I’ve compiled the toolchain for FreeBSD… but placing them in packages folder under toolchain-xtensa does not work.
Installing tool-scons package:
Already installed
Installing toolchain-xtensa package:
Error: The package 'toolchain-xtensa' is not available for your system 'freebsd_amd64'
how can i force platformio to accept what is there and not try to install it. ?
Please edit ~/.platformio/appstate.json and add to installed_packages this
"toolchain-xtensa": {
"version": 9999,
"time": 1456513654
P.S: Could you share somewhere this toolchain? We will add it to our package repository. Thanks.
think i need to add more than that.
I get
The platform 'espressif' has not been installed yet. Would you like to install it now? [y/N]:
even with that added
and it is then removed after i’ve done an update.
and of course i can share them (if they work)
here is the file
{"last_version": "2.9.1", "telemetry": {"backup": [{"qt": 1463602490.821116, "av": "2.9.1", "cd": "Run", "cd4": 1, "cd3": "run", "t": "screenview"}, {"el": "board=esp12e&framework=arduino&platform=espressif", "qt": 1463602492.068014, "av": "2.9.1", "ea": "Run", "ec": "Env", "cd": "Run", "cd4": 1, "cd3": "run", "t": "event"}, {"el": "tool-scons", "qt": 1463602564.013285, "ea": "Install", "ec": "PackageManager", "cd": "Run", "cd4": 1, "av": "2.9.1", "cd3": "run", "t": "event"}, {"exf": 0, "exd": "NonSystemPackage: The package 'toolchain-xtensa' is not available for your system 'freebsd_amd64'", "qt": 1463602564.014437, "cd": "Run", "cd4": 1, "av": "2.9.1", "cd3": "run", "t": "exception"}]}, "installed_packages": {"tool-scons": {"version": 1, "time": 1463602564}}, "cid": "b9f1ea95-d3bb-5d1a-8693-096c9dbe0553"}
Try this
"installed_platforms": [
"espressif"
"tool-scons": {
"version": 1,
"time": 1463602564
"version": 999,
"time": 1463602564
ok got it passed that… but it seems that all the requirements are not there
xtensa-lx106-elf-ar rcs .pioenvs/esp12e/libFrameworkArduinoVariant.a
xtensa-lx106-elf-g++: not found
xtensa-lx106-elf-ranlib .pioenvs/esp12e/libFrameworkArduinoVariant.a
xtensa-lx106-elf-g++ -o .pioenvs/esp12e/FrameworkArduino/Esp.o -c -fno-rtti -fno-exceptions -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -ffunction-sections -fdata-sections -MMD -DF_CPU=80000000L -D__ets__ -DICACHE_FLASH -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_ESP12 -DARDUINO=20200 -U__STRICT_ANSI__ -I/root/.platformio/packages/framework-arduinoespressif/tools/sdk/include -I/root/.platformio/packages/framework-arduinoespressif/tools/sdk/lwip/include -I.pioenvs/esp12e/FrameworkArduino -I.pioenvs/esp12e/FrameworkArduinoVariant .pioenvs/esp12e/FrameworkArduino/Esp.cpp
scons: *** [.pioenvs/esp12e/src/tmp_ino_to.o] Error 127
xtensa-lx106-elf-g++ -o .pioenvs/esp12e/FrameworkArduino/FS.o -c -fno-rtti -fno-exceptions -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -ffunction-sections -fdata-sections -MMD -DF_CPU=80000000L -D__ets__ -DICACHE_FLASH -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_ESP12 -DARDUINO=20200 -U__STRICT_ANSI__ -I/root/.platformio/packages/framework-arduinoespressif/tools/sdk/include -I/root/.platformio/packages/framework-arduinoespressif/tools/sdk/lwip/include -I.pioenvs/esp12e/FrameworkArduino -I.pioenvs/esp12e/FrameworkArduinoVariant .pioenvs/esp12e/FrameworkArduino/FS.cpp
scons: *** [.pioenvs/esp12e/FrameworkArduino/Esp.o] Error 127
scons: *** [.pioenvs/esp12e/FrameworkArduino/FS.o] Error 127
