Yeap, as I wrote in the starting topic I see fast blinking of the led – then it’s uploaded the test code.
So, it works, but not possible to see results of the test – after the Broken pipe error appears the test marked as ERRORED, which is not quite helpful for TDD…
I would be quite baffled by this but then the default PlatformIO implementation for the Unity I/O functions kills it maybe. Specifically I can image that Serial.end() which is called during UNITY_END(); shuts down the USB serial port completely, resulting in a broken pipe.
I’ve added some debugging prints in the setup() and it seems that the Broken pipe error occurred before even the test start executing:
void setup()
// this delay is required, otherwise test results
// would not be communicated to the host terminal
delay(1000);
UNITY_BEGIN();
RUN_TEST(simple_test);
UNITY_END();
I use the cli command to start test: pio test --upload-port /dev/ttyACM0 --test-port /dev/ttyACM0 --environment leonardo
and I see the Broken pipe error in the terminal immediately after the upload finished, much before 1 second delay ends up and the RUN_TEST() even started…
Is another program accessing the port maybe? Something like the infamous brltty service? What’s the output of sudo dmesg | tail -n50 after the pipe breaks?
No brltty service, but dmesg shows each time I run the test 2 consecutive disconnections of the Arduino Leonardo with different idProduct:
[ 1810.138979] usb 1-2: USB disconnect, device number 10
[ 1810.488209] usb 1-2: new full-speed USB device number 11 using xhci_hcd
[ 1810.638580] usb 1-2: New USB device found, idVendor=2341, idProduct=0036, bcdDevice= 0.01
[ 1810.638588] usb 1-2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1810.638591] usb 1-2: Product: Arduino Leonardo
[ 1810.638593] usb 1-2: Manufacturer: Arduino LLC
[ 1810.640662] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
[ 1813.005040] usb 1-2: USB disconnect, device number 11
[ 1813.316350] usb 1-2: new full-speed USB device number 12 using xhci_hcd
[ 1813.469629] usb 1-2: New USB device found, idVendor=2341, idProduct=8036, bcdDevice= 1.00
[ 1813.469634] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1813.469636] usb 1-2: Product: Arduino Leonardo
[ 1813.469638] usb 1-2: Manufacturer: Arduino LLC
[ 1813.471652] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
Each time these two groups of messages appears and device numbers increased all the time, here they are 10 and 11, next run it would be 12, 13 etc.
In the terminal I see per each test run:
Disconnected (device reports readiness to read but returned no data (device disconnected or multiple access on port?))
Reconnecting to /dev/ttyACM0 . Connected!
Reconnecting to /dev/ttyACM0 Connected!
test/test_blink/test_main.cpp:48:simple_test:PASS
test/test_blink/test_main.cpp:49:led_on_test:PASS
test/test_blink/test_main.cpp:50:led_off_test:PASS
3 Tests 0 Failures 0 Ignored
OK
So, the test works but not responded to pio due to this Broken pipe.
