I try to create unit tests, but I can’t get it working. I’ve read the documentation several times, but I can’t find the problem.
In order to limit the sources of errors as much as possible, I made a simple case.
The compilation goes well, the upload goes well, the tests do not succeed.
Here is my configuration: Linux (xubuntu xfce), Clion as IDE, Teensy 4.1, Unity as test framework. PlatformIO Core, version 6.1.4a1
I have read several posts on the forum and issues on Github about similar symptoms. I have tested the solutions described there without success.
for example, I tried this without success: Teensy 4.1 Unit Testing Issue
My platformio.ini configuration file is the following (I tried several combinations and left in comment what I had already tried):
[env:test]
platform = teensy
board = teensy41
upload_protocol = teensy-cli
upload_port = /dev/ttyACM0
test_framework = unity
throwtheswitch/Unity@^2.5.2
test_build_src = false
extra_scripts = post:test/after_upload.py
;extra_scripts = post:test/add_delay.py
;test_port = /dev/ttyACM0
;test_speed = 9600
;monitor_port = /dev/ttyACM0
;monitor_dtr = 1
Extra scripts are:
after_upload.py
# Spongman suggestion
# https://github.com/platformio/platformio-core/issues/3742#issuecomment-1003454439
import time
import serial
Import("env")
def after_upload(source, target, env):
port = env.GetProjectOption("monitor_port")
print("waiting for " + port + " ...")
while True:
try:
s = serial.Serial(port)
break
except:
pass
print("after_upload script: Done!")
env.AddPostAction("upload", after_upload)
add_delay.py
# Max Gerhardt solution
import time
Import("env")
if "test" in env.GetBuildType():
print(env.GetBuildType())
print("add_delay script: Done!")
env.AddPostAction("upload", lambda *_, **__: time.sleep(2))
My code to be tested in /lib/ClassToTest/ClassToTest.h:
#ifndef TEST_TESTING_CLASSTOTEST_H
#define TEST_TESTING_CLASSTOTEST_H
#include "Arduino.h"
class ClassToTest {
private:
boolean _result;
public:
ClassToTest();
boolean myFunction() const{
Serial.println("ClassToTest::myFunction called");
return _result;
boolean mySecondFunction() const{
Serial.println("ClassToTest::mySecondFunction called");
return _result;
#endif //TEST_TESTING_CLASSTOTEST_H
ClassToTest::ClassToTest() : _result(true) {}
My test code in /test/test_ClassToTest.cpp:
#include "unity.h"
#include "ClassToTest.h"
ClassToTest ctt;
void setUp(void) {
ctt = ClassToTest();
Serial.println("test setUp");
void tearDown(void) {
Serial.println("test tearDown");
void test_myFunction(void) {
boolean result = ctt.myFunction();
TEST_ASSERT_EQUAL_MESSAGE(true,result, "test myFunction message");
Serial.println("test myFunction");
void test_mySecondFunction(void) {
// TEST NEVER PASS HERE, WHY?!
boolean result = ctt.mySecondFunction();
TEST_ASSERT_EQUAL_MESSAGE(true,result, "test mySecondFunction message");
Serial.println("test mySecondFunction");
int runUnityTests(void) {
Serial.println("runUnityTests");
UNITY_BEGIN();
RUN_TEST(test_myFunction);
RUN_TEST(test_mySecondFunction);
// NEVER REACH THAT LINE
Serial.println("AFTER RUN_TEST");
int result = UNITY_END();
Serial.print(result);
return result;
Serial.begin(9600); //suggestion: https://github.com/platformio/platformio-core/issues/3742#issuecomment-806186699
delay(5000);
Serial.println("Starting Tests");
runUnityTests();
Serial.println("Test done");
// LED DON'T BLINK
digitalWrite(13, HIGH);
delay(100);
digitalWrite(13, LOW);
delay(500);
The terminal output is:
(base) _@_:~/CLionProjects/test_testing$ pio test -e "test" -vvv
Collected 1 tests (*)
Processing * in test environment
Building & Uploading...
