I’m trying to save a certificate on the NVS of the ESP32. If I use this line:
-DCOMPONENT_EMBED_TXTFILES = scr/test.cer
I get the next lines in my output:
*** [.pio\build\featheresp32\firmware.elf] Implicit dependency C:\Users\xxxxxx.platformio\platforms\espressif32\builder=’ not found, needed by target .pio\build\featheresp32\firmware.elf’.
================================================================================ [ERROR] Took 14.59 seconds ================================================================================
And here’s my platforimio.ini file:
[env:featheresp32]
board = featheresp32
-DCOMPONENT_EMBED_TXTFILES = scr/fabnetAWS.cer
;debug_tool = esp-prog
;debug_init_break = tbreak setup
board_build.partitions = default.csv
ArduinoJSon@<6.0
PubSubClient
Any suggestions?
Regards,
David
