I am working on a project that involves using a camera to read QR codes, and I have selected PlatformIO However, I am encountering difficulties in getting the camera to work. Initially, I suspected that the issue was with the code I am using for reading and processing the QR code, but it turned out that was not the case. To investigate, I decided to use the example code provided by ESP32 and when I ran it using the PlatformIO it did not work. So i decided to do it with the Arduino IDE and everything worked fine. I saw some instructions on Github for how to set up the library on PlatformIO but it was only for the esp-idf framework. So how do i do it for Arduino framework using PlatformIO
The error is while running the code. Kindly check the screenshot attached with this message.
Could you please help me understand what I am doing wrong in PlatformIO? I would greatly appreciate it if you could provide guidance on how to correctly use the camera with PlatformIO.
