Hi, I’ve been using VSCode with PIO integration, and that’s been OK. But when I heard there was integration with Eclipse, I wanted to switch. So I downloaded Eclipse and integrated PIO with it. Everything seemed fine, until I tried using Serial statements in the code.
I have a short program to control LED strips, and was getting unexpected behavior from that program. Using the Eclipse environment, I threw some serial output statements in the code to try and locate the problem, and uploaded the new code to the board. Then I searched the IDE interface…and could find no option to open a serial monitor within Eclipse (I sort of expected there to be one since that is well-integrated with VSCode). Giving up on the IDE for this, I tried using the PIO monitor option, along with running miniterm.py directly, from a bash prompt. Both of those seemed to connect to the serial port OK, but neither gave any output. It was then I noticed that the LED on the board was not flashing, as it usually does when serial I/O is happening.
After trying various remedies with no results, I decided to quit Eclipse and load the project back into the VSCode environment. I did another build/upload, opened the serial monitor and it worked. In particular, I saw that the board LED was now flashing as expected.
So it seems that somehow, within the Eclipse environment, despite the fact that the code works at a base level, any Serial statements I include seem to have no effect. But when building and uploading the exact same code from VSCode, Serial calls work as expected.
I suspect that I must have something misconfigured in the Eclipse environment, but have no idea where to look.
Thanks for any suggestions!
