Here is the output when I try to erase flash:
> Executing task in folder esp01-wifi-config: C:\Users\arun\.platformio\penv\Scripts\platformio.exe run --target erase <
Processing esp01_1m (platform: espressif8266; board: esp01_1m; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 2.5.3 > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.20701.0 (2.7.1)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Found 30 compatible libraries
|-- <WifiManager> 0.15.0
| |-- <DNSServer> 1.1.1
| | |-- <ESP8266WiFi> 1.0
| |-- <ESP8266WebServer> 1.0
Looking for serial port...
Auto-detected: COM5
Erasing...
esptool.py v2.8
Serial port COM5
File "C:\Users\arun\.platformio\packages\tool-esptoolpy\esptool.py", line 3201, in <module>
_main()
File "C:\Users\arun\.platformio\packages\tool-esptoolpy\esptool.py", line 3194, in _main
main()
File "C:\Users\arun\.platformio\packages\tool-esptoolpy\esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:\Users\arun\.platformio\packages\tool-esptoolpy\esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "c:\users\arun\.platformio\penv\lib\site-packages\serial\__init__.py", line 88, in serial_for_url
instance.open()
File "c:\users\arun\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM5': PermissionError(13, 'Access is denied.', None, 5)
*** [erase] Error 1
=============================================================== [FAILED] Took 9.04 seconds ===============================================================
However, I am able to flash code onto it.
