windows. It’s somehow coming from the compiler linker, but don’t know where. I hoped @valeros could help here.
Interesting on Linux I get an error but a different one.
$ pio run
Processing stm8sblack (platform: ststm8; board: stm8sblack; framework: arduino)
Platform Manager: Installing ststm8
Platform Manager: ststm8 @ 1.0.2 has been installed!
The platform 'ststm8' has been successfully installed!
The rest of the packages will be installed later depending on your build environment.
Tool Manager: Installing toolchain-sdcc @ ~1.30804.10766
Tool Manager: toolchain-sdcc @ 1.30804.10766 has been installed!
Tool Manager: Installing framework-arduinoststm8 @ 0.40.181216
Tool Manager: framework-arduinoststm8 @ 0.40.181216 has been installed!
Tool Manager: Installing tool-stm8binutils @ 0.230.0
Tool Manager: tool-stm8binutils @ 0.230.0 has been installed!
Found 15 compatible libraries
Compiling .pio/build/stm8sblack/src/main.c.rel
Archiving .pio/build/stm8sblack/libFrameworkArduinoVariant.lib
Indexing .pio/build/stm8sblack/libFrameworkArduinoVariant.lib
Compiling .pio/build/stm8sblack/FrameworkArduino/HardwareSerial.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/Print-float.c.rel
/home/max/.platformio/packages/framework-arduinoststm8/cores/sduino/HardwareSerial.c:72:2: warning: #warning "using uart2 for HardwareSerial"
Compiling .pio/build/stm8sblack/FrameworkArduino/Print.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/SPI.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/WInterrupts.c.rel
/home/max/.platformio/packages/framework-arduinoststm8/cores/sduino/WInterrupts.c:73: warning 85: in function attachInterrupt unreferenced function argument : 'mode'
Compiling .pio/build/stm8sblack/FrameworkArduino/WMath.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/weak_atexit.c.rel
/home/max/.platformio/packages/framework-arduinoststm8/cores/sduino/weak_atexit.c:13: warning 85: in function atexit unreferenced function argument : 'func'
Compiling .pio/build/stm8sblack/FrameworkArduino/weak_initVariant.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/weak_serialEvent.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/wiring.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/wiring_analog.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/wiring_digital.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/wiring_pulse.c.rel
Compiling .pio/build/stm8sblack/FrameworkArduino/wiring_shift.c.rel
/home/max/.platformio/packages/framework-arduinoststm8/variants/stm8sblack/pins_arduino.h:279: warning 158: overflow in implicit constant conversion
Archiving .pio/build/stm8sblack/libFrameworkArduino.lib
Indexing .pio/build/stm8sblack/libFrameworkArduino.lib
Linking .pio/build/stm8sblack/firmware.elf
ASlink-Warning-No definition of area SSEG
*** [.pio/build/stm8sblack/firmware.elf] Error 1
============================================================================================ [FAILED] Took 30.44 seconds =
Lol this actually works with a fix from sdcc compiler sseg error with 4.0 · Issue #76 · tenbaht/sduino · GitHub .
Set src/main.c as
/* compilation fix. reference main function. */
void main(void);
void (*dummy_variable) () = main;
/* actual code.. */
void setup(){}
void loop(){}
does this work on Windows too?
$ pio run
Checking size .pio/build/stm8sblack/firmware.elf
sdcc -o .pio/build/stm8sblack/firmware.ihx -mstm8 --nostdlib --code-size 16384 --iram-size 2048 --out-fmt-ihx .pio/build/stm8sblack/src/main.c.rel -L/home/max/.platformio/packages/toolchain-sdcc/share/sdcc/lib/stm8 -L/home/max/.platformio/packages/framework-arduinoststm8/STM8S_StdPeriph_Driver/lib .pio/build/stm8sblack/libFrameworkArduinoVariant.lib .pio/build/stm8sblack/libFrameworkArduino.lib -lstm8 -lSTM8S105
RAM: [ ] 3.5% (used 72 bytes from 2048 bytes)
Flash: [= ] 13.1% (used 2148 bytes from 16384 bytes)
============================================================================================ [SUCCESS] Took 2.16 seconds ====
Actually Linux works perfectly fine with the arduino-fade-all-pins example.
$ cp -r ~/.platformio/platforms/ststm8/examples/arduino-fade-all-pins/ .
$ cd arduino-fade-all-pins
$ pio run
Flash: [== ] 18.5% (used 3032 bytes from 16384 bytes)
============================================================================================ [SUCCESS] Took 2.21 seconds ============================================================================================
stm8sdisco SUCCESS 00:00:02.106
stm8sblue SUCCESS 00:00:02.095
s8uno SUCCESS 00:00:02.109
mb208 SUCCESS 00:00:02.155
stm8sblack SUCCESS 00:00:02.215
============= 5 succeeded in 00:00:10.680 =============
success in all cases.
vampir8
November 18, 2020, 2:59pm
17
on Windows with
void main(void);
/* actual code.. */
void setup(){}
void loop(){}
nothing has changed
> Executing task in folder test_stm8: C:\Users\admin\.platformio\penv\Scripts\pio.exe run <
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
====================================================================================================== [FAILED] Took 1.72 seconds ======================================================================================================
The terminal process "C:\Users\admin\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
vampir8
November 18, 2020, 3:17pm
18
Ok. I think it worked. Try download and install
https://sourceforge.net/projects/sdcc/files/
Next copy files from
C:\Program Files\SDCC
to
C:\Users\admin\.platformio\packages\toolchain-sdcc
void main(void);
/* actual code.. */
void setup(){}
void loop(){}
Here is a result
Checking size .pio\build\stm8sdisco\firmware.elf
Flash: [= ] 6.5% (used 2127 bytes from 32768 bytes)
====================================================================================================== [SUCCESS] Took 1.08 seconds ======================================================================================================
vampir8
November 18, 2020, 3:25pm
19
if I quote
//void main(void);
//void (*dummy_variable) () = main;
then other error
*** [.pio\build\stm8sdisco\firmware.elf] Error 1
Just to make sure you used version 4.0.0 from Small Device C Compiler (SDCC) - Browse /sdcc-win64/4.0.0 at SourceForge.net ? Previous version is 3.8.4.
With that new compiler version, does the arduino-fade-all-pins example compile on Windows too, without code modifications?
