This is what i am trying to do,
class TEMP
private:
#define ONE_WIRE_BUS 26
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
public:
TEMP();
float getTemp();
and I have tried to crate them in the constructor but cannot return the values.
float TEMP::getTemp(){
TEMP::TEMP(){
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
sensors.begin();
Thanks
How can I create new object from the OneWire library and DallasTemperature library to use the sensor, vscode gives me this error.
We can’t say anything about this error without the platformio.ini
this is my ini file
lib_extra_dirs = ~/Documents/Arduino/libraries
Well this does not work anyways, you have to use use constructor initializer lists here. But the code you’ve shown that errors out is
See https://stackoverflow.com/a/11491003/5296568:
You can initialize the data members at the point of declaration, but not with ()
brackets:
Which means with a slight modifications this works
However, this is still all static data. What you should be doing is allow the class to have a construcot with the one wire pin and then forward that into the constructors of the underlying objects…
#include <OneWire.h>
#include <DallasTemperature.h>
class TEMP
private:
OneWire oneWire;
DallasTemperature sensors;
public:
TEMP(uint8_t pin) :
oneWire(pin), sensors(&oneWire) {}
float getTemp() {
DeviceAddress addr;
sensors.getAddress(addr, 0);
return sensors.getTempC(addr);
TEMP temp(ONE_WIRE_BUS);
void setup() {}
void loop() { float t = temp.getTemp(); }