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy41.html
PLATFORM: Teensy (4.16.0) > Teensy 4.1
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 7.75MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy @ 1.156.0 (1.56)
- tool-teensy @ 1.155.0 (1.55)
- toolchain-gccarmnoneeabi @ 1.50401.190816 (5.4.1)
Found 94 compatible libraries
|-- ClassToTest (License: Unknown, Path: /home/CLionProjects/test_testing/lib/ClassToTest)
|-- Unity @ 2.5.2 (License: MIT, Path: /home/CLionProjects/test_testing/.pio/libdeps/test/Unity)
Building in test mode
arm-none-eabi-g++ -o .pio/build/test/test/test_ClassToTest.cpp.o -c -fno-exceptions -felide-constructors -fno-rtti -std=gnu++14 -Wno-error=narrowing -fpermissive -fno-threadsafe-statics -Wall -ffunction-sections -fdata-sections -mthumb -mcpu=cortex-m7 -nostdlib -fsingle-precision-constant -mfloat-abi=hard -mfpu=fpv5-d16 -O2 -DPLATFORMIO=60104 -D__IMXRT1062__ -DARDUINO_TEENSY41 -DUSB_SERIAL -DARDUINO=10805 -DTEENSYDUINO=156 -DCORE_TEENSY -DF_CPU=600000000 -DLAYOUT_US_ENGLISH -DPIO_UNIT_TESTING -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -Iinclude -Isrc -I.pio/libdeps/test/Unity/src -Itest -Ilib/ClassToTest -Itest -I/home/.platformio/packages/framework-arduinoteensy/cores/teensy4 test/test_ClassToTest.cpp
arm-none-eabi-g++ -o .pio/build/test/libcc1/ClassToTest/ClassToTest.cpp.o -c -fno-exceptions -felide-constructors -fno-rtti -std=gnu++14 -Wno-error=narrowing -fpermissive -fno-threadsafe-statics -Wall -ffunction-sections -fdata-sections -mthumb -mcpu=cortex-m7 -nostdlib -fsingle-precision-constant -mfloat-abi=hard -mfpu=fpv5-d16 -O2 -DPLATFORMIO=60104 -D__IMXRT1062__ -DARDUINO_TEENSY41 -DUSB_SERIAL -DARDUINO=10805 -DTEENSYDUINO=156 -DCORE_TEENSY -DF_CPU=600000000 -DLAYOUT_US_ENGLISH -DPIO_UNIT_TESTING -Ilib/ClassToTest -I/home/.platformio/packages/framework-arduinoteensy/cores/teensy4 lib/ClassToTest/ClassToTest.cpp
arm-none-eabi-gcc-ar rc .pio/build/test/libcc1/libClassToTest.a .pio/build/test/libcc1/ClassToTest/ClassToTest.cpp.o
arm-none-eabi-gcc-ar -s .pio/build/test/libcc1/libClassToTest.a
arm-none-eabi-g++ -o .pio/build/test/firmware.elf -T imxrt1062_t41.ld -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m7 -Wl,--defsym=__rtc_localtime=1658357985 -mfloat-abi=hard -mfpu=fpv5-d16 -O2 .pio/build/test/test/test_ClassToTest.cpp.o -L/home/.platformio/packages/framework-arduinoteensy/cores/teensy4 -L.pio/build/test -Wl,--start-group .pio/build/test/libcc1/libClassToTest.a .pio/build/test/libf88/libUnity.a .pio/build/test/libFrameworkArduino.a -larm_cortexM7lfsp_math -lm -lstdc++ -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pio/build/test/firmware.elf"])
teensy_size .pio/build/test/firmware.elf
arm-none-eabi-objcopy -O ihex -R .eeprom .pio/build/test/firmware.elf .pio/build/test/firmware.hex
teensy_size: Memory Usage on Teensy 4.1:
teensy_size: FLASH: code:17552, data:6040, headers:9172 free for files:8093700
teensy_size: RAM1: variables:6784, code:14880, padding:17888 free for local variables:484736
teensy_size: RAM2: variables:12384 free for malloc/new:511904
<lambda>(["upload"], [".pio/build/test/firmware.hex"])
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-cli
teensy_reboot -s
teensy_loader_cli -mmcu=imxrt1062 -w -s -v .pio/build/test/firmware.hex
Teensy Loader, Command Line, Version 2.2
Read ".pio/build/test/firmware.hex": 32768 bytes, 1.6% usage
Error opening USB device: Resource temporarily unavailable
Waiting for Teensy device...
(hint: press the reset button)
Found HalfKay Bootloader
Programming.............................
Booting
Testing...
If you don't see any output for the first 10 secs, please reset board (press reset button)
Starting Tests
runUnityTests
test setUp
test myFunction
test tearDown
device reports readiness to read but returned no data (device disconnected or multiple access on port?)
-------------------------------------------------------------------------- test:* [ERRORED] Took 17.62 seconds --------------------------------------------------------------------------
======================================================================================== SUMMARY ========================================================================================
Environment Test Status Duration
teensy41 * SKIPPED
test * ERRORED 00:00:17.618
======================================================================= 1 test cases: 0 succeeded in 00:00:17.618 =======================================================================
When I use pio device monitor, the output loops with:
Disconnected (device reports readiness to read but returned no data (device disconnected or multiple access on port?))
Reconnecting to /dev/ttyACM0 . Connected!
Starting Tests
runUnityTests
test setUp
test myFunction
test tearDown
Starting Tests
runUnityTests
test setUp
I can’t figure out what I’m not doing right.
Do you have any suggestions?
