I’ve run into an issue with my code where it runs in Arduino, but immediately crashes when ran in PlatformIO with the following text:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x1a (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
I found if I update the ESP32 board in Arduino from 1.0.6 to the newest version of 2.0.11 I get the same error from PlatformIO. I’m trying to downgrade the Arduino core in my PlatformIO project, but changing my framework to arduino@1.0.6 doesn’t seem to work; resulting in the following error:
PLATFORM: Espressif 32 (6.3.2) > Espressif ESP32 Dev Module
Error: This board doesn't support arduino@1.0.6 framework!
========================== [FAILED] Took 0.86 seconds ==========================
Are the versions for Arduino in PlatformIO different than the versions in the arduino IDE, or should I be changing something else?
platformio.ini:
main.cpp/ino
