Dynamic execution of python script in platformio.ini not working, win10+vscode+platformio
I have recently installed vscode and platformio on win10.
If I have:-
platformio.ini
    build_flags = -std=c++17 -std=gnu++17
Then with “pio run --target envdump” from PlatformIO CLI within vscode I see:-
‘BUILD_FLAGS’: [’-std=c++17 -std=gnu++17’]
But if I try this:-
platformio.ini
    build_flags = ! getflags.py
All I get is:-
‘BUILD_FLAGS’: [’! getflags.py’]
So clearly the python getflags.py is not being executed.
The getflags.py is in the same folder as platformio.ini.
Using the full path for getflags.py doesn’t work either.
I have ‘PYTHONEXE’: ‘C:\Users\my_user\.platformio\penv\Scripts\python.exe’.
When I compile the project, build_flags is clearly not set with the expected cpp flags.
I see from another post that someone else has win10+vscode+platformio working for executing python scripts within the platformio.ini, so wondering what could be wrong with my setup?
Docs say that you should write !python <yourscript>, so does
build_flags = !python getflags.py
do anything?
Thanks for quick reply.
This gives
‘BUILD_FLAGS’: [’! python getflags.py’]
While this may be true, the flag still ends up in CPPDEFINES for me. I just tested this:
[env:uno]
board = uno
with getflags.py
print("-DMY_FLAG=123")
and pio run -t envdump shows
  'BUILD_FLAGS': ['!python getflags.py'],
  'CPPDEFINES': [ ('PLATFORMIO', 60002),
                  'ARDUINO_AVR_UNO',
                  ('MY_FLAG', 123),
                  ('F_CPU', '$BOARD_F_CPU'),
                  'ARDUINO_ARCH_AVR',
                  ('ARDUINO', 10808)],
So that’s actually working. The flag also shows up in the verbose build.
avr-g++ -o .pio\build\uno\src\main.cpp.o -c -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=60002 -DARDUINO_AVR_UNO -DMY_FLAG=123 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -Iinclude -Isrc “-IC:\Users\Max Gerhardt.platformio\packages\framework-arduino-avr\cores\arduino” “-IC:\Users\Max Gerhardt.platformio\packages\framework-arduino-avr\variants\standard” src\main.cpp
Many thanks, it turns out that “!python getflags.py” is substituted later and it compiles correctly now.
