Open the PN532 folder. What are the files inside it?
What is the platformio.ini
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
monitor_filters = send_on_enter
mbed-seeed/PN532 @ 0.0.0+sha.85bfede025da
bodmer/TFT_eSPI @ 2.5.43
lsatan/SmartRC-CC1101-Driver-Lib @ 2.5.7
sui77/rc-switch @ 2.6.4
This library is for framework = mbed
, not framework = arduino
. It will get ignored in the build. You have to carefully look at the comaptibility chart of the library and not just pick the first library that comes up when searching for “PN532”.
Please use a proper PN532 Arduino library, like:
- https://registry.platformio.org/libraries/adafruit/Adafruit%20PN532/installation
- https://registry.platformio.org/libraries/italia/CIE-PN532/installation
and follow their examples.
The search term for that in the registry would be PN532 framework:"arduino"
, or use the GUI filter.
i picked this specific library because it allowed me to work with NDEF and as far as i know the adafruit library doesnt do that, theres another library i used when using the arduino ide which was made by elechouse but i cant find it on platformio
If it’s https://github.com/elechouse/PN532 we’re talking about, just download that repository and put all these folders into lib/
(so that it has lib/NDEF
, lib/PN532
, lib/PN532_HSU
etc). Delete the old PN532 library from the lib_deps
line and delete the .pio
folder too. Then build again.
thank you, this worked
