Erreur platform IO Build
Bonjour a tous, sur le logiciel, je compile un tout petit programme, il me note, je comprend pas, il n’y a pas erreur sur mon program main.cpp
#include <WebServer.h>
#include <WiFi.h>
#include "BluetoothSerial.h"
// put function declarations here:
int myFunction(int, int);
// WIFI
const char\* ssid = "ma-box";
const char\* password = "mot_de_passe";
WebServer server(80);
String htmlPage() {
  String ip = WiFi.localIP().toString();
  String html;
  html = "<!doctype html>";
  html += "";
  html += "";
  html += "ESP32-C3 opérationnel";
  html += "";
  html += "html,body{height:100%;margin:0}";
  html +=
      "body{display:flex;align-items:center;justify-content:center;background:"
      "linear-gradient(135deg,#f7fafc,#edf2f7)}";
  html +=
      ".card{font-family:system-ui,-apple-system,Segoe "
      "UI,Roboto,Ubuntu,Cantarell,‘Noto Sans’,‘Helvetica "
      "Neue’,Arial,sans-serif;";
  html +=
      "background:#fff;padding:28px 26px;border-radius:16px;box-shadow:0 10px "
      "25px rgba(0,0,0,.08);text-align:center;max-width:560px}";
  html += "h1{margin:0 0 10px 0;font-size:1.6rem;line-height:1.3}";
  html += "p{margin:.4rem 0;color:#4a5568}";
  html +=
      ".pill{display:inline-block;margin-top:10px;padding:6px "
      "10px;border-radius:999px;background:#f1f5f9;color:#334155;font-size:."
      "9rem}";
  html + @keyframe @keyframes ".blink{animation:b 1.2s ease-in-out infinite}";
  html += "@keyframes b{0%,100%{opacity:1}50%{opacity:.35}}";
  html += "";
  html += "";
  html += "👋 Bonjour, moi c’est l’ESP32‑C3 ";
  html += "ESP32‑C3 opérationnel ✓";
  html += "Adresse IP : **" + ip + "**";
  html += "Ouvre cette URL depuis ton réseau local : `http://" + ip + "/`";
  html += "";
  return html;
void handleRoot() {
  // important: préciser le charset pour les accents
  server.send(200, "text/html; charset=utf-8", htmlPage());
// Blutooth
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run \`make menuconfig\` to and enable it
BluetoothSerial SerialBT;
  // WIFI + BLUETOOTH
  // Bluetooth
  SerialBT.begin("ESP32_GG");  // Bluetooth device name
  Serial.println("Service demaré, connecté bluetooth!");
  // WIFI
  delay(800);
  Serial.println("\\n=== ESP32-C3 – Page web jolie (UTF-8) ===");
  WiFi.mode(WIFI_STA);
  WiFi.setSleep(false);
  Serial.printf("Connexion au Wi-Fi \\" % s\\"…\\n", ssid);
  WiFi.begin(ssid, password);
    delay(300);
    Serial.print(‘.’);
  Serial.println();
  Serial.println("✅ Wi-Fi connecté");
  Serial.print("➡️  Adresse IP : ");
  server.on("/", handleRoot);
  server.begin();
  Serial.println(
      "🌍 Serveur HTTP démarré — ouvre l’IP ci-dessus dans ton navigateur.");
  int result = myFunction(2, 3);
  server.handleClient();
}  // put function definitions here:
int myFunction(int x, int y) { return x + y; }
RAM:   [==        ]  17.9% (used 58812 bytes from 327680 bytes)
Error: The program size (1554337 bytes) is greater than maximum allowed (1310720 bytes)
Flash: [=====*** [checkprogsize] Explicit exit, status 1
=====]  118.6% (used 1554337 bytes from 1310720 bytes)
================================================ \[FAILED\] Took 6.96 seconds =======
The default flash partition table scheme is too small to hold your application code. Since you likely have an ESP32 with like 4MByte of flash or more, you should choose a partition table that gives you more APP0 space.
See documentation
https://docs.platformio.org/en/latest/platforms/espressif32.html#partition-tables
E.g., add to platformio.ini:
board_build.partitions = huge_app.csv
Thanks a lot,
Je debute avec esp32, jai une ESP32 Wroom 32U, j’ai choisi ce type de carte
[env:denky32]
board = denky32
debug_build_flags = -Os
For a standard ESP32 WROOM 32U, you would usually choose a standard definition like
For exact settings, see esp32dev.json & denky32.json. They have some slight differences.
