Hi!
I upgraded platformio from 2.8.6 to 2.9.0.
After that a arduino-project produces tons of “error: ‘any_function’ was not declared in this scope”.
also tried with 2.9.1.dev0.
how can I downgrade to 2.8.6.
Thank you in advance!
Robert
Hi!
Robert
Its a large project with many files in ugly style.
I’v also tried to rearrange it a little bit, including renaming it to .cpp with no success.
Is there do way to downgrade to 2.8.6?
There must be some other way how 2.9.x include functions.
I’v moved all ino-files containing function in one big header file included by main.cpp and sorted these functions in the right order.
It’s compiling now but maintenance is almost impossible now.
Robert
The INO to CPP converter has significantly refactored and optimized. I know about this issue with &prototype
, see Build error after the "Big Update" · Issue #639 · platformio/platformio-core · GitHub.
Do you have constructions in INO file with &protoype
P.S: I’m working on fixing.
P.S.S: If you want to downgrade, please use pip install -U "platformio<2.9"
really tried for hours to figure out what causes the error.
Downgrade to Version 2.8.6 works, thank you!
I’ll try again to figure it out after your update.
Robert
Yes. many of them…
I’ve just added support for pointers to the prototypes. See Handle pointer to the prototypes while converting "*.ino" to ".cpp" /… · platformio/platformio-core@a77cbe5 · GitHub.
Could you try the latest development version? Does it work for you?
I tried with “pip install -U https://github.com/platformio/platformio/archive/develop.zip”
with no success.
as i said, my code ist ugly, so probably that’s the reason, so don’t worry.
Robert
Could you share here a few parts before setup()
with problematic files? It’s very important for me to understand why it doesn’t work. Does it work with Arduino IDE?
Current version of my software does not run on Arduino-IDE anymore.
Obviously i made some changes in the past.
To test it for you i took an older version, compiled under arduino-ide.
Then- on platformio 2.8.6 - i had to put everything before setup() in a separate header file to compile the code.
with 2.9.0 it does not work at all.
Sorry but I can’t share the code here, it was my first project and it would immediately exhibited as the worst code ever written on this world;)
Robert
I don’t need old code that works under Arduino IDE. I need code/example that doesn’t work under PlatformIO
Could you create some snippet to reproduce this issue? You can mail me@ikravets.com and I’ll not share your code.
Sorry but i thought you need a code that compiles under arduino-ide AND platformio 2.8.6.
I really want to help you and i tried hard for hours to create a code snippet for you but I did not succeed:(
All I could do is: to mail you the whole code but - believe me - then you’ll only get dirty fingers;)
Robert
No problem, I just want to understand can I improve current INO to CPP converter. Thanks.
PlatformIO 2.9.1 is out! Please upgrade.
