Enable Dynamixel_SDK and EthernetInterface
I’m starting using NUCLEO-F767ZI, Dynamixel servo motors and Ethernet. Then, I have two problems.
First problem ( I maybe resolved ) is that PlatformIO doesn’t include dynamixel_sdk.h properly. After I change mbed version from 6 to 5.15.6, the .h file works.
However, Second problem is that #include “EthernetInterface.h” doesn’t work properly. Before changing the mbed version, this .h file worked.
How can I resolve these problems?
Followings are my .ini file and error (EthernetInterface.h doesn’t works):
[env:nucleo_f767zi]
platform = ststm32
board = nucleo_f767zi
framework = mbed
platform_packages =
    framework-mbed@~6.51506.201227
    https://github.com/ROBOTIS-GIT/DynamixelSDK.git
    -I.pio/libdeps/nucleo_f767zi/DynamixelSDK/include
    -D MBED_CONF_NSAPI_PRESENT
In file included from C:\Users\USERNAME\.platformio\packages\framework-mbed@6.51506.231105\targets\TARGET_STM\USBPhyHw.h:21,
                 from C:\Users\USERNAME\.platformio\packages\framework-mbed@6.51506.231105\targets\TARGET_STM\USBPhy_STM32.cpp:20:
C:\Users\USERNAME\.platformio\packages\framework-mbed@6.51506.231105/mbed.h:26:10: fatal error: netsocket/nsapi.h: No such file or directory
   26 | #include "netsocket/nsapi.h"
compilation terminated.
Does https://github.com/platformio/platform-ststm32/tree/master/examples/mbed-rtos-ethernet-tls compile for you? That one uses the Ethernet API and stuff.
I compled it on mbed 6.17.0 just following the instructions in README.
I added following to .ini file to change mbed version to 5.15.6 for including dynamixel_sdk.h:
[env:nucleo_f767zi]
platform = ststm32
framework = mbed
platform_packages =
Then I got another error:
src\main.cpp:2:10: fatal error: mbed_trace.h: No such file or directory
* Looking for mbed_trace.h dependency? Check our library registry!
* CLI  > platformio lib search "header:mbed_trace.h"
* Web  > https://registry.platformio.org/search?q=header:mbed_trace.h
    2 | #include "mbed_trace.h"
*** [.pio\build\nucleo_f767zi\src\main.o] Error 1
Visiting the Web, I changed .ini:
[env:nucleo_f767zi]
platform = ststm32
framework = mbed
platform_packages =
    armmbed/mbed_trace@^1.3.0
However,
Resolving nucleo_f767zi dependencies...
Library Manager: Installing armmbed/mbed_trace @ ^1.3.0
UnknownPackageError: Could not find the package with 'armmbed/mbed_trace @ ^1.3.0' requirements for your system 'windows_amd64'
I think you used a wrong name for the library - it should be armmbed/mbed-trace
I modified:
[env:nucleo_f767zi]
platform = ststm32
framework = mbed
platform_packages =
    armmbed/mbed-trace@^1.3.0
but error:
In file included from .pio\libdeps\nucleo_f767zi\mbed-trace\source\mbed_trace.c:28:
.pio\libdeps\nucleo_f767zi\mbed-trace/mbed-trace/mbed_trace.h:56:10: fatal error: ns_types.h: No such file or directory
* Looking for ns_types.h dependency? Check our library registry!
* CLI  > platformio lib search "header:ns_types.h"
* Web  > https://registry.platformio.org/search?q=header:ns_types.h
   56 | #include "ns_types.h"
*** [.pio\build\nucleo_f767zi\lib834\mbed-trace\mbed_trace.o] Error 1
    2 | #include <mbed_trace.h>
The URL for ns_types.h shows two packages, but neither are ns_types.h. How can I resolve these?
