I’ve got a problem getting a root cert to embed properly in my project. I’ve followed, to the best that I can tell, the instructions in (link removed because I’m a new user) but I’m getting a failure:
rhettg ➜ ~/Documents/PlatformIO/Projects/YakasaurDemo (main) $ pio --version
PlatformIO Core, version 6.1.15
rhettg ➜ ~/Documents/PlatformIO/Projects/YakasaurDemo (main) $ pio run
Processing esp32-s3-devkitc-1 (platform: espressif32; board: esp32-s3-devkitc-1; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1.html
PLATFORM: Espressif 32 (6.6.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50201.0 (5.2.1)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
- tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 13.2.0+20230928
- toolchain-xtensa-esp32s3 @ 12.2.0+20230208
Warning! Flash memory size mismatch detected. Expected 8MB, found 2MB!
Please select a proper value in your `sdkconfig.defaults` or via the `menuconfig` target!
Found 0 compatible libraries
Linking .pio/build/esp32-s3-devkitc-1/bootloader.elf
Linking .pio/build/esp32-s3-devkitc-1/firmware.elf
/Users/rhettg/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pio/build/esp32-s3-devkitc-1/src/main.o:(.literal.send_image+0x2c): undefined reference to `_binary_isrg_root_pem_start'
*** [.pio/build/esp32-s3-devkitc-1/firmware.elf] Error 1
========================================================= [FAILED] Took 8.07 seconds =========================================================
My platform.ini:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
framework = espidf
monitor_filters = direct
board_build.embed_txtfiles =
src/isrg_root.pem
According to the docs:
In case with ESP-IDF, these files also need to be specified in CMakeLists.txt using the target_add_binary_data function.
The link to the example project doesn’t work, but I found Espressif’s documentation (but I can’t link it) which indicates how to use target_add_binary_data
. So I did that:
cmake_minimum_required(VERSION 3.16.0)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(YakasaurDemo)
target_add_binary_data(YakasaurDemo.elf "src/isrg_root.pem" TEXT)
The platformio docs also mention:
With the ESP-IDF framework symbol names should not contain path to the files, for example _binary_private_pem_key_start instead of _binary_src_private_pem_key_start.
So I’m referencing them like this in main.c
extern const char isrg_root_pem_start[] asm("_binary_isrg_root_pem_start");
extern const char isrg_root_pem_end[] asm("_binary_isrg_root_pem_end");
Full project is here on GitHub.
What am I missing? Any help would be very appreciated.
