I need help. I have been having problem with Platform IO Debug Mode for Window 10.
Sometimes the debug mode works just as expected. But, today it usually gets stuck and is unable to reach the first break point.
It is a very simple code for blinking the led. It is supposed to stop at the setup().
Here is what is printed the debug console when it gets stuck.
PLATFORM: Espressif 32 1.12.2 > Espressif ESP32 Dev Module
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.7% (used 15436 bytes from 327680 bytes)
Flash: [== ] 16.6% (used 216961 bytes from 1310720 bytes)
========================= [SUCCESS] Took 2.39 seconds =========================
Reading symbols from c:\Users\mikel\Documents\PlatformIO\Projects\ESP32 Test\.pio\build\esp32dev\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 45 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 101 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 104 KB
Info : Using flash size 48 KB
undefined debug reason 7 - target needs reset
0x40000400 in ?? ()
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
** Programming Started **
auto erase enabled
auto erase enabled
wrote 16384 bytes from file C:/Users/mikel/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.748064s (21.389 KiB/s)
** Programming Finished **
** Verify Started **
read 15872 bytes from file C:/Users/mikel/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.293994s (52.722 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/mikel/Documents/PlatformIO/Projects/ESP32 Test/.pio/build/esp32dev/partitions.bin in 0.570648s (7.010 KiB/s)
read 3072 bytes from file c:/Users/mikel/Documents/PlatformIO/Projects/ESP32 Test/.pio/build/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.254855s (11.771 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/mikel/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.622247s (12.857 KiB/s)
read 8192 bytes from file C:/Users/mikel/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.274340s (29.161 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 217088 bytes from file c:/Users/mikel/Documents/PlatformIO/Projects/ESP32 Test/.pio/build/esp32dev/firmware.bin in 2.510124s (84.458 KiB/s)
read 217072 bytes from file c:/Users/mikel/Documents/PlatformIO/Projects/ESP32 Test/.pio/build/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 0.967099s (219.196 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
Temporary breakpoint 1 at 0x400d0c04: file src\main.cpp, line 6.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
I also want to show the case when the debugger works.
Here is what is printed the debug console when it works.
Verified OK **
read 217072 bytes from file c:/Users/mikel/Documents/PlatformIO/Projects/ESP32 Test/.pio/build/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 0.963730s (219.962 KiB/s)
contents match
** Verified OK **
Info : Target halted. PRO_CPU: PC=0x400D3BD8 APP_CPU: PC=0x400D0C04 (active)
Info : Detected debug stubs @ 3ffc0ca4 on core0 of target 'esp32'
[New Thread 1073464940]
[New Thread 1073463528]
[New Thread 1073467632]
[New Thread 1073455716]
[New Thread 1073445320]
[New Thread 1073446424]
[New Thread 1073462116]
[Switching to Thread 1073447000]
1, setup () at src\main.cpp:6
6 void setup() {
Info : Target halted. PRO_CPU: PC=0x400E91EA APP_CPU: PC=0x400D0C3B (active)
Breakpoint
3, loop () at src\main.cpp:20
20 count++;
Breakpoint
20 count++;
Breakpoint
20 count++;