seems there are some files missing from
root@test:/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin # ls
xtensa-lx106-elf-addr2line xtensa-lx106-elf-gcov
xtensa-lx106-elf-ar xtensa-lx106-elf-gdb
xtensa-lx106-elf-as xtensa-lx106-elf-gprof
xtensa-lx106-elf-c++filt xtensa-lx106-elf-ld
xtensa-lx106-elf-cc xtensa-lx106-elf-ld.bfd
xtensa-lx106-elf-cpp xtensa-lx106-elf-nm
xtensa-lx106-elf-ct-ng.config xtensa-lx106-elf-objcopy
xtensa-lx106-elf-elfedit xtensa-lx106-elf-objdump
xtensa-lx106-elf-gcc xtensa-lx106-elf-ranlib
xtensa-lx106-elf-gcc-4.8.2 xtensa-lx106-elf-readelf
xtensa-lx106-elf-gcc-ar xtensa-lx106-elf-size
xtensa-lx106-elf-gcc-nm xtensa-lx106-elf-strings
xtensa-lx106-elf-gcc-ranlib xtensa-lx106-elf-strip
what i guess i should have
xtensa-lx106-elf-addr2line xtensa-lx106-elf-gcc-ranlib
xtensa-lx106-elf-ar xtensa-lx106-elf-gcov
xtensa-lx106-elf-as xtensa-lx106-elf-gdb
xtensa-lx106-elf-c++ xtensa-lx106-elf-gprof
xtensa-lx106-elf-g++ xtensa-lx106-elf-ranlib
xtensa-lx106-elf-gcc xtensa-lx106-elf-readelf
xtensa-lx106-elf-gcc-4.8.2 xtensa-lx106-elf-size
xtensa-lx106-elf-gcc-ar xtensa-lx106-elf-strings
xtensa-lx106-elf-gcc-nm xtensa-lx106-elf-strip
Seems to work. I found an alternative
http://www.esp8266.com/viewtopic.php?f=9&t=478
that says it builds g++
Could you share this toolchain somewhere?
I’m uploading it now, but its the one missing g++.
The other crosstool needs some other dependancies so it failed. No usable m4 in $PATH
here you go
https://www.dropbox.com/s/8e8131zpy6jovs8/xtensa-lx106-elf.zip?dl=0
so i can’t get the g++ version to compile.
[ERROR] checking for suitable m4... configure: error: No usable m4 in $PATH or /usr/5bin (see config.log for reasons).
but i have m4 installed and in the right path, so stuck
got it working. g++ and all… compiled a test sketch
"/root/.platformio/packages/tool-esptool/esptool" -eo "/root/.platformio/packages/framework-arduinoespressif/bootloaders/eboot/eboot.elf" -bo .pioenvs/esp12e/firmware.bin -bm dio -bf 40 -bz 4M -bs .text -bp 4096 -ec -eo .pioenvs/esp12e/firmware.elf -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
"xtensa-lx106-elf-size" -B -d .pioenvs/esp12e/firmware.elf
/root/.platformio/packages/tool-esptool/esptool: not found
scons: *** [.pioenvs/esp12e/firmware.bin] Error 127
text data bss dec hex filename
218494 888 29488 248870 3cc26 .pioenvs/esp12e/firmware.elf
The next major stumbling block is getting esptool compiled. This is going to be a problem… but at least if it is going to be a cloud compiler that should not be necessary
here is a link to the toolchain
https://www.dropbox.com/s/1fiwqztyxyw0tfd/xtensa-lx106-elf%2Bg%2B%2B.zip?dl=0
Looks like it is worth following up. compile time on my laptop 33 seconds, on freebsd 7.5 seconds. so i’d be keen to get this cloud compiling working:)
Which problems do you have?
So igrr has just fixed it
were good to go!
https://github.com/igrr/esptool-ck/commit/8a87f8a023005b951683405ad127d4be05c28504
esptool and toolchain working for freebsd. Need to actually test the binary though…
Great!!! Now, we are waiting for the binaries and would be glad to host them in PlatformIO Package Storage for other users.
ok, i confirm that the toolchain works, as does esptool.
I have built mkspiffs but it requires gcc 4.7 with some dependencies… i could only get the executable to work by symlinking in a
ln -s /usr/local/lib/gcc48/libstdc++.so.6 /usr/lib/libstdc++.so.6
which is not so ideal i guess.
