ESPIDF
Though i have installed the library i am getting this issue
Scanning dependencies…
|-- dht_espidf
Linking .pio\build\esp32doit-devkit-v1\bootloader.elf
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
c:/users/dhung/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/12.2.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32doit-devkit-v1\src\main.o:(.literal.app_main+0x10): undefined reference to read_dht_sensor_data(gpio_num_t, dht_type_t, dht_reading*)' c:/users/dhung/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32doit-devkit-v1\src\main.o: in function
app_main’:
D:\program\vscode\platform.io\DTH_SensorTest/src/main.cpp:15: undefined reference to `read_dht_sensor_data(gpio_num_t, dht_type_t, dht_reading*)’
*** [.pio\build\esp32doit-devkit-v1\firmware.elf] Error 1
Library github link : GitHub - infincia/dht_espidf: An ESP IDF component for the DHT11/22 humidity and temperature sensor family.
main.cpp
#include <stdio.h>
#include <string.h>
#include “freertos/FreeRTOS.h”
#include “freertos/task.h”
#include “esp_log.h”
#include “dht_espidf.h”
#define DHT_PIN GPIO_NUM_4
struct dht_reading dht_data{};
static const char *TAG = “Chamber1_Master”;
extern “C” void app_main() {
while (true) {
dht_result_t res = read_dht_sensor_data(DHT_PIN, DHT11, &dht_data);
if (res != DHT_OK) {
ESP_LOGI(TAG, “DHT sensor reading failed”);
continue;
float temperature = dht_data.temperature;
float humidity = dht_data.humidity;
ESP_LOGI(TAG, "Temperature: %f, Humidity: %f", temperature, humidity);
vTaskDelay(pdMS_TO_TICKS(2000)); // Delay for 2 seconds
