I try to set up the hardware DS3234 time with the library “RtcDS3234.h”. The code follows below.
http://codepad.org/pxNNcHTK
Although there is a time setup on line 130, the time print on next lines print an outdated time. I can’t understand what is happening. Can you try to reproduce the error?
Best regards,
Bruno P.
In the code
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
printDateTime(compiled);
Rtc.SetDateTime(compiled);
it’s printing the time at which the sketh was compiled, so that’s normal that it’s a bit behind real-time. Starting from the, the RTC should be primed and counting.
What output does it give fully? Are you using a breakout module? Does it have a battery connected?
I am currently afk and typing from my mobile phone. The output is indeed not the compile time but a DateTime of 2009. What do you mean by breakout module? The battery is connected.
Now, near to keyboard, the output follows:
RTC was not actively running, starting now
RTC lost confidence in the DateTime!
1/4/2021 : 20:10:26
165/85/2009 : 37:165:165
Ego booster: You are awesome and I can’t connect wires. Hahaha
The device is not mistrusted but datetime is wrong. The module gives the time below:
0/0/2000 : 0:0:0
